Question about Rinnai Water Heaters
My Rinnai tankless water heater flashes 11 when calling for hot water.
  • 352 Answers
Code 11 basically means no gas. It could be:
  • The internal gas valve does not open.
  • The pressure regulator in the gas piping ahead of the water heater has failed (which is more common than you would think).
  • A neighborhood hooligan turned off the gas.
  • You did not pay the gas bill.
Posted on Apr 27, 2015
  • 2,963 Answers
Your Owner's manual should help. No manual, try MFG website, or email their customer service. Or try manualslib.com
CRTN
  • 716 Answers
SOURCE: No water flow from hot water tap with a rinnai tankless water hea
Its A Possibility The Left Over Water In The Hot Is Frozen. If Your Line Is Exposed Outside Somewhere It Can Easily Freeze Up. Turn On The Hot Water Everywhere In The House And If Accessible Check The Lines To See Where The Warmth Ends. You Can Leave One Off Over Night In Hopes That It Will Eventually Defrost.
Posted on Jan 16, 2009
  • 152 Answers
SOURCE: No hot water
The code # 11 is a code that warns of "no ignition" and the causes of this error code are too many to list. I would suggest that a qualified tech. perform a diagnostic test and repair.
This is not a task for the "do it yourselfer"
Posted on Mar 25, 2009
  • 11 Answers
SOURCE: takes too long for hot water.
You need a recirculating line. You will have to hire a plumber to run a water line from the farthest fixture or to the fixture you are concerned about on the hot side and return it back to the water heater. this will cause hot water to constantly run throught the hot water line (via the recirculating line) and when you want to draw water from the fixture, you will already have hot water right at the line.
I know this works with standard tank water heaters, but it is a lil trickier with rinnai units(but very possible) if your plumber pleads the 5th and tries to sell you another unit call the Rinnai manufacturerand ask them how.
Posted on Jun 20, 2009
snap101
  • 117 Answers
SOURCE: this things beeping and flashing 12 everytime we
check the error codes on it by pressing the on off button for 2 seconds then while holding the on/off button press the up button this should display the last 9 error codes let me know what they are
Posted on Jul 29, 2009
SOURCE: My Paloma tankless water heater flashes C2 11 error code
I just had the same problem and I fixed it in about an hour or 2. First shut off the gas,water and power(unplug it) Take off the cover There are about 20 screws above the electrical circuit board. You have to remove all of those screws to remove plate that is covering the burner assembly. The burner assembly has these 3 pins that look like number 7's these are covered with build up and gas can't flow right. That's why you get the c211 error not enough gas. Take a wire brush and gently remove any build up, I also cleaned the thermocoupler which is next to the burners. It looks like a metal pin with a couple of wires coming out of it this was also very dirty. I took a can of air and basically freshened it up It works perfect now. Email me with any Q's at Mario@myredr.com Good Luck All that you need is a long phillips screw drive and a drill because its about 25 screws
The burner assembly has 2 screws all the in back underneath the assembly once you remove those 2 the assembly comes out . You don't have to disconnect any wires.
Posted on Oct 29, 2009
Rinnai 20 heater stopping and starting have changed regulator but still not working properly only started playing up i have been in house 2 years any more suggestions
Single-handle faucet cartridge that leaks can cause tankless not to function. Check for crossover or cross connection:
http://waterheatertimer.org/Crossover.html
Cut losses from owning tankless computer that heats water. Go to Lowes and buy new tank-type gas water heater for $390 and have hot water right quick with less maintenance and own a product that homeowner can repair themselves.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Otherwise call service technician who is qualified to work on tankless computer.
Gene
n
Aug 07, 2013 | Rinnai Webstone The isolator EXP tankless...
I have a Rinnai Continuum Model 2532 natural gas tankless water heater in my home. It takes about 45 - 60 seconds for the water to get hot at the faucet which is closes to the heater. This thing is...
clean filter on the cold side coming in and clean or replace the aerator at the sink, rinnai works on water flow, common problem if your water hardness to high or if you have iron in your water
Oct 04, 2010 | Rinnai Webstone The isolator EXP tankless...
I went out of town for the weekend and when I returned home my Rinnai tankless water heater lcd monitor was completely blank (off) and there is no hot water.
Check voltage going into the heater and at the remote terminals. Many tankless heaters also have a GFI inside their units. You can check if the GFI has power across the connections.
Jul 24, 2010 | Rinnai Webstone The isolator EXP tankless...
Exterior mounted Rinnai tankless water heater not
check to see if you have a blocked line on the hot water side
Jan 08, 2010 | Rinnai Webstone The isolator EXP tankless...
Our Rinnai tankless water heater is producing water as hot as pre
Power outage will reset Rinnai unit to that temperature. Read manual for more info.
Nov 28, 2009 | Rinnai Water Heaters
This things beeping and flashing 12 everytime we
Jul 28, 2009 | Rinnai Water Heaters
Takes too long for hot water.
Jun 12, 2009 | Rinnai Water Heaters
No hot water
Mar 22, 2009 | Rinnai Digital Remote Water Heater Control...
Jan 16, 2009 | Rinnai Webstone The isolator EXP tankless...
Water Heaters Logo
211 people viewed this question
Top Rinnai Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
jdthefixer
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
