Question about Canon Imagerunner 5055 Digital Copier
Canonir5055 paper jamed then all paper reemoved but not ready machine again open front door remove paper indication coming.but machine off then on machine ready.i went jam code.B000 no sensarpls help
SOURCE: Canon MP830 paper jam
Your "Best Solution" posted 10/01/07 needs just a little bit more. I followed the directions and saw the jammed paper but couldn't get hold of it. I then called Canon support and they told me that the green plastic can be pulled up and then the paper under it is accessible. I pulled up the green plastic and was able to grab the jammed paper and pull it out. He also told me that the solution could be found in the Canon knowledgebase with a color picture as well.
Posted on Feb 04, 2008
SOURCE: Paper Jam
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
  • 70 Answers
SOURCE: paper jammed .....but no paper jammed
Sounds like this is a common problem with these printers. Hopefully, this is a malfunction of the printer that you can remedy.
I'm assuming that you have THOROUGHLY searched the printer for any evidence of paper and/or debris. Have you tried resetting the printer? If this issue is as simple as just needing to clear the error from the printer then a reset should work. (If you still have the manual, it should provide instructions on resetting the printer.) This is the best that I can provide on how to reset it:
  1. Turn the printer off.
  2. Hold the Resume button (red circle in the triangle), add a printer (click Power) an indicator light green.
  3. Hold the Power button and release the Resume button.
  4. NOT releasing the Power button, double click Resume and release BOTH BUTTONS (Power and Resume).
  5. Click Resume four times.
  6. Click Power to confirm the selected action (reset counter absorber). Click Power again to disable the printer.
Please rate this solution or let me know if this was any help.
Posted on Mar 27, 2009
canontech
  • 1219 Answers
SOURCE: paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Posted on Jan 12, 2010
  • 1739 Answers
SOURCE: my Canon Pixma MP600R insists that paper is jamed
The simplest thing would be to try unplugging the printer from the power source. Let it rest for 5 - 10 minutes then plug back in to the power supply and see if that resolves the problem.
If not you are going to need to do a thorugh inspection to verify that all paper remnants have been removed.
The following is for the MP600:
Issue: ERROR LCD: The paper is jammed. Clear the paper and press [OK].
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Trust this is helpful.
Posted on Dec 10, 2010
Error code c0200 minolta EP 4000
Sir, right below the drum area when you open the machine front door is a assy. with two very fragile gold plated wires that transfer the image from the drum to the paper. The paper moves over this wires during the copy process. They mite have broken giving you a C0200. Or the same type of wires are above the drum on the drum unit which must be removed to see them mite be bad. did you open close the front door to see if the machine will reset?
Jun 25, 2014 | Minolta EP4000/5000 CS/PRO Copier
The printer is saying that paper was misfed and it says that procedure for clearing misfed paper is shown inside the front door : C and A
First you have to open all the doors see their are two papers are get jamed in side, one paper at C section that meens in fuser module and another one in lower papaer tray section you can find the nob of C when you open the front door please rotate that the C jamed papaer comes out and other one open lower right door op tray-2 and tray-3&4, you can see the Ajamed paper remove that and close all the doors if problem exists call expert-thankyou
Dec 15, 2010 | Ricoh Aficio 2035 Copier
A single sheet of paper has jamed, can not release it.
Clearing a paper jam
If the paper jams in the printer, follow the steps below to clear the jam:
Remove the paper stack from both paper trays.
Press the POWER button. Instead of turning off, the printer will try to eject the jammed sheet.
If the printer cannot eject the paper, unplug the power cord from the back of the printer.
NOTE: Do not press the POWER button again before unplugging the power cord.
Open the rear access door at the back of the printer. To do this, press the handle to the right and then pull out the door.
Remove the jammed paper. Make sure no small pieces or obstructions remain.
Reattach the rear access door and plug the power cord back into the printer.
The printer will turn on automatically and be ready for printing again.
Reload the paper in the IN tray.
Try printing again.
Nov 25, 2010 | HP LaserJet 1010 Printer
I have a paper jam and it says to open the front cover, put the front cover just shows the ink cartridges and there is no visible paper jam. how do i find the jam and remove it? It's a canon image...
The paper jam could be in three places.
First:
Open the cover of fixing section, its above bypass, and check for jamed paper
Second:
Open the transfer cover, these cover has handle and it goes by pulling toward you, and check for jamed paper.
Third:
In hight of first paper cassette, on left sideway of copier, beaneath the bypass are small door, open it and check for paper jams. Be sure that you closed them properly because if they arent closed the check printer cover message will arrise.
Hope that helped
Jul 07, 2010 | Canon ImageRunner 1600 Copier
Paper jamed
Hi
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
PAPER JEM WHILE PRINTING. I NEED A HEIP TO REPAIR THE PRINTER.
first, if thare any paper is jamed in the paper tray, pull the paper stright out. take out the remaining paper. close the paper tray.
opne the front cover pull out the toner cartirdge, remove the jamed paper.
open the inner door (where the paper exit). make sure there is not paper jamed it.
close the front door. if any paper jamed inside of the machine, it should automatically eject it out.
Note: reset the printer by opening and closing the front door.
Apr 03, 2009 | Samsung ML-2510 Laser Printer
KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Apr 02, 2009 | Konica Minolta Office Equipment & Supplies
PAPER JAM
open the front door and remove inkl cartridge then check thr is not any paper jam .thn refix the inkmcartridge.
Mar 12, 2009 | HP Deskjet 450 wbt Printer
Paper
then you have some buried deep inside..turn light off in office, close door, and use a flashlight or penlight..paper will glow from light..that will help a bit..then long tweezers to extract the fragments, eh?
http://tinyurl.com/6qcpgy
Aug 15, 2008 | Brother HL-2040 Laser Printer
Panasonic printer dp4520 error code j40
This indicates there is a paper in the fuser area(very Hot section be cautious).1. open the front door.2, open the left side door. look inside for a green plastic handle & lift up he metal guide plate sometimes the paper gets wrapped around the upper heat roller or curled up and around the separator claws. if so be very careful not to scratch the rollers or break the sep claws. there is a green handle/knob located in the machine that can be turned, this turns the fuser rollers and makes it a little easier to remove a fuser paper jam. After you remove the paper jam close all the doors/panels you first opened. the copier should reset itself. I have seen the pj errors change to a new one indicating another pj still exists. if so look again and remove as indicate by the Lcd screen. Please leave positive feedback if this helps
Jun 07, 2008 | Office Equipment & Supplies
Canon Imagerunner 5055 Digital Copier Logo
24 people viewed this question
old marine
old marine
