Question about Mtd Garden
My blades slow down when I lower the deck - Mtd Garden
  • Mtd Master
  • 3,519 Answers
Hi Ert:
Is it possible that the belt is worn?
Check for any loose bolts that might allow the pulleys to move, letting the belt go slack.
Check the belt tension spring to make sure it is secure and in the right position.
Posted on Apr 27, 2015
What causes blades to stop in low setting?
Scott, sounds like belt or pulleys could be worn out, also see if your pulley tension spring is still on the tensioner pulley arm if your machine is equipped.
Apr 04, 2016 | Garden
Why is it that my riding Lawnmower doesn't cut when I lower the deck to cut the grass lower
Tighten or replace drive belt. Before you do that though, with the deck raised right up and engine switched off reach underneath deck and grab hold of blades and try to move them up and down. Make sure there is no build up of debris between pulleys and guards. Remove the belt off pulleys if you can. Turn blades and check they are free to turn. What you are doing here is checking the blade spindle bearings for wear or damage. If they have excessive movement or feel rough and/or tight replace them. If they are good and the belt looks in good order, tighten belt That is done by adjusting the deck rods so the deck moves back. You tube have some videos of belt adjustment.
Aug 22, 2014 | Garden
2000 craftman lawn tractor 917.270822 blades will not engage
If your blades won't engage when you raise the lever to engage them AND that lever moves freely without the normally expected resistance, then you've lost the cotter pin that connects the lever rod to the mower deck assembly. Very easy fix! Using the mower deck raise/lower lever, lower the mower deck to "down" position. Now, lay on your side along the right side of the mower and look up (use a flashlight) under the mower at the top of the mower deck while moving the blade engagement lever "up" (which pushes the connected rod down). At the end of the rod, you will see a hole where the mower deck and rod connect. Align the hole at the end of the rod with the matching "pin" on the mower deck (you'll see it) and insert a new cotter pin to secure them together. Use a nail if you don't have a cotter pin. Voila! you are done. The blade engagement lever will now engage/disengage your mower blades successfully. Just remember that mower deck must be down, or lowered, before you engage the blades!
Jun 22, 2012 | Garden
Blades turn slower when deck is lowered on cub cadet 1042
Had the same problem after winter storage and couldn't find an answer anywhere. I noticed that the drive belt (not the ribbed deck belt) was loose when the deck was down below 4 and tight when it was up higher.
That told me either belt is stretched beyond the belt tensioner's or the tensioner wasn't working right. Found that the tensioner was hard to move and would stick. Greased the zerk on top of the large bolt, worked it back and forth a number of times by pulling on the belt. Problem fixed. But I'm thinking it may be time to order a new tensioner spring and belt anyway. Hope this helps someone down the road. If so pass it on. :) jerseyjimmers@yahoo.com
Jun 16, 2012 | Garden
LA110, 42" mower deck, 1
Check that the cutting tip of the blade that is cutting lower is not bent down. Also park the mower on a level surface and lower the deck and check the gap under the front of the deck is even. If not, there are levelling adjustments on the top of one side of the deck. Regards Phil
Apr 15, 2011 | John Deere 195HP Hydrostatic 42" Cut...
Blades slow down when cutting deck is lowered.
the lowerer the deck the more your working the mower. either mow more often or reduce speed
Oct 22, 2009 | Garden
The blades will not go down
The blades are attached to the deck. If the deck moves , the blades move with it. They can't do otherwise...
Sep 11, 2009 | John Deere Garden
The engine run rough and backfires when deck is lowered with pto
It sounds like your blades may be restricted when you lower them. A possible solution for this problem would be to remove the mower deck and clean out all the dead grass buildup inside the housing.
May 23, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
316 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
