Question about Sewing Machines
The bobbin thread is not catching the upper thread. Can't even catch the thread initially. What can I do?
Cleaned and oiled the bobbin compartment. Tried adjusting tension screw on bobbin case. Still not catching.
    Top Expert:
  • Sewing Machines Master
  • 47,586 Answers
There is a possibility that the needle /bobbin timing is out
check this by inspecting the needle eye position in relation to the bobbin hook
the hook should be at the needle just above the eye if the timing is correct
the method for adjustment will be in the work shop manual for the machine , available from the manufacturer on line in pdf version
failing that take it in for a service and adjustment
Posted on Apr 27, 2015
Why does my thread keep bunching up?
That is called "thread nesting," and several things can cause it. The upper thread enters the bobbin area during sewing, catches the bobbin thread, and as the needle goes up, pulls the stitch tight. Something is catching the upper thread as it goes around. The most common reasons are the bobbin or bobbin case (or both) is improperly inserted; the bobbin is warped (roll it down a flat surface--if it wobbles, it's warped), either the case or the bobbin is not seated evenly, there is a rough spot on the bobbin case that is catching the thread, or your bobbin is loosely/badly wound. You need to rule out the possibilities step by step until you find the cause. First, review your threading procedures from start to finish, using your user's manual. Then, without fabric, turn the hand wheel by hand (ALWAYS towards you) to see if you can see it start to catch. The top thread should rotate smoothly in the bobbin area. You should be able to pin-point the cause that way.
Sep 24, 2014 | Singer 2517 Mechanical Sewing Machine
Upper thread is not catching bobbin thread
Carmen, seem that you have carried out the necessary rectification, but could it be your rotary hook tip blunt/broken, if not most probably it needs needle/hook timing adjustment. And this will require your sewing machine technician to do it.
Jul 24, 2013 | Sewing Machines
I have a Necchi 535FA sewing machine that will not catch either the thread, just leaves a stright line of thread not catched
try changing the needle
also try rethreading the machine top and bobbin
make sure the bobbin is turned the correct way in the bobbin case
if the suggestions don't help then it's possible that the machine
needs to be checked for a timing problem
Jan 15, 2013 | Sewing Machines
Upper thread will not catch the bobbin thread
make sure to use every thread guide
try a new needle
make sure the bobbin is inserted correctly
if these suggestions don't help & if the machine is still under warrenty take it back & let them check it
Mar 20, 2012 | Singer Sewing Machines
I cannot get the needle to catch the bobbin thread
sounds like your keeping the upper thread too tight when you drop your needle down to catch the bobbin or the bobbin thread that you left hang out is too short, let me know if it works amy
Jul 25, 2008 | Brother LS-2125 Mechanical Sewing Machine
Upper thread will not catch bobbin thread
Your machine is out of time. It would be best to have a tech adjust the timing.
Jun 01, 2008 | Bernina Virtuosa 150
Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
  • Thread the needle.
  • Turn the handwheel by hand.
  • Watch the hook as it approaches the needle from right to left.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
Nov 12, 2007 | Kenmore 12102
Brother 3022 Mechanical Problem
Make sure your needle is in correctly. Check your threading again. If that does not work, remove throat plate, install new needle, turn hand wheel until needle is at its lowest position and observe if the hook is exactly behind the eye of the needle. If that is correct then you do not have threaded correctly. If it is not then the machine needs to be re-timed.
Oct 09, 2007 | White Sewing 2037 Mechanical Sewing...
Bobbin thread won't catch
I've just had this exact problem with my model 2037. The problem, according to 3 shops I've taken mine to, is that the shuttle hook (the metal piece that the bobbin sits in) is broken and needs replaced. Problem is, the piece is next to impossible to find.
Jan 14, 2007 | White Sewing 2037 Mechanical Sewing...
Sewing Machines Logo
60 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
