Question about Avanti Dishwashers
Avanti calls for a cabinet height of 34 1/2". However, the dishwasher is only 32 1/4" tall. What do you do to fill the gap of 2 inches at the top?
  • Avanti Master
  • 932 Answers
I agree with Daniel, you need to unscrew the adjustment legs on your dishwasher to raise it up higher.
Posted on Apr 27, 2015
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 68 Answers
You don't fill the gap. There needs to be some clearance for the door to be able to swing open without contacting the underside of the counters. You can always decrease the gap a little by using the adjustable stands on the bottom of the unit. The unit will come with a kickplate that can adjust to multiple heights.
2 Suggested Answers
  • 128 Answers
SOURCE: dishwasher for 32 inch cabinets
Miele makes a G600 series that are 32 1/4 " tall - that would probably be your best bet.
Posted on Jan 05, 2009
How much breathing space does a refrigerator need NONE, 1/2 inch or 1 inch above the top of the cabinet for air circulation. Sears has told me all 3. WHICH IS CORRECT?
For airflow it would be the back that needs clearance of a couple inches. Top of unit shouldn't matter. Inside the fridge itself if you plan on packing it as full as possible except for the amount space needed to allow airflow,. I would just atleast leave 1 inch on every side. But outside of fridge just leave clearance in back and front. Google manual and it will tell you
Oct 24, 2016 | Refrigerators
Which dishwashers are less than 830mm high, to fit under my work surface?
Peter,
830mm equals 32.68 inches. You will just have to look at the specs of any dishwasher that you are interested in and see if they will fit in less than that height. Most dishwashers that I have installed would fit between 32 and 34 inches in height. Hope this helps!
May 15, 2015 | Dishwashers
What are the dimensions on a Kenmore 363.14192992 dishwasher?
Dishwashers that are installed into standard kitchen cabinets have a standard width and depth of 60 cm (Europe) or 24 inches (US), and most dishwashers must be installed into a hole a minimum of 86 cm (Europe) or 34 inches (US) tall. Portable dishwashers exist in 45 and 60 cm (Europe) 18 and 24 inch (US) widths, with casters and attached countertops. Dishwashers may come in standard or tall tub designs; standard tub dishwashers have a service kickplate beneath the dishwasher door that allows for simpler maintenance and installation, but tall tub dishwashers have approximately 20% more capacity and better sound dampening from having a continuous front door.
Feb 06, 2015 | Kenmore Dishwashers
Dishwasher slides when both top and bottom trays are out at the same time
Please clarify if the dishwasher is tilting forward when both the trays are out.
If so there are ways to install the machine so that it will not tilt. If your dishwasher is installed under the kitchen bench and there is a gap on top, the machine will tilt from the weight of dishes once the trays are rolled out.
The legs are adjustable, therefore, free the hoses and power cord. Pull the machine out so that you can untwist the legs to a height suitable to minimise the gap. Just leave enough space to allow you to push the machine back in with ease. You can always pack in cardboard or phoam later when machine is in.
If after legs are heightened and you still have a big gap, the you need to get to pieces of timber cut on either top edge to fill the gap.
There are specialty brackets (e.g. L-shaped brackets) which you can buy and screw into the cabinet walls to hold machine in.
Some machines have holes on the side or top to allow you to screw in from the wall of machine into the cabinet. However, I do not believe Electrolux models have this.
Let me know if I have misunderstood your problem.
Ash
Sep 19, 2011 | Electrolux Dishwashers
We purchased a slide in range, Frigidaire fggs3045kf. We want to put a granite countertop and use tile on the floor. When we raise the heighth of the range to make room for the tile, the ridge of the...
Hello Mkoffice, this a very common problem when floors are installed in front of cabinets and not underthe cabinets. it also causes a problem for the dishwasher. it will become trapped or cant be installed.If you dont want to removed cabinets to install the tile. you will need to raise the cabinet height. my shop has run into this before. We add 1 inch tall strips of wood across the entire front edge of the cabinets. the same is done to the back wall and any area where two cabinets sides meet. we dont use full sheet of ply wood because the granite installers will need access into the top of the cabinets to level the counters. The wood type should match the cabinet.( at least in the front) it will have to be stained or painted.
Hope this helps
Joe Connolly
Aug 16, 2011 | Frigidaire FGGS3045KF Stainless Steel Gas...
What are the product dimensions
Hi and welcome to FixYa, I am Kelly. The installation guide with the dimensions can be found here:
http://www.managemylife.com/mmh/installation_guides/3932/KENMORE-Dishwasher-L0504234?brand_name_search=665.15952 (7.87 mb file)
The top of the cut out is 33 & 7/8" Min. to 34 & 7/8" Max (adjustable legs for height)
Minimum space to counter top parent material 1/4" (Top of dishwasher cabinet is screwed in at the top)
Depth 24 & 1/4 inch minimum
Width 24 & 1/4 inch minimum (Allows for 1/8" clearance on both sides)
Thanks for choosing FixYa,
Kelly
Feb 22, 2011 | Kenmore 15952 Dishwasher
Over The Range Microwave new models too tall need under 15 in hig
cut the cabinet off. a cabinet maker can do it and you can tell if they ar good
Jul 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Dishwasher for 32 inch cabinets
Jan 05, 2009 | Dishwashers
Height for dishwasher is only 33.5 inches
we found a fridgidare dishwasher the had a range of 32.5-34 model number FDB2410HIC1 try it, it saved us from having to do alot of tile cutting
32 inch dishwasher...
hello Welcome
I believe Ge makes one to go under a sink!
And that's the only one! that low.
Thank you Huum
please leave a solved rating before you sign off
Dec 07, 2008 | Equator Dishwashers
Dishwashers Logo
76 people viewed this question
Top Avanti Dishwashers Experts
David Ellis Rhea
Robert Plante
Are you an Avanti Dishwasher Expert? Answer questions, earn points and help others
