Question about Miele Washing Machines
Model #W1113 Serial #69358691
Water kept filling machine and we could not stop by turning machine off or electricity off had to turn main water off
    Genius:
  • Miele Master
  • 1,585 Answers
Inlet valve has stuck open replace about £10.00
Posted on Apr 27, 2015
My whirlpool cabrio7600 top load washer starts up filling with water an doesnt stop filling.
Hi.
If the water inlet is faulty the water flow will only stop if you turn the wall tap off...
If the fault is in the machine the inlet will stop when the machine or the electricity is turned off.
If the water flow stops when electricity is halted it indicates that the inlet is functioning properly. There are a number of things which can cause the inlet to not turn off, such as the water level sensor is faulty or blocked. It could even be that the motor controller is faulty.
Unless it is a simple inlet change I recommend that you let a technician look at your machine.
Good luck,
Nomess
Mar 03, 2015 | Whirlpool Washing Machines
W6444
make this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 25, 2013 | Washing Machines
Miele w1113. Washer drum won't spin during wash cycle
I assume you are saying the machine is working except the drums not turning? - you need to see if the belt has come off because thats what i would check first if you hear the motor start/stop after it fills up with water.
May 30, 2011 | Miele Touchtronic W1113 Washing Machine
First became aware there was a problem when machine overfilled resulting inj flooding,cold water fill would stop when i turned on a tap ,suspected water pessure switch.new water pressure switch fitted...
If it works O.K. in a different wash cycle, then the timer could well be the issue.
Using that last cycle you described, will it perform a complete normal cycle ???
Jan 05, 2010 | Washing Machines
Help! My fisher paykel washing machine won't stop filling up!
If the water continues to fill even if unplugged the water valve is sticking and needs replaced. if removing power turns the water off the water level pressure switch is bad or there is something plugging the sensor tube somewhere.
Eric
Nov 22, 2009 | Washing Machines
My washing machine wont stop filling with water
sounds like the hot cold water valve is bad,you also have the water level switch,the switch has a water level hose on it,some times the hose comes loose,chech y=that also,let me know what you find-mike
Mar 17, 2009 | Kenmore Washing Machines
Maytag Neptune MAH-1 won't stop filling with water
A couple things may be going on here... you may not want to hear, but the Neptune has a had many "consumer related problems".
If your complaint is "will not stop filling with water" I would access your inlet water-valve (typically blue with 2 black battery looking solenoids; where your water-lines connect directly), test for continuity and replace as necessary. Sometimes inlet-water valves also go bad where the complaint is: "no water comes in at all".
Jan 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Estate washer, new, water will not stop, overflowing
you need to replace the inlet valve something is stuck in the valve not allowing it to shut.
Dec 23, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing machine
it needs a new water valve
Nov 16, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
