Question about Aurora Electronics PR600M Basic Calculator
Will this print roller fit the Aurora PR600M Palm Printer 12 Digits Multi-Funtional printer
  • Aurora Elect... Master
  • 3,957 Answers
Hard to tell from here. Cannot see the print roller, and do not know what or where it came from. Perhaps a visit to an office equipment repair shop can get you the help you need.
Posted on Apr 27, 2015
Funtional problem SC302
It depends on which Ricoh model.
Some Ricoh copier/printer use a corona wire for charging the drum, so SC302 means that the corona wire is ether broken or have some current leak. but in most case the wire is broken.
Other Ricoh copier/printer use a charge roller for drum charge, so on this model SC302 usually appear when the charge roller have a bad contact.
Aug 19, 2013 | Ricoh Office Equipment & Supplies
How do i clean the rollers
Introduction Your printer requires minimum routine maintenance. This chapter explains the following tasks
  • Cleaning the printer
  • The toner cartridge
  • Extending toner cartridge life
  • Clearing a TONER LOW message
  • Replacing printer parts
Cleaning the printer To maintain print quality, thoroughly clean your printer:
  • Every time you change the toner cartridge
  • After printing approximately 6,000 pages
  • Whenever print quality problems occur
Clean the outside of the printer with a lightly water-dampened cloth. Clean the inside with only a dry,lint-free cloth. Observe the warnings and cautions that follow the cleaning tasks on the following pages. Caution To avoid permanent damage to the toner cartridge, do not use ammonia-based cleaners on or around your printer.
Printer Cleaning Tasks Before you begin these steps, turn the printer OFF and unplug the power cord. Caution Do not touch the transfer roller (black sponge-rubber roller) with your fingers. Skin oils on the roller can cause print quality problems.
If toner gets on your clothes, wipe it off with a dry cloth and wash your clothes in cold water. Hot water sets toner into fabric.
Warning Avoid touching the adjacent fusing area. It may be HOT
  1. OPen the printer's top cover and remove the toner cartridge
  2. with a dry lint-free cloth, wipe any residue off the Paper Access Cover (it has a green handle) and the adjacent silver metal strip.
  3. Wipe any dust or dirt off the black plastic Paper Feed Guide with a dry, lint-free cloth.
The Toner Cartridge see the printed book pending update of this page Extending Toner Cartridge Life see the printed book pending update of this page Clearing the TONER LOW Message see the printed book pending update of this page User-Replaceable Parts Some worn parts can be replaced by the owner. See Chapter 8, "Solving Printer Problems", for descriptions of the difficulties that can indicate when to replace a part. Warning Switch OFF and unplug the printer before replacing parts. Failure to do so may result in personal injury or damage to the printer. After switching the printer OFF and unplugging the power cord, allow the printer to cool for 30 minutes before replacing the parts.
Unless specifically noted, replacement is the reverse of removal. Always carefully observe the position and alignment of the part you are removing; this is your best guide to replacement. User Replaceable Parts Part Name Part Number Remarks Multi-Purpose (MP) Tray Pickup Roller RB1-2127-000CN Replace both the MP Tray Pickup Roller and the MP Separation Pad at the same time. Multi-Purpose (MP) Tray Separation Pad RF5-0343-000CN Replace both the MP Tray Pickup Roller and the MP Separation Pad at the same time. Paper Cassette Pickup Roller RB1-2204-000CN See Chapter 8 for replacement conditions. Transfer Roller RF5-0349-000CN See Chapter 8 for replacement conditions. Fusing Assembly RG5-0880-000CN 220-240 Volts Cleaning Brush RB1-2260-000CN n/a Optional LC Pickup Roller RB1-2650-000CN See Chapter 8 for replacement conditions. Ordering Information User replaceable parts are available from the authorized HP dealer or from Hewlett-Packard. To order parts, see this information Multi-Purpose (MP) Tray Paper Pickup Roller and Separation Pad Before you begin these steps, turn the printer OFF and unplug th power cord.
  1. Open the Multi-Purpose (MP) Tray.
  2. Grasp the black plastic Envelope Feed Access Cover as shown, and pull it downward and toward you to remove it.
  3. Read all of this step before proceeding. Remove the pickup roller by pushing down on the plastic retaining clip with your right index finger (see inset A) while sliding the roller to the right with your left index finger. When the roller is partway to th right, push in on the small plastic tab (see inset B) behind the right end of the roller and fully remove it.
  4. Insert a flat-blade screwdriver into th indentation at the front of the separation pad and twist the screwdriver blade gently to loosen the pad see (inset). When loose, gently lift pad from its seat.
  5. To install a new separation pad, place it over the opening and press it down firmly with your forefinger to seat it. Be sure the metal edge is toward the front of the printer. To install a new Multi-Purpose (MP) Tray Paper Pickup Roller, slide it over the shaft, then rotate it so that the flat side of the new roller is aligned with the flat side of the shaft. Then slide th roller to the left until it clicks into place.
  6. Reinstall the black plastic Envelope Feeder Access Cover and discard the used roller and pad.
Paper Cassette Pickup Roller Before you begin these steps, turn the printer OFF and unplug th power cord.
