Question about Garden
I replaced the drive belt I know it is on right, But now it will not move in 2nd gear and up, Only 1st, And to make it goes faster you have to press in on the break and clutch
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 57 Answers
Not knowing the model of the tractor makes this a little tough so here is a more generic response. Are you absolutely sure you have the right belt? I've occasionally gotten a slightly different belt (like when trying out kevlar or when matching up by length and not getting the width quite right). I would roll the machine up on blocks, have someone help you in the driver's seat and crawl under to see what it's doing (engine off is a good idea). Grab the belt and feel for slack all the way through the clutch travel and see if you can tell why a slightly depressed clutch might give more tension. Also (and this did happen to me once with a looser belt) look to see if the idler on the clutch arm is moving too far and binding the back of the belt into something else there.
Posted on Apr 27, 2015
Why doesnt my MTD 42" lawn tractor move but it will start?
If the transmission is belt drive, check the belt, worn/oily? If you have a hydrastat tranny, make sure that the bypass plunger is pushed in. Check that the belt goes around the tranny pulley. If still no luck, turn mower off, jack up and support the rear frame, with the real wheels hanging in the air(just an inch or two is plenty) try turning the wheels -1st, with the gear selector in "N". then 2nd, with the gear selector in "D". This should narrow the problem down a bad tranny or a sheared keyway in the axle.
Jun 03, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
2007 Chevy Avalanche 3rd and 4th gear are not working
From what you are describing, it is possible either the 3-4 actuator is no longer playing with the 3rd & 4th clutch packs, only way to know for certain is to hook up the good ol' pressure gauge to trans. system, yeah, you think the Chevrolet dealer should know this right?
Sell it now if you can!
Smiles
Mar 02, 2014 | 2007 Chevrolet Avalanche
700r4 transmisson vibration in 1st and 2nd gears
this is probably a bad u-joint(s) crawl under the truck engine off and in park and on a flat spot, twist the drive shaft if it clunks at all or has some up down or left right slop the joints are shot and will need replacing. And yes the u-joints will cause a drive line vibration that seems like a transmission issue it goes away with speed as the shaft will spin fast enough the vibration will become only a hum.
Jan 02, 2014 | 1991 GMC C1500
Chevy cavalier gear shifter
if it is s manual box remove the gear lever tower from the top of the box and see what damage was done to the bottom of lever and/or lever pivot pin in the tower. Remember normal gear boxes require a gentle shift to allow the syncro rings to work properly and if you want to do racing changes get yourself a specially built box.
Jan 02, 2014 | Cars & Trucks
I own a 2007 Harly Davidson Street Glide with the motor running n I am in 1st or 2nd gear I let off the gass I get a noise n when I engage the clutch the noise goes away
I'm not sure what you mean by "engage the clutch". If you mean when you pull the clutch lever, the noise goes away, I'd check the tension on my final drive belt. If the belt is loose, when the engine tries to slow the motorcycle down, the final drive belt tries to rise up off of the front belt pulley making it rub the underside of the starter to inner primary housing. When you pull the clutch lever in, you disengage the engine from the transmission and the engine breaking force is removed from the front pulley and the belt goes back down on the pulley.
Good Luck
Steve
Feb 21, 2011 | 2008 Harley Davidson FLHX Street Glide
Ariens SnowBlower I recently blew a belt on my Ariens 5.5 hp snowblower Mdl# 932140 I replaced it and it blows snow and when i put it in 1st gear the machine goes into reverse. All my other gears work...
Hi dwva, I think you have the belt on properly seeing the other gears work fine. The difference between 1st and reverse can be as little as 1 half in on the drive wheel. It depends on which side of center is the friction wheel riding. Remove bottom pan with the machine in 2nd or 3rd gear notice which side of center is the friction wheel riding. (the friction wheel is the one with a rubber outer ring). Now put it in 1st, is it on the same side of center? There is an adjustment on that linkage, adjust so in 1st is on the same side of center. Happy New Year, hope that helps.
Dec 29, 2010 | Garden
My fzr 1000 is leaking gearbox fluid by the looks of it ,i start it up and when i put it in 1st gear it cuts out before i even let the clutch out. but if i put it in 2nd gear it doesnt cut out,, is this...
that's a bad neutral safety switch...it's a shop repair...now, the reason it goes bad:
the 1st gear is for getting the bike moving, period...you "never" wind out in 1st gear...ever...high rpm and going from 1st to 2nd is very bad for a transmission...think about how much movement is happening to go from the bottom, past neutral, to 2nd gear...that's where most trans damage occurs...once you start moving, go to 2nd, then rev it out... remember...1st gear is for getting moving only...
Apr 18, 2010 | Yamaha FZR 1000 Motorcycles
Squeak in low gear.
Try spraying the belt with a "dressing" spray. With the engine not running of course. If it stops, then your belts may need adjustment or replacement.
Feb 06, 2010 | 2007 Mazda MAZDA6
Will only drive forward in 1st gear, 2nd gear and
It is propably the gear box. Take the seat off and you will see the gears inside. Mine works only in 2nd and not the 1st or reverse. But I know it is the gear box since my husband replaced the 1st one a while agao. Just need to find the web site for the repacement part. Only cost us about $30 to fix last time. Hope this helps.
Jun 28, 2009 | National Little Tikes Hummer Yellow
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
