Question about American Power Conversion Corp SUVTR30KG4B5S - APC Smart-UPS VT 30kVA Rack-mountable UPS
APC Smart VT 30KVA UPS cannot sustain power after power failure
Cannot sustain power after power failure Batteries are in good condition Fuses in the battery fuses in the battery module are tested Batteries have been tested and are ok
    Top Expert:
  • American Pow... Master
  • 50,058 Answers
Ups units run a computer directly from mains power and from a battery when mains power is cut.
some run the computer through the battery at all times and so use the battery as a surge protection
points to check on your unit
is the by pass system being damaged in the surge protection section
is this requiring the batteries to provide power but not being charged at the same time
Is the power consumption exceeding the battery rating ( pc, printer, monitor , modem etc exceeding the out put of the ups
Posted on Apr 27, 2015
Apc smart ups vt - no mains detection
be more precise
more info needed. what did you do. how did U startup the unit?
Mar 14, 2015 | APC Smart-UPS VT (SUVTP30KH3B4S) UPS...
Why does an APC Smartups 30kva have high battery temperature alarm?
UPS should be located in an environment where the temp should not exceed 25 degrees Centigrade, or you may have a damaged fan (inside the UPS, or the temperature sensor is defective.
Jun 09, 2014 | APC SmartUPS VT 30kVA Rackmountable UPS ...
30kva apc ups VT is nor getting On?
Try holding the "on" button for a few seconds until magnetic relay is on.
Sometimes flat(dead) batteries will stop UPS on
Apr 19, 2014 | APC Smart-UPS 2200XL (APCSMART2200XL) UPS...
Ramesh,
See my answer to your previous post.
Quote:
" Ramesh,
There are multiple reasons why this is happening. Give me a call, reply here, or email me and I'll be glad to help."
If you need UPS, Surge, or Power Related help contact Daniel with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/ ** If this helped - click YES :) **
How to find out damaged battery unit in 30kva apc smart ups VT?
pull them out, examine each one for cracks, bulging, leaking, then check the voltage. Should be around 12.25v fully charged.
Apr 19, 2014 | APC Smart-UPS 1500VA Shipboard...
APC 10kva UPS SUVTP10KH1B2S is not turning on
check the battery bank, and the battery must be in good condition
May 13, 2013 | APC Smart-UPS VT SUVTP10KH1B2S UPS System
Inverter fault
This unit will require you to Brain dead the whole UPS.
To see if it is actually a condition that exists with the hardware or if it was just a lock condition.
Steps:
1)Power down unit completely
2)Unplug all batteries
3)Unplug from wall
4)Leave unplugged for about 5 minutes or so WITH NO POWER AT ALL.
5)Plug batteries back in
6)Plug back into wall
7) Turn unit back on
Log into console of UPS and see if the condition returns.
If it does not return your good to go.
If the error returns. You have to replace the WHOLE battery pack.
APC has told me their units are typically good for 4-6 years, after that their units cannot hold the same tolerances as they did when they were brand new.
Hope this helps.
Oct 30, 2012 | APC SURT8000XLT-1TF3 Smart-UPS RT 8000VA -...
Apc smart 1000 ups after changing batteries all right are blinking
Is this the RT or the VT or the RM or the XL? Recheck the UPS's batteries by conducting a battery test. Press the I/Test button to initiate the battery test. If All LED are lit and the UPS emits a constant beeping then there is a internal fault.
FRONT PANEL LEDS FLASH SEQUENTIALLY: The UPS has been shut down remotely through software or an optional accessory card.
If all else fails then remove the input power. Unplug the batteries. Check the fuses in the back. If fuses are ok then push and hold the power button. This will reset the logic. Plug batteries back in, apply power and hopefully all is ok. If not then purchase another UPS the cost to repair it will be more then what it's worth
Sep 20, 2011 | APC Smart-UPS 1000VA UPS System
Does a APC UPS have an internal fuse. If yes where can I find it?
Some of the batteries have fuses attached to the batteries. The UPS fuses would be close where the power comes in.
Aug 24, 2011 | APC Smart-UPS UPS System
APC Smart-UPS 1400 no power
Better late than never...
The older Smart UPS models are peculiar in the way that they appear dead (will not power on) if the battery is completely bad.
Replace the battery, and the UPS should come back to life.
Jul 01, 2008 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
American Power Conversion Corp SUVTR30KG4B5S - APC Smart-UPS VT 30kVA Rack-mountable UPS Logo
55 people viewed this question
Top American Power Conversion Corp Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an American Power Conversion Corp Electrical Supply Expert? Answer questions, earn points and help others
