Question about Hoover Washing Machines
Build up of dust on fikter under dirt container after 1 hoover
Also blows dust when switched on
  • Hoover Master
  • 3,519 Answers
Hi Sandra:
Is it possible that the dirt container is broken?
Check all of the seals. Make sure they are cleanand functioning properly.
Posted on Apr 27, 2015
Buuld up of ( layers) of dustbon fikter under dirt container happens after 1 hoover
this indicates that the filter is not fitted correctly or is the wrong filter in use
Apr 27, 2015 | Hoover Vacuums
Troubleshooting hoover
Hi! Here are some basic trouble shooting steps for the Presto 2-in-1.
1. Remove the dirt cup. Push the release catch on the hand vac and pull the dust container off the motor unit
2. Remove dust container from filter assembly and cyclone separator.
3. Hold the dust container over trash can and tap out debris.
4. Check cyclone separator for additional debris, empty into trash can
5.Check the rinsable filter. If rinsing is needed, remove rinsable filter, rinse with pleated side facing up. Allow filter to completely dry for at least 24 hours.
6. Remove any hair and debris from the brush roll.
7. Remove the floor nozzle from the cleaner by pressing the nozzle release button on the back of the floor nozzle and pulling from cleaner.
8. Check and clear nozzle of any obstructions.
Hope this helps!
Aug 06, 2014 | Hoover Vacuums
Hoover dm6200 blowing air
check your suction hose again, follow it to where it goes into the body of the machine. I assume this will be near where the bagless cannister is. Remove the bagless cannister and look up inside to where the attachment hose should come into the cannister. I believe you are still blocked up there. using a butter knife or something along those lines should free up the blockage.
Also, if that is all clear, try re-adjusting the dirt cannister as it may not be on properly to create your suction flow through the hose.
Good luck and let me know if I can help further.
Jan 24, 2012 | Hoover Vacuums
Is blowing dust out as I vacuum
In your manual:
Visible dirt escaping from cleaner
Possible Causes: Remedies:
1) Dirt Container full 1) Empty Dirt Container
2) Filters missing or installed incorrectly 2) Check Upper Tank, Pre-Motor and Post-Motor
Filters for correct installation
3) Dirt Container installed incorrectly 3) Pull out and re-insert Dirt Container correctly
Feb 01, 2011 | Bissell 6591 Power Trak Revolution Bagless...
Want to blow air out to inflate mattress
You need to remove the main head with the brushes from the front and install the safety cup. The remove the bag by unclipping from the top and disconnecting the boot end from the bottom with an outwards twist. Now attach the hose to the exposed outlet; attached the thin nozzel designed for inflating to the hose and switch on - you will feel air being expelled from the hose.
Air, which normally contains dirt and dust because you're hoovering is blown into the bag, but now with the bag removed; the air is blown into your hose, through the attachment and into what ever needs inflating.
For a good visual set of instructions click on the following link and scroll down to the second set of instructions :
How to change hoover to a blower
Sep 25, 2010 | Kirby G5 Bagged Upright Vacuum
I just bought a foldaway hoover with wide path. I plugged it in and started to vacuum and dust flew everywhere. Walmart would not give me my money back so they gave me another hoover foldaway with the wide...
Take to Walmart, plug it in and start to vacuum THEIR floors!
Try removing the dust container and look for anything blocking airflow including the HEPA filter. Make sure the dust cup has a seal where it joins the vacuum. The fix is probably simple, but it shouldn't be up to you to do so!
Nov 16, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
My acer 5420 keeps overheating and shutting down
Clean the insides of your Desktop case.
1. make sure all the fans(CASE FANS, POWER SUPPLY FANS AND CPU FANS) are working dust and lint free.
2.remove dust and dirt build up in CPU heat sinks.
3. remove dust and dirt build up in the motherboard, RAM and
expansion slots.
4. remove dust and dirt build up on CD-ROM's, Hard Disk Drives and expansion bays.
5.apply new thermal paste on your CPU.
Jan 20, 2009 | Computers & Internet
Poor suction-need to know how to remove & clean filter under canister of Hoover Wind Tunnel Mach 4.7 Twin Chamber System.
I assume this is a Hoover Bagless, if poor suction, the hose or dirt inlet by the brush roll may have a clog. The filter inside the dirt container may need replacement. Some had a screw to take out to remove the cover for the filter, the one under where hte dirt container sits. Alos the belt may be stretch and won't turn the brush roll under load. Having the model number would help.
Apr 19, 2008 | Vacuums
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
