Question about Xerox Phaser 3300MFPX - 30 PPM Multifunction Network Duplex Monochrome Laser Printer, 3300 MFPX, 3300-MFPX, 3300MFP/X, 3300/MFPX
Paper main.c 126 9. what is the fail? - Xerox Phaser 3300MFPX - 30 PPM Multifunction Network Duplex Monochrome Laser Printer, 3300 MFPX, 3300-MFPX, 3300MFP/X, 3300/MFPX
  • JMJr May 21, 2015
    What is the whole error code you are getting?
Cannot get the top part of my double oven to heat nor broil. The oven model is JKP26GOP2BG GE appliance. I have check voltage going to the oven and it 240 VAC and ohm the elements and they checked fine. ...
the thermal control has failed
http://applianceguru.com/forum1/18946.html
check here
perhaps as you get 126vAC ?? strange its half the supply volts
perhaps a missing something
i think your elements are in series or a missing nutral ???
each will measure 126 this way
you can atleast check the sensors resistance
mesure from nutral at the mains to each element point
did you disconnect the elements then test there resistance
even getting 126v they will heat .. half up....
so something isnt right
hope i can help
Dec 09, 2014 | GE Ovens
1989 cheverolet s 10 pick up 4.3 litre v-6, failed smog hc too high
About the only thing you can do is take it to a qualified DEQ specialist and have them take a look at it. It might be something as simple as a hose, or not.
Nov 28, 2013 | Chevrolet S 10 Cars & Trucks
126 is 84% of what
126/X=84%. But 84%=0.84. Thus X=126/0.84=150.
Check 150*0.84 =126
Sep 30, 2010 | Casio fx-300ES Calculator
Delta 15-126 Drill Press. Does not turn on when switch is pushed, fuse is good, motor runs when removed and plugged in directly. Any suggestions as to what part is failing?
replace the switch with an generic room wall box with a 125 volt switch instead. they work great and easily replaced when needed
Mar 02, 2010 | Delta 15 - 126 Drill Presses
Load paper light stays on
load paper, if paper loaded and light stays on then the sensor that the paper trips is bad or the sensor arm is broken or the main board is broken...
try reseting the machine and failing that taking it apart and finding the sensor thats bad...
Dec 07, 2009 | Office Equipment & Supplies
Printer wont print color anymore
I dont mean to insult you by replying with the simplist answer first, I am making asumptions from your question. The most likely cause of the problem is the protective cover on the ink cartridge did not come off completely before instalation. Have a look at page 126 in the user manual (link at bottom of page)
http://h10032.www1.hp.com/ctg/Manual/c01153752.pdf
Sep 21, 2009 | HP PhotoSmart C4385 All-in-One Printer
All LED blinking
try to reset the printer:
- Machine off
- Front cover OPEN
- Switch on the machine while holding down the “GO” button
- Check that the TONER/DRUM/PAPER leds are lighted
- Release the “GO” button and check that all the leds are off
- Press the “GO” button 2 times
- Close the FRONTCOVER
In case of all the leds are flashing on/off, that means the printer hardware fails somewhere. To find out what section fails, you can press down the “go” button and a led will go on.
Toner >> FUSER FAIL
Drum >> LASER UNIT FAIL
Toner + Paper >> MAIN MOTOR FAIL
Paper >> MAIN CONTROLLER BOARD FAIL
If you cannot determine wich led goes on,it seems that the main board is broken.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 07, 2009 | Brother HL-2040 Laser Printer
Identify Bulkhead Plug
here is the link for the manual if you need it; http://www.garmin.com/manuals/82_OwnersManual.pdf page 59 has a wiring diagram which i guess you may have seen check this link - http://www.ltw-tech.com/c.php?idc=1&cs=&ms=&cb=&as=&task=part these guys seem to have the right ones Hope this helps :)
Mar 15, 2007 | Garmin GPS 126 GPS Receiver
Xerox Phaser 3300MFPX - 30 PPM Multifunction Network Duplex Monochrome Laser Printer, 3300 MFPX, 3300-MFPX, 3300MFP/X, 3300/MFPX Logo
75 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
