Question about Xerox Workcentre 5225 / Copier, With 100-sheet Bypass Tray, 2 X 500-sheet Paper Tray, 2 X 500 Tray... Printer
Code error 061-315 copy not coming - Xerox Workcentre 5225 / Copier, With 100-sheet Bypass Tray, 2 X 500-sheet Paper Tray, 2 X 500 Tray... Printer
    New Friend:
Change the laser and it will be done. please don trouble your self just do as i am saying.
. remove the cover were the paper falls when you are making copies and take off the front cover until you reach the laser unit and replace with a functioning one. if you want some more help contac me on my cell number 00258 846427869
Posted on Sep 19, 2017
Erreur cod 009-330 xerox 7245
009-330 error code xerox work center 7345 problom & soluson
Jul 10, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Error code U6-02
You have a large capacity double tray, the code is for the lift up motor in the right hand tray (that lifts the paper stack to the rollers) pull out the tray and see if there is paper wadded between the tray and the back wall of the machine blocking the motor boss from meshing with the tray.
Clear the motor error code with SIM 15 in the service area of the machine (from copy mode, # * C * to access)
If the code comes back your lift motor is worn out and needs to be replaced
Apr 20, 2014 | Sharp Mx-m450n Mfp Multifunction Booklet...
I have a sharp arm237 the error code is h2-01.... I cleared the melted peice of injet paper my daughter used from the heat roller. I still have the error but can't figure out how to clear it.
double check to make sure all paper is removed.
On the key pad press P * C * it will bring up another screen enter 14 and press the copy button it will ask you if your sure you want to clear the error select yes and press copy button machine should restart if error code comes back you will need a tech to come out and check the fuser and connections
Aug 22, 2010 | Sharp AR-M237 Digital Copier
Comes ready but wont copy. wrench comes on and calls for repair service.
You will need to press and hold "clear" and "8" keys simultaneously. This will display the error code in copy quantity screen. What is the code?
Jun 08, 2009 | Toshiba 2860 Copier
NP 6545 Copier - Error Code E401
error code E401...DF paper feed motor lock...check the motor of your DF...try to turn off the machine and unplug the communication cable from DF to the machine and turn on the machine again...
Mar 16, 2009 | Canon NP 6545 Copier
Home cinema sony dav f200 error cde c:13:71
ive got a sony dav f200 home cinema system,it lets me play music cds but trying to play dvds(not copied or american) it comes up with and error code c:13:71. what does it mean?
Mar 14, 2009 | Sony Televison & Video
Error Code L
error L can not do anything We had power outage then this happened
Oct 13, 2008 | Sharp AL 1631 Copier
Print and copy comes out blank paper
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Xerox Workcentre 5225 / Copier, With 100-sheet Bypass Tray, 2 X 500-sheet Paper Tray, 2 X 500 Tray... Printer Logo
283 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
