Question about Magnavox Tb100mw9 Digital Tv Converter Box With Remotenew And Manual
Intermittand dtv converter - Magnavox Tb100mw9 Digital Tv Converter Box With Remotenew And Manual
  • Magnavox Master
  • 2,992 Answers
Sounds like some connection problems. Double check your connections and power supply.
Posted on Apr 27, 2015
HOW DO I SET MY UNIVERSAL RE MOTE FOR MY CONVERTER BOX
To be honest I never got a universal remote to work Magnavox TB110MW9 DTV Digital to Analog Converter
Nov 16, 2015 | Magnavox TB110MW9 DTV Digital to Analog...
HD TV?
No,it a tube tv,it analog tv.It well reqiure a DTV converter box to get DTV signal.Only LCD screen tv have digital tuner,to get the DTV with out the digital converter box.
Feb 10, 2010 | Daewoo Televison & Video
Radio Schack converter doesn't program Ch: 25 like Magnavox!
Returned product to dealer. That fixed my proble.
Thanks...
Aug 19, 2009 | Philips Magnavox 20MT133S 20" TV
Want to run my dtv receiver through new digital converter box.
You will not be able to record local station from a DTV converter connected thru a directv receiver unless there is a a/v input on the directv samsung receiver. Also check the user manual for this receiver if recording from an external source such as a DTV converter box is possible. The answer to seperating the DTV converter box from the directv samsung receiver is possible if your tv has multiple inputs. Try connecting the DTV box to the RF input and the directv samsung box to an a/v input then change inputs using the tv remote. you will need an av cable (yellow/ red/white) for the directv box and a rf jumper cable for the DTV box.
May 17, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
DTV Conversion Question
Yes you can connect a DTV converter box in your van.
If the TV is DC powered you will need to buy a DC to AC inverter, like these http://www.dcacpowerinverters.com/12_volt_power_inverters.html because there are currently no dc dtv converters available.
If the tv is ac powered you will only need to connect the converter to the inverter the tv is connected to.
If you need more help or installation instructions let me know.
Please rate this solution.
Lone99star
Apr 03, 2009 | RCA R52WH73 Projection Television
Need to know if I need dtv converter for my Samsung combo tv
If you are using a cable TV or satellite service to get your TV content then you do not need a dtv converter.
You only need a dtv converter if you use an antenna to get your TV content and you do not have a digital TV with a internal digital tuner.
If you have the model # of your TV I can look that up for you if you are unsure.
Jan 12, 2009 | Televison & Video
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
Programming Quasar VHQ940 for DTV converter box
I assume you're trying to record from the DTV box. You will have to set the DTV box to play through channel 3 then tell the VCR to record channel 3. So basically the VCR always THINKS it's recording channel 3, but in reality it's recording whatever channel the DTV box is on. You will be unable to used timed recording unless you leave the box on whatever channel it is you're wanting to tape.
Aug 05, 2008 | Quasar VHQ940 VHS VCR
How do i convert my dtv-5801 to the new free digital air waves
My information indicates that the DTV-5801 has a NTSC (analog TV) tuner built in bot not and ATSC (digital tuner). It does have HDTV inputs to which an external tuner can be connected. For Off-Air Digital TV, add an HDTV (ATSC High Definition tunner) and you are set to go. Do not buy the DTV converters, they have down converters built in and only deliver SD to the outputs.
May 26, 2008 | Runco DTV-5801 58 in. Rear Projection...
How to install DTV Digital to Analog Converter
Your outside antenna connects to the input of the d/a converter box then the output goes to your tv...1.2.3.... If your on cable you do not need a converter box.
May 08, 2008 | Televison & Video
Magnavox Tb100mw9 Digital Tv Converter Box With Remotenew And Manual Logo
42 people viewed this question
Top Magnavox Audio Players & Recorders Experts
Jay Plesset
gbob59
Are you a Magnavox Audio Player and Recorder Expert? Answer questions, earn points and help others
