Question about American Gardener Get the lower price on YS24 YardStick 10-Inch 24-
I NEED A SPOOL COVER WHERE CAN I GET IT ? - American Gardener Get the lower price on YS24 YardStick 10-Inch 24-
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
How to make a spool cap cover for an American Gardener YS24 (Weedeater XLT24) Trimmer
If you've tried to buy parts lately for your trimmer, you've noticed they are harder and harder to find. In fact, I was unable to find a spool cap cover, so I came up with this work-around.
Before you start this project, it's important to save any parts from the old spool cover-especially the top, if you can. The top is needed to make a spacer for the new cover that will still allow you to "bump" out the string.
I used a Craftsman 71-64215 replacement spool retainer to make my new spool cover cap. It fits the Craftsman C3 19.2 volt 74381 String Trimmer (CRAC06540 spool cap). I found this cap at a local Ace Hardware, but apparently it is also getting hard to find-I googled the Ace Hardware number to find it on the web-"7314644 cap." I bought a couple extra from HardwareDistributors.com. Note that the diameter of the cover at the tabs is the same diameter of the old cover-although the diameter of the cap is slightly larger.
Take the old cover, and using the tab from the old cover, mark a line on the new tabs the same width as the old. Make sure you center the old tab on the new tab so you will remove the same amount of plastic from each side of the new tab. I used a dremel tool with the cutoff wheels to cut the tabs on the new cap to the same size as the old cap.
If you look at the new cap, there is a round plastic circle ridge on the bottom of the cap. If you look closely you can see a slight indention, or discoloration on the top of the new cap matching the circle on the bottom. You need to cut the plastic out of the new cap matching the plastic circle. I used a dremel tool with a metal cylindrical grinder to do that.
Once you get everything cut, put the old cap into the new cap so that the spokes face down toward the similar spokes on the top of the spool. You may have to trim the old cap so it fits into the new cap.
Finally, snap everything together into your trimmer-don't forget the spring. Note that the new cap has about a 1/8 inch gap above the spool. However, this doesn't seem to affect the trimmer-and you can still "bump" the head to eject the string.
Posted on Jul 10, 2015
How do I remove spool holder from drive shaft?
Depends on make and model. Most electric strimmers have a removeable cover over the spool. This cover has 2 pressable tabs that releases the cover that then lifts off exposing the spool. Some spolls are clipped into this cover, others sit on the drive shaft from the motor. In both cass the spool should lift off / out. Make a note of the direction that the cutting line is wrapped around the spool so that you can re wrap it correctly with new line. Hope this helps
Sep 15, 2016 | Garden
Rope broke
Starter rope is sold at home centers like Lowes and Homedepot. It is important to buy the same thickness of rope so that an ample amount will fit into rewind spool(starter rope is sold by size from 3.5 to 6.5) . Remove the starter cover /fan cover if the starter is riveted to fan cover (or just remove the pull rewind if bolted on). With cover removed, notice how the rope enters thru bushing and ties onto spool. Visualize in which direction the spool turns when you pull the rope. This is the direction that you will be winding the spool. Fish out the old rope and wind the spool in the direction mentioned above. The spool will get tighter as you wind. When the spool will not wind another turn, back-off one turn and align hole in spool to bushing on cover. Insert rope thru bushing into hole and tie knot (any knot that will not obstruct motor parts). At this point allow the rewind to take-in the rope to stop at handle. Test your work. The rope will break if you try to start the washer under load. Press trigger on wand to release pressure. Also the rope is stressed when the operator has a very long strong arm and pulls out the rope to bottom out at the knot. Good luck with your repair
Aug 04, 2011 | Briggs & Stratton 3000 PSI Pressure Washer
I have a honda generator but i change the cordon starter and now i dont now how ensable it, i need a diagrama of this
What you need to do is first remove the new cord that you installed.
(This next process is best performed by 2 people)
Pre-wind the spool gently COUNTER CLOCKWISE until the spring prevents further winding. Have the 2nd person grip the spool so that it does ot unwind. Back off the spool until the re-wind rope hole is aligned with the outer cover rope guide. Insert the new rope through the outer cover rope guide hole and into the spool hole. Pull the new rope through the spool hole and tie a single small knot. Pull the knot into the hole. 2nd person releases the spool and the rope will rewind into the re-coil assy.
Aug 04, 2010 | Honda 3000 Watt Portable Generator
I have a 1200w ust portable generator and when I went to start it the cord it the cord snapped. What tools do I need and how do I replace it?
You do not need any special tools but you do need a third hand somtimes to complete the job.
