Question about GE GFWH2400LWW Front Load Washer
Machine will got start.
Cloths did not drain / spin, Tried to restart but would not. Powered down. pushed power button, pushed start button, door locks, after couple minutes door unlocks and machine does not start. I have unpluged the machine to reset but still not working.
  • GE Master
  • 2,963 Answers
Warranty? Owner's manual troubleshooting section? Sounds like a bad circuit board, and time for GE technician. I'd ask them for the worst cost repair. You may want to consider a lightly used replacement.
Posted on Apr 27, 2015
I have a LG Front Loading Washer, Mdl. WM2601H. My wife was doing a load and I believe load became unbalanced. This was on the wash cycle not the spin cycle. She kept pushing buttons and the display went...
Did you try switching the power on whilst holding the start button only for at least ten seconds.if you can pull the machine out enough to tip it 45 degrees toward the rear so no water leaks when you open the penny trap to see if a button of coin has lodged in the drain pump.good luck.
Jan 13, 2015 | LG Washing Machines
ASKO W620 QUATTRO 1200 RPM front load washing machine. This morning clothes were still very wet, I turned on spin cycle & some water came into machine?? Turned off water at tap - now can't open door to...
Probably a blockage in the drain hose at the back of the machine. Easy to fix. Turn machine off then pull machine out so you can easily access behind. Have bowls and cloths/rags at hand for water spillage. The drain hose is located low down and links into your sink drain, it is held in place by a clip. Remove the clip and hose. This will start to drain the machine so make sure you have enough vessels to catch the water. When the water has stopped draining, check the hose for blockages : buttons / coins / hair grips / paper etc. Also check the hole where the hose attaches to the machine. Remove items then blow through the hose to see if there are any other restrictions. If all clear then replace hose on back of machine. Clear up. Move machine back to normal position. Switch on and set to spin. When complete, the machine should shut off cycle and unlock door. This will save you at least 100 pounds on a call-out. Good luck.
Jun 18, 2014 | Washing Machines
Why is my maytag Neptune Model no# MAH5500AWW spinning very slow and not draining water out?
Complete drain must occur before spin. A no drain situation would be an actual full pool of water seen in the bottom of the machine if all the cloths were removed, sounds like you are experiencing a spin enable switch failure, which mainly prevents final high speed spin leaving the cloths dripping wet. The spin enable switch contacts become tarnished/corroded over time resulting in poor connection. If the door lock light comes on than your door lock wax motor is working. The spin enable switch is the last switch to the right in the door lock unit where the light bulb is. Part# is 22002162. If there is an actual pool of water in the bottom of the machine as if you simply removed the cloths from the unit but left the wash water, than you should look first look to your drain pump for failure, or obstruction of foreign objects, or excess lint in the pump. Pleazer Appliance...
74bd738b-53cb-465a-99c1-ba55e2189ba2.jpg 5e1e4646-e2e3-4e7c-afc7-7a0e188e6cf0.jpg
Apr 15, 2014 | Washing Machines
Maytag Neptune washer machine won't spin or fully drain
    • 1 Open your home's breaker box and flip the circuit breaker switch to "On." If it is already set to "On," flip it to "Off" and then back to "On" to reset it. A power surge may have interrupted your wash cycle so the drain/spin cycle never actually started.
    • 2 Move the washer away from the wall and straighten the drain hose if it is twisted or turned in a way that makes it difficult for water to flow through it. Replace a kinked hose with a new hose.
    • Sponsored Links
    • 3 Push on the washer door to make sure it is fully closed. The washer will not drain or spin unless the door is closed tight. Press the "Start/Pause" button after you close the door.
    • 4 Wait for about 30 seconds after you press "Start/Pause." The washer will not operate until it has been able to fully lock the door and restart the drain process.
    • 5 Run the clothes through a complete cycle again, making sure you use cold water if there are a lot of suds in the washer. Too much soap in the washer can make it hard to drain. Use high-efficiency or low-sudsing detergents on subsequent uses.
Feb 15, 2013 | Washing Machines
Filling with water then does not finish cycle
There should be a sensor on the door that tells it the door is shut. Check that this is being pressed when the door is shut. You should see it where the doormeets the washer and can use something to press it. Put your washing in spin cycle and press it if it starts spinning there is your problem( make sure the washer is empty ). If it still doesn't work you will most likely need a repairman.
Apr 18, 2012 | Candy Washing Machines
When I accidently push the start button when I mean to push the key button to open the door, the cycle will start again. Is there any way to stop it?
Push and hold down the start button again. The machine will stop. Turn to Spin (to drain the water that burped into the machine when you turned it on by accident). Hit start, let the drain and spin cycle complete. Hit the key button and you're all set.
Sep 24, 2011 | Asko W6021 Front Load Washer
Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Jan 26, 2010 | Zanussi FLE1416W Front Load Washer
Maytag MAH 24 does not drain and makes weird humming noise
i also have this problem. to get the door to unlock, just unplug the washer and it should open in a min or two. you will hear a click. you may have a mini flood but at least you can get your cloths out and bail out the water. my problem started when i began using a new detergent from Tide called total care. Still tying to get the pump to work.
Jan 25, 2009 | Maytag MAH2400A Front Load Washer
MACHINE RUNNIMG STOPPED SUDDENLY WITH THE LIGHTS BLINKING AND WE TRIED TO RESTART IT AGAIN AFTER DRAINING THE WATER THROUGH THE OUTLET PIPE &OPENED THE DOOR REMOVED THE CLOTHES AND RESTARTED IT AGAIN BUT...
turn on power switch,then press the spin speed button then push start, the water should drain then spin. if the water does not drain chech the drain pump button trap, located lower left front panel.
Dec 30, 2008 | LG WM-2277HW Front Load Washer
GE GFWH2400LWW Front Load Washer Logo
57 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
