Question about Body Sculpture Bc1510 Exercise Bike
I cant seem to get the timer to do anything on my excercise bike
It has a battery in it it dont seem to do anything when i pedal it
  • 6 Answers
The display (timer) needs to be connected to a sensor on the bike.
Make sure the display is plugged into a cable coming out of the bike.
If it's plugged in and still doesn't work, then contact the manufacturer.
It could be,
1. a bad display. (possibly a broken PCB connection)
2. a bad sensor inside of the bike. They typically use a Reed switch.
3. a broken connection in the cable or connector
4. the magnet fell out of its location.
You can get a replacement monitor from the manufacturer. If this doesn't solve the problem then it's either the sensor or the connection.
You can also place a continuity tester across the 2 contacts of the connector that plugs into the display. The continuity tester should flash when you pedal the bike.
Here's a link where you can purchase a continuity tester.
http://www.amazon.com/Extech-ET40-HD-Continuity-Tester/dp/B0025PK724
You can also pickup a continuity tester at any auto parts store.
Posted on May 13, 2015
My Schwinn doesnt gain speed
axel bearing either is bad or needs grease or not adjusted correctly
Oct 08, 2012 | Schwinn 700c Mens DSB Dual Sport Bike
Can you confirm what Reebok Edge excercise bike fault code E1 what this means as I have lost manual.
Same problem here! means that the motor is not sending a signal to the computer!? But that as far as ive got....................
Jan 11, 2011 | Reebok New York Giants Eli Manning Jersey
Its been 23 years since i rode a bike.im on a new excercise phase of life, so i brought a cannondale 900 series. how and when ,do i change gears to get the most benefit out of them.i was strickly bmx as a...
1st:
http://www.cannondale.com/deu/deu/Instructions
2nd:
as you drive ,you will KNOW when to shift,Anytime it gets to quick to pedal fast enuff>shift UP....when going up grades,shift to lower gears(but don't wait till your crawling)
Mar 28, 2010 | Cycling
Vitamaster excercise bike makes clunking noise when in use,
The moving parts like chain sprocket,etc where the friction is lkely to be created is the exact place you have to oil. Dont apply more oil than needed. Avoid oil to parts like brake shoe,etc where friction is neccessary for those parts to work properly.
Aug 19, 2009 | Cycling
Pd -m424 cant get pedals off bike? do i need to use allen key as well as spanner
No, you do not need to use both. In fact, you should never use a spanner wrench to remove your pedals or anything requiring large amounts of torque. For removing your pedals you should be using an pedal wrench or if the pedals are not very tight the allen wrench. A basic pedal wrench like the Park PW-5 is inexpensive and does a great job. Also remember that the non-drive side(left) is reverse threads, meaning both sides come off by unthreading to the rear of the bike.
Hope this helps. Thank you
Jul 15, 2009 | Shimano M324 Clipless Spd Platform Pedals
I have low fluid but i dont know what to put in it...its on the left side of the bike
(1) Place an add in your local paper and sell your bike. (2) Buy a three speed pedal bike.
Jun 13, 2009 | Suzuki GSX-R 750 Motorcycles
DP Air Gometer Exercise Machine manual
When excercising faster it seems to make a lound clicking noise.Dose not happen when going slow.HELP
Apr 04, 2009 | Cycling
Body Sculpture Bc1510 Exercise Bike Logo
536 people viewed this question
Top Body Sculpture Exercise & Fitness Experts
Electro Med Services...
John
ray gallant
Are you a Body Sculpture Exercise and Fitnes Expert? Answer questions, earn points and help others
