Question about Frigidaire Dishwashers
E r u o code comes up and a clicking sound occurs
Dish washer has e r u o code and a clicking sound won't run any cycles
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Jean, thanks for your inquiry!
I understand that your Frigidaire dishwasher is displaying an error code of "E R U O". From the code you provided it sounds like the code is "UO" which means the vent is open. This could be a possible issue with your vent assembly, wiring harness, or control panel. I would suggest checking the vent assembly to assure it is opening and closing. If the vent is working properly I would advise you to perform a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. If this does not resolve your issue I would recommend having a professional technician out to perform proper repairs. This will prevent you from purchasing unnecessary parts. -Matt
Posted on Apr 30, 2015
  • Therese Faulhaber May 31, 2015
    HOw would I check the vent? I am getting the same code, my dishwasher is less than a year old.
Why is my dishwasher is stuck in the drain cycle
What kind of dish washer. It sounds like the switch is stuck try giving the dish washer a through cleaning.
Aug 13, 2014 | Samsung DMT400RHS Builtin Dishwasher
Hi my classique dish washer won't open,it is full with dishes ,how can i get in.thanks
f your Dishwasher is stuck in a cycle check the following
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. see the diagram attached.God bless you
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board.
Apr 05, 2013 | Dishwashers
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
Frigidaire dishwasher noticeably louder - circulation motor?
Try to position the machine, so that you can run the cycle and watch the dish washer. Remove the back panel and hear the sound of origination. Take suitable action as per your convenience. You can clean & replace the bearings if they are worn or replace as a whole unit.
Jul 06, 2010 | Frigidaire Dishwashers
Cloudy looking dishes?
Check water quality. If more of calcium or hardness is present, this situation could occur. As per manufacturers directions fill salt meant for dish washers, in the dispenser provide in the door( Inside). This will improve the quality of the water.
Fill rinse aid liquid as per the directions. Refer user manual.
May 25, 2010 | Kenmore 15922 Built-in Dishwasher
Clicking sound on Washer Spin Cycle
You are quite correct in thinking that it is the motor brushes that are worn.
You need to remove the motor and replace the brushes.
This will solve your problem.
Good luck.
Nov 28, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Runs but no water
Is the water cut off to the dishmachine. The first thing any dish washer should do at the beginning of the cycle is heat/fill with water. If you do not hear the water come on when you start the cycle, chances are that you have a bad fill valve, control circuit issue or no water supply to the dish machine.
Jun 08, 2009 | Dishwashers
Series 90 washer loud clicking during Slow wash cycles, Fast OK.
Turned out to be a loose electrical connector near the motor.  Plug was re-connected and secured with a zip tie to prevent another disconnect.
Apr 03, 2009 | Kenmore Washing Machines
Whirlpool Duet HT
its a door lock error a door lock error occurs if the door cannot be locked it will try to lock 6 times before displaying the error
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
112 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
