Question about Santa Fe 2010 Hyundai Owners Manual, Hyundia Owners Manual - Used Like New
I CHANGED FILTERS AND PUMP BUT STILL GETTING CODE P1186
    Top Expert:
  • Santa Fe Master
  • 10,875 Answers
Fuel pressure too low,did you reset the light?? if not,you need to,if so,you have a blockage,check the fuel rail, and lines,also,is the fuel filter on the right way?
Posted on Apr 27, 2015
I changed the filter and noticed that there was little to no pressure in filter. usually high pressure air released before I unscrew.
makes sure pump basket is full of water check pump top seal and check seal to filter make sure filters in correctly and returns are open
May 23, 2016 | Pool & Spa
What parts do you recommend for a fault on my Hyundai Tucson which has developed faults?
uh oh, 1186 and 0087 are both related... fuel pump or the filter or both! either case the filter is now located inside the fuel tank
P1186 Hyundai Fuel Pressure Too Low
P0087 Fuel Rail System Pressure Too Low
"Potential causes of a P0087 trouble code may include: Weak fuel pump, clogged filter or screen, restricted fuel supply line Faulty fuel pump driver module Faulty fuel pressure sensor"
How to Change the Fuel Filter on Hyundai Tucson eHow
according to eHow, you can access the filter relatively easily. (although the pic is an illustration of something not really related to this ~ why they showing a fuel petcock that's not even on your car?)
P2112 Throttle Actuator Control System Stuck Closed
"Possible causes:
- Throttle Body Plate Binding
- Faulty Throttle Actuator
- Throttle Actuator harness is open or shorted
- Throttle Actuator circuit poor electrical connection"
older models we had the gas pedal attached to a cable to move the butterfly valve on the throttle body. Now it's this newer drive-by-wire stuff... remove air intake hose and check / clean / move the throttle body valve by hand first to see if it's binding or not
then, go from there on testing the actuator and tps
Apr 17, 2015 | 2006 Hyundai Tucson
No fuel pump power
More information please. Year make model of your vehicle.
Sep 07, 2014 | Chevrolet 1997 Chevrolet Astro Cargo Van
Error code p1186 2007 hyundai santa fe diesel need more information on low fuel pressure
there have three factors may be cause the problem,
1.The filter is a source for low fuel pressure, because it is stoped up or is cloged.
2. The fuel pressure regulator is another.
3. The pump itself.
Tech 2 software
Jul 18, 2012 | 2009 BMW 3 Series
Hyundai verna diesel fault code P1186 fuel pressure too low whats problem
Dear sir , Hyundai verna fault code p1186 we check found warring and couplers was ok and we replace injector and fuel rail problem was not resolved, cold starting engine vavrection and rpm stack and white smoke and hot conduction normal but rung conduction engine vavrection and missing no accelerator is working please suggest
Feb 25, 2012 | Cars & Trucks
KIA SORENTO CODE P 1186. Tubes are rotated OIL FILTER also NAFTS PUMP IS NEW. ISSUED WITH THE SAME PROBLEM
P1186
FTS Low - Fuel Pump Temperature Sensor Low
I do not know what to do about this. Most likely you will have to replace the fuel pump. Make sure you received the correct pump if you purchased and installed a new one. You might be able to reset the system by disconnecting the battery for a few minutes.
Dec 22, 2010 | 2005 Kia Sorento
P1186
OBD code p1186 - Low fuel suply! Maybe you have something in your fuel lines, or fuel filter, or your fuel pump doesnt work properly
Dec 06, 2010 | 2005 Kia Sorento
Car died. changed fuel pump and both filters. car will turn over but will not start. any help is appreciated.
Check for spark and fuel as a starting point. If you're getting fuel pressure at the rail, then the fuel pump and filters are not the problem.
Possible crankshaft sensor if the spark is not getting to the spark plugs in the 1992 Buick Century.
Aug 26, 2010 | 1992 Buick Century
Santa Fe 2010 Hyundai Owners Manual, Hyundia Owners Manual - Used Like New Logo
234 people viewed this question
Top Santa Fe Radio Communications Experts
eradiostore
eradiostore
Are you a Santa Fe Radio Communication Expert? Answer questions, earn points and help others