Here are the basic steps after you remove the starter from the engine:
Prepair the new starter rope by burning the end to keeping it from fraying and shape it into a point. Use a rag to shape the point because it will be very hot. (about 5 feet of good qualty starter rope size to match existing. It is sold in sizes form about 3.5 to 6.5) Tie a temp knot on the other end of the new rope. Remove the old rope and align the hole in the spool with the hole on the starter cover and practice incerting the rope thru the guide hole on the cover into hole on the spool . This will be the final action after you wind the spool. You should be able to hold the spool and insert the rope thru both holes and tie a knot while holding the spool in a wound state. Once you have mastered incerting the rope thru both holes and tying a knot you are ready to begin.
Wind the spool in the same direction that the spool turns when you pull the rope. You must wind in the correct direction or you may bend the rewind spring out of shape. The spool will begin to tighten as you wind and will eventually stop turning when the spring is fully wound. Once fully wound unwind spool one full turn and stop when hole on spool aligns with hole in cover. Now insert rope as practiced thru both holes and tie knot with free hand or have helping hand. Once knot is tied slowly let spool take rope in untill no more will go in or you reach temp knot. Now tie pull handle and you are done. Good luck
Jul 29, 2010 | Briggs and Stratton 073001 2" Portable Gas...
The string on my spool ran out.
• Turn off the trimmer and remove the battery
• Press the release tabs on the line spool cover and remove the cover by pulling it straight off. replacement spool is AF-100
• Lift the spool of nylon line out of the hub and clear any broken line and debris
• In case of jams and tangled line unwrap about one foot (30cm) of line to ensure that it is undamaged. If it is OK rewind it and insert the line end through the eyelet in the spool hub.
• Pull the line through the hole to maintain tension while placing the
spool down into the hub with the notched side exposed.
• Press the spool down GENTLY and rotate it until you feel it drop into place. (When in place, the spool will turn a few degrees left and right freely.)
• Snap the spool cover back on.
Jul 06, 2010 | Black & Decker String Trimmer Cordless 12"...
How to wind a pull rope
Thread the rope into the spool and knot the end, pull a 6 to 8 inch bit of slack from between the spool and the outer cover and let the rope set into the small indentation on the outside of the spool. Rotate the spool with rope attached and sitting in the notch in the opposite direction of recoil until sufficient tension is achieved, pull slack back through feed hole in cover and allow the spool to draw the rope into the spool, now attach the handle.
the notch in the spool is there to allow you to spin the spool without twisting the rope or having it bind on the cover.
Jun 14, 2010 | Honda 25cc 4-cycle Mini Tiller
Refill line on spool of toro electric model 910
Onve you remove the cover the spool should pull straight out. Be careful, there's a spring under the spool that can fly out and get lost. You need that spring to re-assemble.
Apr 11, 2010 | Toro& Electric String Trimmer
Renew pull start cord
Go to smalleng.com they have video on how to do what you need. Check it out awesome website!
Nov 24, 2009 | Husqvarna Partner Gas Powered Cut Off Saw...
I need directions to replace string on black and decker cordless 18v grasshog
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
Replace pullcord on troy built mower
Replacing the rope is not difficult but tricky. I believe that your model has a fuel tank on top of starter cover, empty fuel and remove tank to expose starter cover. Remove the starter cover and place it on your workbench with the plastic rewind spool visible and remove the old rope noting how it was tied. The rope is sold in various sizes from # 3 to # 6.5. Most mowers use a #4.5, with length of about 6 to 7 feet. You may not need this much but more is better. Now practice inserting the rope thru the hole where it comes out of the cover into the hole where it ties on the spool. Once you can do this you are ready to wind. The spool /spring winds when you pull the rope, that why it recoils when you let go of the rope. With that in mind, turn (wind) the spool in the same direction that it turns when you pull the rope. It should be getting tighter as you turn. Keep winding in the direction that it turns when you pull the rope untill it will not go anymore. It should be very tight. Now unwind one complete turn and align the hole of the spool to the hole in the housing and hold it there while you insert the rope from outside hole into the spool and tie knot. After the knot is tied slowly let rope rewind into the spool untill it stops on its own. You are done. You should have plenty of extra rope left to extend out to the handlebar. Enjoy
Jan 10, 2009 | Garden
American Gardener Get the lower price on YS24 YardStick 10-Inch 24- Logo
164 people viewed this question
Top American Gardener Garden Experts
Dennis Key
Dennis Key
john h
Are you an American Gardener Garden Expert? Answer questions, earn points and help others
