Question about Psi Garden
What is the corect Oil for Swiss Kraft 2500 psi pressure washer Brand New No paperwork
  • 991 Answers
10w30
Posted on Apr 27, 2015
  • Psi Master
  • 1,169 Answers
SAE30 for most engines.
  • 40 Answers
SOURCE: Pressure Washer trouble The Engine Won't Turn Over. What's Wrong?
well for starters if you let it sit all winter you the pump probably froz up and you might be able to get it un jamed by pouring in oil (any kind) in the hose inlet and let sit one night the try starting
Posted on Jun 03, 2009
SOURCE: oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
Posted on Apr 18, 2010
SOURCE: how to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
Posted on Apr 22, 2010
mkh5094
  • 145 Answers
SOURCE: What type of oil is needed for a Honda GC160 Power
The type of oil recommended for that engine is SAE 10W-30 and the capacity is 0.61 quarts. This and more can be referenced at the website at the end of this solution. I was able to find the owners manual of your particular engine.
http://www.northerntool.com/downloads/manuals/60594.pdf?cm_re=Product%20Page-_-Manual-_-Side
Posted on May 28, 2010
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
White smoke from spark arrester in a brand new Generac 2500 psi 196cc.
Have you mixed the 2 stroke oil in the proper ratio with the petrol?
Jan 06, 2015 | Garden
Karcher 2500 PSI Pressure Washer
Yes it is not an engine problem it is the high pressure pump that stopped working as I was power washing
May 27, 2014 | Karcher 2500 PSI Pressure Washer
Pressure washer pressure strong but pulsates/surges
check the engine oil and hydraulic pump oil if neither are the case you have a dirty batch of gas. You would need to drain the gas from tank and reservoir then put new gas in it. Water could be in it the filling station could of just got new gas and your gas could of been contaminated
Aug 08, 2013 | Karcher 2500 PSI Pressure Washer
Brand new will not start
is there a fuel shut off valve thats not turned on
Apr 03, 2012 | Homelite Workforce 2500 PSI 23 GPM Axial...
I WOULD LIKE TO KNOW, WHAT OIL TO USE FOR ANY KARCHER PUMP. Thanks. Richard V. Tucker
This depends on the brand of pump that you have, there are many different pump oils out there, getting the correct one is essential to increase the life of your pump.
Oct 06, 2010 | Karcher 2500 PSI Pressure Washer
Powerstroke pressure quit after 15 min. won't restart
Have a powerstroke gc 190 honda pressure washer the pressure is great for a little while then it seems to bleed off its a brand new machine. Not even 15 minutes on it.
Sep 05, 2009 | Karcher 2500 PSI Pressure Washer
Jun 03, 2009 | Karcher 2500 PSI Pressure Washer
Do I need to add oil to the gas for a Troy-Bilt 2500 power washer
This engine is 4-cycle. It does not require oil in the gas. Is the crankcase full of oil? Do you know how to check it?
May 05, 2009 | Karcher 2500 PSI Pressure Washer
Won't run with air filter on
I have a fairly new pressure washer with the same problem and discovered that because it was temporarily stored on its back (rather than upright), oil seeped into the air filter housing. If you look at the air filter it may not look like it has oil on it - especially if the oil is new. Mine runs fine without the air filter, but as soon as I put it in, it does the same as yours. I came across this site since I am looking to order a new filter. Hope this helps.
Jul 09, 2008 | Karcher 2500 PSI Pressure Washer
Honda 2500 pressure washer,
The oil in the front of the washer turned a cream color...like it has water in it. Any comments?
Apr 26, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
122 people viewed this question
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