  1. Remove the toner cartridge.
  2. Remove the Paper Cassette.
  3. place the printer on its left side so that the bottom of the printer is easily accessible.
  4. Remove the pickup roller by pinching the release clip and sliding the roller off the shaft (the new roller will be installed in the reverse order). Slip the new roller over the shaft and rotate it until properly aligned. Slide the roller along the shaft until it clicks into place.
  5. Place the printer upright, then place the toner cartridge, Paper Cassette, and power cord. Switch the printer ON.
Transfer Roller see the printed book pending update of this page Fusing Assembly see the printed book pending update of this page Lower Cassette Pickup Roller Not applicable to HP printers at ING
Please rate my solution! :)) Thanks for asking me :)
Apr 13, 2011 | HP LaserJet 4 Printer
Hello Sir, Please help me, i hav 6690cw printer, when i am printing multi copy (50copy) after 1 or two copy, there is a paper jam indication, half of the paper is in tray, sometimes little end is there in...
Your roller(s) are worn and failing to properly grip the paper to feed it.
The printer technician's solution to this problem is to order a "Roller Kit" for the printer,
and replace all the rollers - when one starts to lose its grip, they all will soon go - since
all wear at about the same rate.
This happens after a printer has printed alot of pages - the definition of "alot" varies from
printer to printer.
Feb 13, 2011 | Brother MFC 6490CW InkJet Printer
I cannot believe, after I bought a Kodak printer and use Kodak ink, that you would tell me that I will get better help if I grease the palm of your technicians! Ethics anyone??? My Easyshare 5300 is...
This printer was slated for poor quality performance.
Problems included:
Inkheads drying up
Alignment issues
Incorrect pressure on feed rollers / prints dragging
A lot of returns with damaged print heads, I'd suggest you do a RTB and state it is not fit for purpose
Jan 26, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have Multi funtional Lexmark x342n machin. but i don't know,How to send fax from my machin.
have you installed the driver properly then good .in printer a fax printer is also installed when you install the full software of printer driver .for sending fax from any document choose the print option and in printer select the fax printer and send the fax.
but make sure fax printer is installed.
Jan 14, 2010 | Lexmark X342n All-In-One Laser Printer
I get error 0408 when i try to fax. Using epson
Communication error,try defaulting the machine ,check the line with a good telephone make sure you have dial tone.
Good luck
Sep 21, 2009 | Epson WorkForce 600 All-In-One InkJet...
Won't print from tray 1...
Hi banelson: Tray #1 pickup problems
Possible Solutions:
1. Dirty,worn,or deformed multi-purpose tray pickup roller.
A. if dirty, clean the roller.
B. if worn or deformed,replace the roller
2. Defective separation pad.
A. if dirty,clean pad. if worn or deformed,replace pad
3. Damaged drive gears.
A. Check the drive gears in the pickup/feed area. if damaged,replace the gear.
4. Defective multi-purpose tray pickup solenoid.
Dec 19, 2008 | HP LaserJet 3600n Printer
Printing problem with HP Laserjet P2015 printer
This can be an issue with one of the faulty sensor across the printer.
Please check if you are able to print from tray 1, e.g. a configuration page.
A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
Figure 1: Unplugging the power cord
mma01_13245_0
2. Open the print cartridge door, and remove the print cartridge.
Figure 2: Removing the print cartridge
mma01_13246_0
3. Remove the main input tray (Tray 2).
Figure 3: Removing the main input tray (tray 2)
mma01_13247_0
4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only).
Figure 4: Opening automatic two-sided path door
mma01_13248_0
5.Place the printer on the work surface with the front of the printer facing up.
Figure 5: Placement of printer
mma01_13249_0
6. Pull the white tabs outward, and rotate the tabs up.
Figure 6: White tabs
mma01_13250_0
7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
Figure 7: Right tab movement
mma01_13251_0
8. Slide the pickup roller assembly to the right, and remove the left end cap.
Figure 8: Pickup roller assembly movement
mma01_13252_0
9. Remove the pickup roller.
Figure 9: Pickup roller
mma01_13253_0
10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the right slot (2).
mma01_13254_0
11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
Figure 11: Pickup roller end cap
mma01_13255_0
13.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer facing up. 15.Close the front automatic two-sided path door.
Figure 12: Closed automatic two-sided path door
mma01_13256_0
16.Reinstall the print cartridge, and close the print cartridge door.
Figure 13: Print cartridge
mma01_13257_0
17.Plug the printer in to turn it back on.
Figure 14: Power cord in
mma01_13258_0
Cleaning the pickup roller
Perform the following to clean the pickup roller.
1.Remove the pickup roller as described in steps 1 through 9 of Replacing the pickup roller above.
2. Dab a lint-free cloth in water, and scrub the roller.
mma01_13259_0
Figure 15: Scrubbing the roller
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
mma01_13260_0
4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
mma01_13261_0
Figure 17: Reinstalling the pickup roller
Oct 27, 2008 | HP LaserJet P2015dn Printer
Printing multi copy forms
you can check your paper size or the tear of poit and set it to that point.
Oct 01, 2008 | Epson FX 890 Matrix Printer
Aurora Electronics PR600M Basic Calculator Logo
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
Jim Keysor
ka4iup
ka4iup
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
