Question about Polaroid TDA-03211C 32 in. LCD HDTV
How do I fix my tv
It has a blue screen on it with a moving message, no message
    Genius:
  • Polaroid Master
  • 1,585 Answers
Child lock may b on c instructions
Posted on Apr 27, 2015
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
Blue line convergence not working
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Projection <a href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target="_blank">TV</a> sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look <a href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target="_blank">3D</a>, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. <br /><br />This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem. <br /><br /><b>Common Symptoms include....</b><br /> <ul class="h_mi"> <li class="h_mi">Screen looks 3D <li class="h_mi">Colors don't line up <li class="h_mi">One or more colors can't be adjusted when using the convergence menu. <li class="h_mi">Screen is bowed or warped. <li class="h_mi">TV shuts off after powering on. Power light will blink. TV may also make a chirping noise. </li></ul>Here are some <a href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target="_blank">photos</a> of convergence problems.<br /><br /><img class="h_mi" src="/uploads/images/42D3683.jpg" /><br /><br /><img class="h_mi" src="/uploads/images/7859B01.jpg" /><br /><br /><img class="h_mi" src="/uploads/images/E87380C.jpg" /><br /><b>Here is a quick tes</b><b>t....</b><br /><br />Using your original remote go-to the settings menu then goto the convergence section.<br /><br />Try to adjust the red and then the blue convergence.<br /><br />You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight. <br /><br />If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem. <br /><br />Note: If you TV has as flash <a href="http://www.fixya.com/#" target="_blank">focus</a> or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix<br /><br /><b><img class="h_mi" src="/uploads/images/69189A5.png" />CONVERGENCE SOLUTION<br /><br /></b>You can see some more examples and find a fix using this link on Fixya <a href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull" target="_blank">http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull</a></span>
Aug 26, 2010 | Hitachi 43FDX01B TV
We can cet the blue and green adjusted but not the red. It like watching tv in 3D
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
My big screen tv looks 3d and red green blue are off
  • Screen looks 3D
Mar 06, 2010 | Sony KP-51WS500 51" Rear Projection...
Red, green, and blue lines at bottom of screen, mirror looking effect, also looks like 3D. Got at a garage sale so no manual.
  • Screen looks 3D
Jan 03, 2010 | Hitachi 43F300 43" Rear Projection...
VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
May 18, 2009 | Vizio VX20L 20 in. LCD TV
Blue screen no signal
You need to replace the surface mounted voltage regulator IC (small black square chip with a metal tab on one end, and two legs on the other end.) it is on the main board, right behind the signal input board. It's a BA09FP regulator IC, you can purchase this on mouser.com
it requires a bit of disassembly, but it is relatively easy to do. it is component number IC9C25. It could be bad, or just have bad connections . This IC supplies 9 volts to the terminal board. Try resolding it first.
Jan 15, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Blue shadow above writing and pictures on screen
it sounds to me like your convergence boarde is bad and needs replaced
Oct 23, 2008 | Televison & Video
Seeing blue screen only on all chanels/Inputs but hear sound
Sounds like trouble in blue video amplifier or shorted picture tube; needs to be looked ats by TV tech.
Jul 16, 2008 | Emerson EWF2004 20" TV
Polaroid TDA-03211C 32 in. LCD HDTV Logo
50 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
