Question about New World Kitchen Ranges
When I ignite my new world gas oven the flames stay low no matter how high I turn it.
  • 1 more comment
  • James Jones Apr 27, 2015
    yes its all the burners, would you know if the part i may need is called an FSD, this is what is mentioned in the manual but does not explain what it does, the cooker is about 10 years old. Thank you for your previous comment.
  • David Bugden
    David Bugden Apr 27, 2015
    Yes it is a flame sensor device a lot like the old thermal couplers used in the older stoves..
    The difference is ones electronic and the older thermal were direct contact with a pilot light.. guess what one costs more :)
    ha ha the one that i need, thank you ?
    Master:
  • 430 Answers
If it is happening on all burners then the regulator is probably pooched... this is what allows has to enter the lines but not at too high a pressure
Posted on Apr 27, 2015
Testimonial: "Extremely helpful,very quick reply."
SOURCE: my gas oven flame
the flame failure device( FFD) may have malfunctioned,not allowing full volume of gas through to the burner.This is a safety feature, preventing full gas pressure to the oven straight away.
Posted on Oct 01, 2007
bigg t
  • 640 Answers
SOURCE: Gas Oven Flame Constantly on High
I belive that the thermostat to the oven isnt working properly.The t-stat bulb sits inside the oven on the wall and this is what senses the temp in the oven.If its out of place or the t-stat is bad the oven will just keep heating.hope this helps let me know.HAPPY HOLIDAYS!!
Posted on Dec 03, 2007
  • 160 Answers
SOURCE: Gas oven
Its the flame failure device faulty (FFD)
Posted on Feb 22, 2009
bozcro
  • 867 Answers
SOURCE: xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Posted on Jul 30, 2009
  • 42 Answers
SOURCE: Newhome stoves 600 SIDO oven ignites but flame stays low
your problem is the fsd ,iam a x gas service eng.
Posted on Sep 28, 2009
My oven does not want to heat up - it always stays on LO? can u help
Do the top burners act properly, meaning giving high heat? Are you seeing black soot or just low flames? Low heat all around possible the gas cutoff in the kitchen has been turned down accidently. not an expert but have experienced the same problem with my new gas stove. The valve was almost off.
Nov 29, 2012 | KitchenAid KGRT607 Gas Kitchen Range
My stove lights very slow with a low flame. Should the igniter stay on after it lights oven
Yes the ignitor stays on even after the burner is lit. The ignitor is wired in series with the oven valve. It sounds like the oven valve isn't opening all the way. A new ignitor should solve this problem. The old igniter builds up resistance and doesn't let the correct voltage through to the oven valve for it to open properly.
Tom
Aug 16, 2010 | Magic Chef CGR3725 Gas Kitchen Range
Mad gas flame at back of New World G70M
HI it could be agas pressure problem meter pressure too high get the gas company to check it out for you
Feb 04, 2010 | New World G70m Gas Double Oven
My g70m oven ignites and stays lit but it won't heat up it stays the same all the time
Hi
You have one of these faults:
Faulty FSD (Flame Safeguard Device). When you turn your oven on the FSD lets a small amount of gas through, after about 30-90 seconds the FSD is satisfied and allows more gas to come through......this then moves over to the.......
Oven Thermostat, this will sense the heat from the oven and adjust the temperature accordingly.
If the flame doesn't go high after 60 seconds it's the FSD, if it does but then it goes low and fails to increase then it's the Thermostat.
Either way you need to get a qualified gas engineer to look at it.
I hope this helps
Steve :)
Apr 05, 2009 | New World G70m Gas Double Oven
Gas oven
Nov 30, 2008 | Rangemaster 110 (Gas) Kitchen Range
Pressure of flames in Cannon gas oven
HI thanks for your question. the part that's at fault, is the igniter. it glows but not hot enough to ignite all the gas. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | Ovens
My gas oven flame
BLOCKED JET MAYBE CAUSED BY FOOD SPILLAGE OR BLOCK IN PIPE TO JET
May 28, 2007 | Parkinson Cowan SG320 Gas Kitchen Range
Kitchen Ranges Logo
63 people viewed this question
Top New World Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
John Rodgers
John Rodgers
Are you a New World Kitchen Range Expert? Answer questions, earn points and help others
