Question about Garmin DC 50 Dog Tracking Collar
Collar is blinking a red light and want connect to hand device
My HBS-900 headsets have a blinking red and blue light that blinks when it's on and off, it won't pair with anything, and when I put it on charge it blinks red and blue
Usually this means there may be too many Bluetooth devices in range to connect to and cannot connect so the blue and red flashing lights indicate an error. A second possibility is that the device is broken. This might sound strange but sometimes several sharp firm raps to the side with the charger port and lights along with a few power cycles often snaps it out of error and back into operation. Good luck.
Dec 28, 2016 | Radio Communications
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
Blinking light
The issue is the dispensing unit you have is a sanitizer dispenser, not a soap dispenser. The adapter collar on the bottle is the issue. Soap dispensers use a GRY collar, sannitizers use an LBL collar. There should be a sticker on the dispensing unit that says "LBL" or "GRY". Try removing the collar from a sanitizer bottle and place it on your soap bottle......should work fine. In short, make sure your letter code on the bottle mathces the letter code on the dispenser.
Jan 30, 2014 | GoJo Purell 2720-12: TFX ? Touch Free...
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
My garmin rd 40 colar dons'nt blink...solid red light
You may want to contact Garmin Support for assistance.
1-800-800-1020
Nov 24, 2011 | Garmin DC 40 GPS Dog Tracking Collar
Blue Parrott Road Warrior B250XT, will not stay connected to my phone, The phone is a Motorolai335, it will connect and disconnect just when ever some times every 3 to 5 minutes and will reconnect within...
These steps are for a headset that is already paired to you cell phone and is stored in the phones trusted device / history list.
Look at the lights on the Multi-Function Button of the headset (the top / largest button of the three buttons); the light will be blinking Red if not connected and blue if connected (paired and connected are two different things). Push the volume up (middle button) 2 times, you should hear a beep each time you press it. If you hear the beeps go to the next paragraph. If you hear no beeps at all you will need to call 1-800-742-8588 for an RA # (Return Authorization Number) for warranty and non warranty repairs.
Look at the lights on the Multi-Function Button on the headset (the top / largest button of the three buttons); the light should be blinking Red if not connected and Blue if connected (paired and connected are two different things). Plug the headset into the power adaptor with power applied. Make sure your cell phone is on and the Bluetooth power of the PHONE is turned on. After 5 seconds unplug the headset from the charger and do not press any buttons. You should get a slow Red blinking light at first. Allow the headset to connect automatically to the cell phone, this may take up to 10 seconds. Once the connection has occurred the Blue light on the Multi-Function Button will blink once every second.
If after 10 seconds the light is still blinking Red once every 5 seconds you will need to press either the Multi-Function Button of the headset once to connect to the cell phone, or, your phone may be set up requiring you press a designated button or sequence in the phone to connect to the headset (meaning your cell phone is not set with or does not support automatic connect).
*NOTE* Most newer model cell phones have an automatic connect feature. Some phones have the categories of "Headset", and "Hands Free" in their Bluetooth menu. Some companies use the term Auto-Connect under the "Hands Free" category in their Bluetooth menu to indicate the set up for use with the Bluetooth system in an AUTOMOBILE.
Automatic connection under the "Headset" category and Auto-connect under the "Hands Free" category are not the same thing. When dealing with the headset you want to work in the "Headset" menu and make sure the Auto-connect of the "Hands Free" menu is turned off.
If this doesn't correct the issue I'd recommend calling VXi at 800-742-8588 for additional clear and reset instructions and the possability of warranty repair options.
Aug 29, 2011 | VXI Corporation Blueparrott B250-XT...
My garmin dc 40 red light stays on solid?
update your collar..mine was doing the same.As soon as I updated it ,it worked fine
Aug 08, 2011 | Garmin DC 40 GPS Dog Tracking Collar
Hello! i bought 4 collar dc40 for astro 220. one of them have a problem: the light is red and fix: what happend?
UPDATE THE COLLAR,ONE OF MY COLLARS WAS DOING THE SAME. AS SOON AS I UPDATED IT ,IT WORKED FINE
Dec 07, 2010 | Garmin DC 40 GPS Dog Tracking Collar
Not working
dear,
The small notch in usb device socket under the mouse could be malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
regards,
dont forget to rate it
Aug 19, 2008 | Microsoft Wireless Notebook Optical Mouse...
Mouse optico doesnt work
dear,
The small notch in usb device socket under the mouse was malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
regards,
hope it will fix your problem
Jun 27, 2008 | Microsoft Wireless Notebook Optical Mouse...
Garmin DC 50 Dog Tracking Collar Logo
723 people viewed this question
Top Garmin Home Security Experts
Lawrence Oravetz
Are you a Garmin Home Security Expert? Answer questions, earn points and help others
