Question about Electric Health & Beauty
I bought a Avigo electric scooter for my son. Its used. I was assured it works but it makes no sound after being fully charges. When i flip the switch it makes no sound at all.
  • 2,963 Answers
I would return it to the seller. They misrepresented the condition of the item, or ask them to "make it work as they said it did".
Posted on Apr 27, 2015
  • 118 Answers
SOURCE: sterling sapphire 2 4wheel scooter
Larry,
Many scooters use a special charger that will not overcharge the batteries. Your best bet is to run a long extension cord to wherever you are safely storing you scooter and use the on-board charger. Be sure to charge your batteries often, since they last a lot longer if you do not run them down too far.
Posted on Nov 27, 2008
  • 23 Answers
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Posted on May 06, 2010
FixinFax
  • 3085 Answers
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Posted on Jun 27, 2010
SOURCE: We have a Fortress Scientific 2000 electric
Your break release shifter is in the push the scooter mode. Put it back in gear and the horn doesn' beep and it should run..
The horn beeping is the alarm to tell you the break release is on.
It is usually located under the seat on the body of the top of the battery housing. Looks like a stick with a ball on it.
Posted on Dec 18, 2010
  • 692 Answers
SOURCE: I have a 3yr old
Kay the status light flashing indicates a problem. Count the nunber of flashes and your manual should tell you what the error code means. Also check the freewheel lever and make sure it is drive position. Without knowing the number of flashes I can't tell you what the problem might be. Hope this helps
Posted on Mar 21, 2011
Testimonial: "freewheel lever! thank you very much"
I have a Avigo kids electric scooter.its saying it's fully charged showing the green led light but it won't go why is this
make sure the battery is actually good, if so it may have a corroded or broken wire to the motor or bad ground wire.
Nov 26, 2015 | Electric Health & Beauty
I have a Taotao electric scooter not a mobility scooter the scooter is fully charged the lights and horn work fine but when you turn the throttle nothing happens it makes a kind of clicking sound
Not familiar with your particular scooter - but I am well versed with electricity. The issue you're seeing is likely a result of a poor connection somewhere. The amount of power (current in amps) required to operate the horn or lights is a small fraction of that needed to run the motor.
You should trace larger sized wires/cables from the motor back as far as you can - ideally to the battery if possible. Remove, thoroughly clean and reconnect each of these cables under each terminal screw - one at a time. This way you'll know any unconnected cable goes on the only terminal that is removed.
At this point, you should have 100% good connections for all high current loads - including the motor and will probably be able to use the scooter. Placing the battery on a slow trickle charger overnight will help ensure that the battery is fully charged - not just enough to operate the horn or lights.
May 11, 2015 | Electric Health & Beauty
Batteries wont charge
You would need a voltmeter to check the charger in order to see if it is charging the batteries. New batteries if purchased from a reputable outfit will have a nominal charge and should work initially in order to test the scooter. Depending on the model check for blown fuses and disconnected wires on the battery boxes, connections, plugs and charging circuits including the wall outlet. The display on the scooter will indicate the state of charge and the key switch should work and give an initial indication that the scooter is on. If you provide make and model I can respond with more specific information.
Mar 23, 2014 | Health & Beauty
We have fully charged the battery but when we pull the paddle to move it doesn't go
Reengage the wheels again then give it a slit push you should fell some resistance .seems the freewheel is not fully in
Apr 24, 2013 | Electric Mobility Mobility Electric Power...
My scooter will not fully charge
This could be the charger socket is worn and not making a good connection when charging or it could be the charger itself at fault. Now you have changed the batteries, I presume new and both the same type, you need to look at the charging side.
Apr 03, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Kazuma battery will not hold a charge
This is a common problem with chinese atvs. I installed a toggle switch on the positive wire from the battery. When my daughter is finished riding, I simply flip the switch and all power to the bike is killed, preserving the battery.
Apr 18, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Pride victory Scooter battery charged won't run
The clicking sound is most likely the motor relay engaging and disengaging. Most scooters and wheelchairs do this when in neutral, or when damaged.
I would first make sure its not in neutral by switching a petal, or lever in the back or at the side of the scooter. (you may need to do this on both sides) You should switch this when the scooter is off because you will need to restart it afterward anyway.
If that doesn't work you most likely have a motor issue if the battery is charged as you describe.
Dec 16, 2008 | Pride New Mobility Legend 4 Wheel Scooter
Health & Beauty Logo
96 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
