Question about Whirlpool Washing Machines
Whirlpool washing machine 360degree before spinning 551error code display. What is the remedy
    Genius:
  • Whirlpool Master
  • 1,585 Answers
Check pump
Posted on Apr 27, 2015
SOURCE: Whirlpool Cabrio HE washing machine
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Posted on Jan 01, 2009
SOURCE: flashing code F-6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Posted on Apr 12, 2009
  • 6 Answers
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Posted on Sep 09, 2009
Krazytech
  • 725 Answers
SOURCE: washing machine whirlpool awm8123/1 stopped and FH on display
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR If the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. Press PAUSE/CANCEL twice to clear the display.
check the fill hose screens or you my have to repalce water valve make sure water is turned on....
Posted on Sep 19, 2009
  • 942 Answers
SOURCE: washing machine drains, wont spin, making clicking
If your washer won't spin, check these: It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jan 30, 2010
Ul is displayed what does this mean
UL Stand for unbalanced load
probably the balance rods washer has 4 of them and they work like shocks for the tub and if they go bad than they allow the drum to spin wildly.
Jun 03, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
F- code does not show code in book what and how to remedy the problem?
Hello there again here is some more info for you
Whirlpool Washer Troubleshooting: Error/Fault Codes Whirlpool Washer Troubleshooting has been made easier since newer Whirlpool washers generally display a consistent range of error codes (or fault codes) when problems develop so that owners and service personnel can quickly troubleshoot the problem and fix it easily. The Fault codes address a wide range errors that occur with Whirlpool washers, everything from water and power problems to basic maintenance routines. We have put together a comprehensive list of Whirlpool Error Codes for some specific and general Whirlpool Washer models to help you with your Whirlpool Washer Troubleshooting task.on next post
Oct 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer, during the wash cycle, get H F error code
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Washing Machines
ERROR MESSAGE F50
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^&*(
Jun 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The digital display jumps programmes wont empty or spin
Take the toe kick off of the machine. Reach in and up to the right. There is a "manual" which covers error codes and possible remedies but not much more. Hope your "manual" is still there.
G.
Apr 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirl pool sports washing machine is displaying the error code F2? pls suggest some remedy
HI There
i have this code for you and this is helpful and let me know how it goes.
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pumpThank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Whirlpool Washing Machines
My Whirlpool Calypso Washing Machine has a code Er But makes no beeping sound? What is wrong with it and how do I remedy this?
You sad,My Whirlpool Calypso Washing Machine has a code Er But makes no beeping sound? What is wrong with it and how do I remedy this?
You can unplug the washer for 5 minutes and this should reset the system
Huuum
Oct 24, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
