Question about PfaFF Sewing Machines
Need correct part number for commercial sewing machine
Pfaff serial# 146H-6C/D LM double bobbin. Is bobbin assembly 91-011 246-05 (section 3 pg. 22 Pfaff list of spare parts) or 91-113 077-05 (section 11 pg. 53) the correct part?
    Top Expert:
  • PfaFF Master
  • 50,033 Answers
Contact paff direct with the information and they should help verify the parts
could even help with supply or a dealer that has the parts.
Posted on Apr 27, 2015
My bobbin is winding really slow on my Pfaff Quilt Expressions 4.2. It used to wind fast and don't know what happened.
Hard to say.
Does it wind slow with both methods? I would double check that the thread path is correct--incorrect thread path could cause it move slower
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwj8nPz_2qXYAhXSk-AKHTYIDQsQFggmMAA&url=http%3A%2F%2Fwww.pfaff.com%2FSiteMedia%2FPFAFF%2FProducts%2FMachines%2Fexpression-line%2FManual%2Fexpression-3-2-4-2-manual-EN.pdf&usg=AOvVaw00vbTPKaCOh98HQ2-QnKQP
You may find a standalone bobbin winder (Sidewinder for $30) avlb at JoAnn's or on Amazon. Nice little accessory that lets you wind multiple bobbins without unthreading the machine and also saves wear and tear on your machine.
Dec 25, 2017 | PfaFF Sewing Machines
This is on a 5.0 pfaff sewing it will build a bird nest below the plate
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the top tension to the midway point (may need to tweak this for your particular machine).
Remove the bobbin thread from the machine. Reinstall the bobbin in the bobbin case confirming the bobbin is turning the correct direction and the bobbin case is correctly threaded.
Pull the bobbin thread up to the top of the fabric and gently hold both thread tails in your left hand when slowly taking the first couple of stitches.
Apr 30, 2017 | PfaFF Sewing Machines
Pfaff 1221: was sewing fine; now top thread doesn't catch bobbin thread
try rethreading the machine top and bobbin
make sure the bobbin is inserted correctly into the bobbin case
and if that doesn't help, the problem could be a timing issue and would require a sewing machine shop
Apr 15, 2015 | PfaFF Sewing Machines
Thread keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Sep 02, 2013 | Pfaff Creative 4.0 Sewing Machnie
How can I factory reset my PFAFF 7550 sewing machine ?
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Feb 28, 2013 | PfaFF Creative 7570
Pfaff 4.0 quilt expression pulling bobbin thread up to top of fabric help.
try a new needle
rethread the machine top & bobbin
try adjusting the top tension just a touch to see if that helps
clean under the needle plate & in the bobbin area for loose threads
or lint
make sure the bobbin is wound correctly & inserted into the bobbin
case correctly
Jun 04, 2012 | Pfaff Creative 4.0 Sewing Machnie
I just inherited a Pfaff 139. Can you tell me what year it was made? I tried sewing with it and I think the belt is a little old. On the bottom of the machine there are these letter: GZ-01022. On the front...
Hi! Congratulations! I just read a great review of your machine at http://sewing.patternreview.com/cgi-bin/sm/readsmreview.pl. One of the things the reviewer noted is that the 139 wasn't designed by Pfaff. It was designed by another sewing machine company (the GZ in your serial number) that Pfaff had bought. The machine dates to the 1950s.
Statewide sewing (http://www.statewidesewing.com/#Accessories) has a great selection of belts.
Hope this helps!
Happy Sewing
Robbie
Feb 15, 2010 | PfaFF Sewing Machines
I have a 15212 model sewing machine & have hardly used it. When sewing the other day a few stitches went out of the fabric and got stuck. I opened the shuttle assembly, cleared the tangled thread and...
Sorry to say but one of your steps is incorrect. Look at it again, take a deep breath and gom
over everything slooowly. If this really doesn't work then Im afraid it's a technician you need :) .
Apr 27, 2017 | Kenmore 15202 Mechanical Sewing Machine
Shuttle alignment and assembly
The shuttle/race/bobbin system shouldn't really be taken apart by the average user. Unfortunately, your chances of ever getting it back together properly so the machine will sew (this is the timing of the machine) are very slim. You'll need to take it to a sewing machine technician. I would recommend an authorized Pfaff tech as they'll be sure to have the proper tools to do this correctly - won't be inexpensive but will be worth it. Most "neighborhood sewing machine repair folks" don't have experience on computer machines. Resetting timing on a computer machine isn't the same as the old mechanicals and requires some expertise.
May 02, 2008 | PfaFF Creative 7570
Sewing Machines Logo
59 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
