Question about Confidence Gtr Power Pro Motorised Treadmill
Machine is on but belt wont move - Confidence Gtr Power Pro Motorised Treadmill
Model 2142. Motor runs but why doesn't belt move for regular sewing?
Make sure the bobbin winder has not been activated. When the bobbin winder is activated, the needle bar is deactivated. The belt could also be stretched, damaged, or broken.
If it is a mechanical machine, how long has it been since a thorough cleaning and oiling?
It was working now it seems to be frozen the needle part wont move
Mar 06, 2016 | Kenmore Sewing Machines
Hoover optima 614 drum wont spin
Either a broken drive belt or a failed transmission.
Jan 12, 2015 | Hoover Washing Machines
Drum wont turn or empty water
depending on the model, a broken belt is a good possibility. if you hear the motor going, but the bowl isnt moving, that is a sign of a broken belt, it is also possible the motor has failed.
Nov 11, 2013 | Washing Machines
Acd3 treadmill belt wont move
hi There.
A treadmill belt can shift to the right or left over time. If it shifts enough, this may cause the belt to stop moving. Stand at the back end of your machine and inspect the belt. If it has shifted, you will need to center it by turning the rear roller adjustment bolts. These bolts adjust both the tension and the centering of the belt. Follow the instructions in your owner's manual that explain which of the two bolts you need to tighten or loosen to shift the belt back to the center.
If the belt is too tight, it could cause enough tension that the motor can't turn the belt. This is most likely the cause of your belt not moving if you recently adjusted the belt tension due to slippage. Lift the edge of the belt. If you can't raise it at least 2 to 3 inches off the walking deck, the belt is too tight. Follow the directions in your owner's manual for loosening the belt. You will need an Allen wrench to loosen the rear roller adjustment bolts.
If the troubleshooting does not get the belt running again, you may have a tight motor belt or a bad motor. You will need to remove the motor hood to access these parts of your machine. If your treadmill is still under warranty, contact the manufacturer for a professional repair. You may void the warranty if you attempt to work on the motor yourself.
or read up some more at this link.
How to Fix Treadmill Belt That Won Move
or this one.
Acd3 treadmill belt wont move Google Search
Dec 16, 2017 | Exercise & Fitness
Janome 655
I am no mechanic but it sounds like the drive belt from the machine motor is broken. Replace the belt. You should not need to time the machine or do anything else. It is a simple fix!
Mar 06, 2012 | Janome Sewing Machines
Belt wont stay on maytag neptune washer
Put the belt on the wheel & motor pulley. The motor is fixed in such a fashion that at one end it is hinged & other end can be moved freely which is secured by bolts. release these bolts just to move the motor downwards. Put some pressure for the tension required for the belt & tighten these bolts.
Sep 18, 2011 | Washing Machines
The mower with not move! I put it in forward push the gas paddle and it will not move. It just wont move, it has a brake paddle and a gas paddle and brake. All yard machines basicly have the same setup in...
Inspect the drive belt,if it is broken.Under the hood is a list of parts and part numbers.Find the drive belt on there and get a replacement.The package the belt comes in has the diagram for installation on the back.Would not be a bad idea to go a head and change the deck belt if it is ore than 2 years old,while you are under there.
May 12, 2011 | Yard Machines 155 Torque Briggs Stratton...
Washing machine GLWS1649ASO wont spin on spin cycle. motor and pulley turn, but belt doesn't move. Is it the belt?
no it will not be the belt more so it will be a bad transmission.or something stuck under the agitator i have seen drill bits and keys get stuck under the agitator and cause the transmission to stop
remover the agitator first and check it is there is nothing there the transmission needs to be replaced
Oct 02, 2009 | Frigidaire GLWS1649A Top Load Washer
Self propel will go foward, but will not reverse. Seems like handle is all the way extended.
There is a cable that connects to the handle and goes down to the powerdrive transmission. It is visible at the actuator arm on the drive if you look at the bottom of the handle where it pivots on the main housing. It will be on the right hand side, front corner of the handle bottom. You should be able to see the cable connected to the arm of the drive and will move back and forth with the top handle. Sometimes, they break at this connection. The cable may be frayed and broken, or the acuator arm may be broken where the cable connects.
This could also be a simple worn belt problem. The roller is always rotating in a direction that pulls the machine forward and if the belt is worn, the roller will turn sluggishly but still enough to pull forward, but the belt also drives the transmission and a worn belt will not have the capacity to overcome the forces involved to propel the machine backwards. Always change the belt(s) yearly.(on average)
Dec 22, 2007 | Hoover U6630-900 WindTunnel Bagless...
Confidence Gtr Power Pro Motorised Treadmill Logo
64 people viewed this question
Top Confidence Exercise & Fitness Experts
ray gallant
Bill Boyd
Are you a Confidence Exercise and Fitnes Expert? Answer questions, earn points and help others
