Question about Dehumidifiers
When turned on all that happens is the frost stat light flashes. The room is warmer than 12deg. Anyone know why?
Always worked perfectly for last 3 years
    Genius:
  • 1,585 Answers
Needs serviced
Posted on Apr 27, 2015
Lived in my house for 2 years, never once did I have to empty the bucket on my dehumidifier. In the last 3 days it has filled up twice, what would cause this?
It finally decided to start working for some odd reason... before it was not working...it is supposed to fill the bucket...
heatman101
Aug 27, 2011 | Frigidaire Dehumidifiers
Everything seems to work but it is not collecting any water. Two years old, FDL25P11. Has worked perfectly until now, 25 qts every two days
Apparently the room humidity was too low (we were in a long cold dry spell) now that the rains have returned the machine works fine.
john
Dec 14, 2009 | Frigidaire Dehumidifiers
MY unit has become increasing noisy and the fan is the mane cause. The fan is now making different noises at differing levels high and low of loudness, and it often quits running all togetger. It is also...
It sounds like the bearings in the motor are worn out, especially as you said it quits running at times. You should be safe in just replacing the fan motor, but check the fan blade to make sure it isn't out of balance for any reason(dirty, missing a balance weight, or bent). Hope I was of assistence!
Nov 14, 2009 | Kenmore 53701 Dehumidifier
Dehumidifier goes off after winter break
There are two reasons that it should turn off. Either the humidity level is at the setting off the humidistat control switch or the bucket is full. The only other thing I can think of is that the motor is overheating.
May 11, 2009 | Kenmore 54701 Dehumidifier
Will run but won't take moisture out of the air
It sounds as if the fan motor is running, but the compressor is not.
Apr 05, 2009 | Maytag M3DH30B2A Dehumidifier
P1 error
Your question needs to be answered in 3 parts:
1) As per the manual for my Danby Dehumidifier (Model DDR657EE), the unit may not turn on immediately when powered On (it may take a several minutes). So, generally, it would be normal in your case.
2) Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
So, generally, if you see P1 periodically (for brief periods), then it would be normal.
3) Since your unit keeps running (continuously) and there is no water in the bucket, then you should call Danby ServiceI for additional assistance - it seems defective for this reason.
I hope that helps.
Oct 31, 2008 | Danby DDR2506 Dehumidifier
Motor
Your problem may be the thermistor that causes the CH01 trouble code.
Aug 21, 2008 | Comfort-Aire BHD-501 Dehumidifier
Dehumidifiers Logo
134 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Dehumidifier Expert? Answer questions, earn points and help others
