Question about LG Cell Phones
How do you unlock a lg microwave model number LMVM2055st I've had it for about 7 years now it's showing me : thanks
MicrowaveSvc
  • 9098 Answers
SOURCE: LG Microwave LMVM2055ST Just stopped working!
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics. You'll probably have to call them.
Posted on Dec 13, 2008
EwingElect
  • 276 Answers
SOURCE: bulb for lmvm2055st lg microwave
Can't help with part number as it's not an Australian Model, but refer to http://us.lgservice.com/index_b2c.jsp to help you find a service location!
Posted on Mar 19, 2009
  • 97 Answers
SOURCE: manual missing in box
Found manual download through LG go to http://www.lge.com/us/support/product/support-product-profile.jsp?customerModelCode=LMVM2055ST&initialTab=documents (this is a link to download...will need adobe).
Posted on Jun 08, 2009
SOURCE: LG Microwave oven LMVM2055ST
Same issue here. LMVM1935 about 2 months past warranty keypad stopped working. Apparently they need to add something in the manual about not boiling water on the range over which the microwave is installed (gee who would have thought that there would be steam over the cooktop and we should seal the membrane?).
The silver traces on the keypad got corroded and no longer conduct. After complaining to Sears (NO HELP) and LG (EVEN MORE INEPT) and running on 30sec button for about 6 months, I found a replacement keypad $30 w/ shipping and didn't break anything taking the door apart, thanks to the parts list link above. Thanks Rickzilla!
Life's Good, Their Keypad SUCKS, or apparently we are the only people that boil water anymore.
Posted on Jul 27, 2009
  • 37 Answers
SOURCE: Our microwave is not working. As near as we can
yes, it's easy.
unplug it.
open the case.
trace the power cord from the plug end. you should encounter an in-line fuse (like an old-style auto fuse)
just go to the hardware store and get the same type fuse. it will look like a small white cylinder, about the size of tic-tac (but a little longer) with metal ends.
Posted on Oct 21, 2009
On stove bulbs what is the wattage I need to replace the two bulb's. Everytime I purchase bulbs they don't last long. LG microwave, model # lmvm2055st Thanks, Dave
There should be a sticker in the back that quotes this. 40 Watt is the highest you may go but....buy the 130volt brands as this is a higher rating for 120volt and it will not burn out as quick. Make sure it is an appliance bulb. Most hardware stores like ACE have them. Big Walmarts do too but check the package.
Jan 03, 2011 | LG LMVM2055 Convection/Microwave Oven
We have a over-the-range LG Microwave Model #LMVM2055ST purchased in 2006. It was working fine until today when I tried to heat something, it wouldn't start. The light works inside when you open the...
Most likely the touch panel is bad. You can try ordering a new one from repairclinic.com by searching with your model number. If you find that replacing it doesn't help, return the panel within 30 days and you are only out the shipping costs. With what you describe, it should be the panel itself. Let me know what you find out.
Benjamin
Nov 04, 2010 | LG Over-the-Range Microwave
LG LMVM2055ST Microwave. went completely dead, completely
I replaced outer door with key panel on my LG MICRO MODEL LMVM2055ST which solved my problem but when I went to put the handle back on it did not fit. The tophole in new panel for the handle is round and the old one is rectangle. LG says I have right part can not help me.A new handle comes rectangle shape. What now?
Mar 15, 2010 | LG LMVM1935 Convection/Microwave Oven
Display scrambled on my model # LMVM2055ST
HI. this LCD is attached to the PWB assembly board. Unfortunately, this lcd is not sold separately and, you will need to replace the whole PWB assembly in order to fix this issue.This is actually a pwb(pcb) assembly failure.
CLICK HERE TO ORDER YOUR NEW PWB ASSEMBLY(LCD)
Jun 04, 2009 | LG Microwave Ovens
Bulb for lmvm2055st lg microwave
Jan 12, 2009 | LG LMVM2055 Convection/Microwave Oven
Sep 05, 2008 | LG LMVM1935 Convection/Microwave Oven
LG MICROWAVE LMVM2055ST
your gonna have to get another key pad
Mar 25, 2008 | Microwave Ovens
Cell Phones Logo
29 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
