Question about Frigidaire Freezers
How do I replace the door light switch? - Frigidaire Freezers
  • Frigidaire Master
  • 744 Answers
Hello Deborah;
My name is Peter. I am a retired field service refrigeration technician.
Have you replaced the bulb with a special bulb for refrigerators, not a house hold bulb?
Have you up plugged your refrigerator or cut power at the circuit breaker, then remove the bulb and check to see it the contact at the bottom of the socket is not depressed so far that the bulb can not make contact?
Ok, Then:
The light bulb and the door switch are a direct single circuit.
Un plug your refrigerator or turn power off at the circuit breaker.
The switch is flush against the liner wall. They pop in and out. With a small flat head screw driver work your way around the switch until you pop it out. Disconnect the two contacts. BE CAREFUL THE CONTACTS HAVE SHORT LEADS AND MAY FALL BACK INSIDE THE LINER WALL. Hold onto the leads after disconnecting. Connect the new door switch and pop into the liner wall.
You might as well go ahead and purchase the door switch first. This is your problem.
Go into the following website. Put in your model number. Diagrams will appear. Select the diagram with the door switch. It will give you the part number and cost of the switch. Your model number is located in your fresh food section on a label on the upper side of the liner.
Water Filters Lawn Garden Appliance Parts
Posted on May 02, 2015
  • Official Brand Answer
  • 2,267 Answers
I appreciate your post, Deborah!
From what you have described you need to replace the door light switch on your Frigidaire freezer. In order to assist you further I would need your model number. You can locate your serial tag (which lists your model number) on the inside wall of your freezer. I look forward to assisting you. -Matt
Posted on Apr 30, 2015
Light flickers when door is opened
it has connection problems when you open the door of freezer connecting wire turn gradually and one time comes up light normally,you repair connecting wire of lights.
Mar 23, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The door light in wine fridge will not turn off when the door is fully closed..
There is a switch for the light. If it isn't a mechanical switch where the drawers slide in, it will be a magnetic switch in the edge of the drawer
Dec 27, 2012 | Haier Aficionado 26 Bottle Wood Trim...
Door light blinks but never comes all the way on. changed the light still does the same thing
Hello....sounds to me like you have a problem the momentary contact switch that is activated by opening the door..and deactivated by closing the door...I'm not sure how east it will be to find a replacement switch...If you still have the manual...you can check there..or maybe go online..or have a service call to replace the switch...If you have problems...let me know the make and model of the fridge and I will see if I can help you....I hope this was helpful......PEACE....
Feb 07, 2012 | Freezers
Alarm on door keeps peeping red light on and says door ajar
The door switch which senses when the door is ajar needs to be replaced or cleaned. See if you can make the alarm go off by pushing the switch in as far as it will go or take the switch out and by pass it by taping the wires together. There's a sensor switch for each door so try each one separately.
Feb 12, 2011 | Frigidaire Freezers
The "door ajar" alarm keeps going off and the door is sealed shut?
Your door switch may be bad. Is the light on when you open the door when you manually push in on the switch does the light go off? On most fzr the door ajar alarm is set off by the door switch showing the door is open.Turn off the power by unplugging the fzr then you can pop the switch out with a flat blade screw driver if it is only a two wire you can use a paper clip to connect the two wires wrap them with elect tape Then plug the freezer back in and see if the problem clears if it does order a door switch. Some units use a vacume sensor but i believe all kenmores use the door switch. good luck
Aug 17, 2010 | Kenmore Freezers
Refrigerator inside light will not go out when door closes
This can be due to one of two things, either the door is not hitting the light switch when it closes or the light switch is bad.
Locate the switch, it is usually on the top of the cabinet inside the refrigerator, push the switch, if the light does not go out then the switch is bad, if the light goes out the door needs adjusted so it will hit the switch when it closes. Typically this can be done by loosening the hinges and holding the door in place while someone tightens the hinges back up.
May 08, 2010 | Kenmore Freezers
The ligt stays on with the door closed but not at the full level only dimly.
The door switch that is pushed when you close the door is probably not being pushed far enough. Push it all the way with your finger and see if the light goes off. You may can clean the switch or just replace it.
Jan 07, 2010 | Siemens Freezers
Trips breaker when door opens
Sounds like the switch or wiring around the switch is shorting out. Most light switches pop out with a screw driver.Some older units might have a small heater in the door around the seal but usually not See if there is any wiring going through the hinge pin. If so you can safely cut and tape this off. The door might sweat a little but this is a solution. Please deal with this as it could be a shock hazard. You might not notice if you touch and are wearing dry shoes, but a barefoot child could be killed.
Jun 27, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
258 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
