Can I use a wireless mouse - Computers & Internet
  • 5,631 Answers
Yes, you can. Check batteries in mouse, plug in usb dongle and restart your computer.
Posted on May 12, 2015
    New Friend:
  • 7 Answers
Can you use a wired mouse? If so, the transition to wireless should be painless.
Of course, Change hurts!
How do yoou connect a wireless mouse to your computer
Connecting a wireless mouse to your computer is a great way to reduce clutter around your workplace.
Also, it is an alternative to using your laptop's directional pad.
Wireless mice work just as well as wired mice for most computing needs.
The only detail that wireless mice lack compared to wired mice is the DPI (dots per inch) and the frequency rate, which is essential to the "fast twitch" movements in gaming.
However, most people do not need highly responsive mice; therefore, wireless mice are perfect for any other computing activity other than gaming.
Insert batteries into your mouse.
If your mouse is rechargeable, charge it in the docking station provided with the mouse.
Buy a wireless adapter that works with your mouse. If your laptop is enabled with wireless technology or Bluetooth, skip to the next step.
Install the drivers for your mouse.
Reboot the computer to apply the changes.
Power on the mouse and let the computer recognize the new hardware. If you are using a mouse that requires software to run, enable the mouse in the software that is provided to you.
Hope this helps
Nov 04, 2012 | Computers & Internet
No mouse control via wireless mouse, or touch pad
IT SOUNDS LIKE YOU HAVE MAY HAVE DRIVERS OR IRQ THAT ARE CONFLICTING, TRY UNINSTALLING THE DRIVERS FOR YOUR WIRELESS MOUSE, AND REINSTALLING THEM, MAKE SURE THE WIRELESS MOUSE IS UNHOOKED BEFORE YOU REINSTALL THE DRIVERS.
Mar 11, 2010 | Toshiba Satellite Pro L300 Notebook
I have a Microsoft Wireless Desktop Receiver 3.1 unit which works both my keyboard and Wireless Laser Mouse 5000. My mouse is not working and I've changed the batteries 3 times. Can I buy a replacement...
I have the same system. Mouse can be ordered, but not easily. Make sure mouse is not working.... i almost made tour same mistake. In my case, the mouse plug (from computer to wireless receiver) had become unhooked. All i could see is that mouse was communicating with wireless receiver but appeared to be frozen. If you can reset receiving channel, and see that receiver acknowledges presence of mouse, you may have my same problem. Also, if you can see that the laser light is working, mouse is probably ok, and batteries are good.
Feb 15, 2010 | Microsoft Wireless Optical Mouse USB...
Wireless USB works, but mouse itself doesn't
Sir/Mam good day,
Is your mouse device also wireless? you need to resync it with it's receiver,
you may follow the methods below to make your wireless usb mouse works.
You need to press the button on your wireless mouse receiver, and make sure that the light on your wireless mouse
receiver blinks. But you need take note that some newer model of microsoft devices are permanently fixed to their receiver
and can't be reset. If your devices don't have a button, here's what to do:
If a dialog box appears on the screen in how many seconds, you need to follow the instructions from it. Or else, you need
to do this:
press and release the connect channel button on your wireless mouse, and make sure that the light from your receiver works
and the status on it's light is steady. If this happens then the synchronization is successfu. But if the problem is still
the same you need to repeat the previous steps once again.
As for the wireless mouse for notebook, this problem come out when the micro switch on the underneath of the mouse was not
released. You can use a pencil or anything with a sharp point to released it.
There are a lot of options why your wireless mouse receiver won't work, and a lot of solutions. Here's some of them:
*Try different ports on your computer, if the connection to some usb ports are not working you can connect to other ports
and see if it will work.
*And also the cables that are included with the wireless receiver, try to use another cables if the
device is still not working.
*If you're device is connected to a usb hub, disconnect it from the usb hub and directly connect it to
the available ports on your pc and see if it will work.
*When fixing this type of problem you need to have only one usb device
connected to your computer, which is in this case, your usb wireless mouse.
*When you have other usb devices, you need to
plug it out.
*If the methods mentioned previously still won't work, you need to reinsert your
wireless mouse batteries or install a new one.
*Another possible remedy to this problem is checking the interference, your wireless
usb mouse together with its receiver should be a distance away from anything that
transmits signals such as cellphones, radios or other similar devices. And also
any metal objects. because such things might interfere with the signal of your
wireless mouse.
* If the problem persists after doing all of the above steps, maybe it's time to update
your wireless mouse drivers, For installing latest driver update with your wireless
mouse, see the documentation that is included in your wireless mouse.
* If all of the methods above did not solve your wireless mouse problem. You can
connect your wireless mouse to another working computer to see whether the problem
lies with your wireless mouse or to the computer which your wireless mouse is
connected.
Final instruction:
If all of these methods fail, you better have your wireless usb mouse be check
by a professional computer technician in order not to further damage your device.
Hope this helps. Good luck and God bless
http://online-pcrepair.blogspot.com/
Jan 11, 2010 | Silver Jeans 1660-13SL Mouse
My wireless mouse 5000 is not responding yet the keyboard is. So, what is the problem?
Replace the batteries, look under the mouse you should see a removable cover, the batteries should be in there.
Dec 19, 2009 | Microsoft Wireless Laser Mouse 5000
My case logic optical mouse will not link up
Is this a wired or wireless mouse?
If this is a wired mouse, try connecting it into different USB port or different computer so that you would know if there's a problem with the USB ports or with the computer or with the mouse.
If this is wireless, try the following:
1. Replace the batteries of the mouse.
2. Make sure that the mouse is turned ON.
3. Try connecting the USB wireless adapter of the mouse into different USB ports.
4. Connect also the adapter into different computer.
5. Make sure that there's no interference between the adapter and the mouse such as wireless phones, cell phones and other wireless devices.
Wireless mouse, cordless phones and cellphones are all running at 2.4Ghz frequency, so if there's a wireless device that's running on the same wireless freq, then it would interfere with the mouse that would cause the mouse not to work.
If same problem occurs after checking everything, then contact the manufacturer of the mouse for RMA (repair).
Have a great day!
Sep 21, 2009 | Case Logic Computers & Internet
Can I use a new MS wireless mouse to replace my existing MS wireless mouse. Currently my mouse and keyboard connect together on the same wireless USB device. Could the new mouse be detected and be used...
I suppose there is a reset button on the keyboard or the software provided so I suppose it could be possible, I don't know.
I use a Microsoft Wired Keyboard...
But Best of luck.
Jul 21, 2009 | Microsoft Wireless Optical Desktop Pro +...
Explain wireless keyboard wireless mouse
You just plug the usb adapter for the wireless keyboard and mouse into the computer and run the install disk. Wireless just means that the device sends signals to the recieving devices.
Jun 16, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Wireless Mouse
I don't think the wenger swiss spyder wireless mouse is compatable with the Microsoft wireless receiver. I think you will have to use the spyder reciever for the mouse and the Microsoft receiver for the keyboard.
May 28, 2009 | Microsoft Wireless Desktop Elite...
Activating COT2 wireless mouse
Your ACME COT2 wireless mouse must have come in two pieces, the USB connector the mouse itself.
Insert the USB connector of your wireless mouse to your Toshiba Satellite and press simultaneously the button in your USB connector and the button in the wireless mouse. This is done in order to pair the mouse to the USB connector.
Jan 05, 2009 | Computers & Internet
Open Questions:
Get Data Recovery Backup Online Data Recovery Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Server Cloud Backup Solution their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Cloud Backup For Small Business companies with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in mind. To provide Online Backup Pricing optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
Jun 18, 2018 | VIA Computers & Internet
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
