Question about Pool & Spa
I have a Baldor reliance super e-motor catalog number 84 Z 0 40 50 I do not have a wiring diagram for this motor it's a multi tap 230 volt through 460
  • 2,963 Answers
Try MFG website, or their customer service email, or
try manualslib.com
Posted on Apr 27, 2015
MOTORWIZJ
  • 1363 Answers
SOURCE: i'd like to know how to change a 115/230 volt pool...
IF YOU SEE ON THE LABEL ON THE MOTOR HOW TO CHANGE FROM HI - LO VOLTS . THATS ALL YA GOT TO DO ..THE WIRES HOOK UP NORMALY
Posted on May 29, 2010
  • 221 Answers
SOURCE: i have a sta rite 1 hp 115/230 motor i cant find
I assume you mean the white wire under the rear motor cover? If so Sta-Rite puts a wiring diagram inside this back cover. Hopefully it is still intact for you. Depending on your model and if it is wired for 115vac or 220vac will make a difference. I would suggest you go to the link I attached and look up your manual. The manual will have the wiring diagram for you.
http://www.starite.com/
I hope this helps you out. Please rate my response. thanks
Posted on Jun 17, 2010
  • 8404 Answers
SOURCE: I HAVE A HAYWARD SUPER PUMP SELF PRIMING MODEL :
What is broken in your motor? Don't count it out until you have your pool place give it a check. If it is dead, get a 1 1/2 Hayward Super Pump just like the one you have.
Thanks for your interest in FixYa.com
Posted on Aug 12, 2010
  • 368 Answers
SOURCE: need wiring diagram for BN34
Usually the wiring diagram is on the nameplat of the motor. I hope this helps.
Posted on Aug 16, 2011
SOURCE: Hi,i have a AO Smith S# c56a05a19 HP 3/4 ,type C, v 115/230 , Ph 1.0. I need to connect it to 230 volt. , can´t find a Wiring diagram. Can someone please help??
If the only difference is the HP rating, the wiring should be the same.
Posted on Feb 10, 2015
How does one configure for 115 and 230 volts?
It varies. You will need to contact the mfr.
Apr 06, 2015 | Pool & Spa
How do I change the voltage from 115 volts to 230 volts on a duel voltage motor?
When you open motor you will find schematics on inside of housing.Sometimes its just a switch you push from one side to another.
Sep 12, 2014 | Baldor VL3515 Single Phase C-Face Motor,...
Can I rewire a Hobart VCM-25 Mixer/Cutter 460v to run on 220/240v?
There is likely a nameplate with a wiring diagram inside. Without being familiar with the specific model, I can't tell you where. If you can find it, it will show both 460 and 230 volt configurations. Regardless, you will find inside the wiring box (where the conduit comes into the mixer) there are four wires corresponding to two windings - for 460 volts, the windings are wired in series. For 230 volts, they should be wired in parallel.
Jul 16, 2014 | Hobart Food Mixers
I need to wire up a baldor 3 phase motor 208-230/480 15hp and dont have the wiring diagram to know what wire is what or where to hook it to?
Hi Casey, I'm an electrician and can help you with this problem.
First, a disclaimer. Without the catalog number of the motor you have, or a wiring diagram for it, no one can tell you how to wire this motor with any certainty. With that said...
Nearly all single speed 3 phase motors have 9 leads (numbered 1 thru 9) and can be wired for either "high" or "low" voltage. Most of the time, high is 480 volts and low is 208/240 volts. Given that you posted the amperage as "41-38 / 19", I am 99% confident that 41 amps is at 208 volts, 38 amps is at 240 volts and 19 amps is 480 volts. Further below is the way to wire unless the motor manufacturer or name plate indicates differently. You will need to determine the voltage of the appliance this is going to be installed into. You should be able to find this on a name plate of the appliance - but it may provide a dual voltage spec here, too. If this is the case, you will need to *carefully* measure the voltage with a meter, or find out the voltage of the electric panel that feeds the appliance.
Once you have learned the incoming voltage, you will connect the motor as such when L1, L2 and L3 are the line voltage supply wires and wires 1 thru 9 match the numbers on the nine wires from the motor.
208/240 or "Low" volts:
Motor leads 4, 5 & 6 connected together and wirenut.
Motor leads 1 & 7 to L1 and wirenut.;
Motor leads 2 & 8 to L2 and and wirenut and lastly,
Motor leads 3 & 9 to L3 and wirenut.
480 or "High" volts:
Motor lead 1 to L1 and wirenut,
Motor lead 2 to L2 and wirenut,
Motor lead 3 to L3 and wirenut,
Motor leads 4 to 7 and wirenut,
Motor leads 5 to 8 and wirenut and lastly,
Motor leads 6 to 9 and wirenut.
The motor should be operated briefly or "jogged" to determine the direction the motor turns. If the motor rotation needs to be changed, simply swap any two "L" wires (swap L1 and L2, or L1 and L3, or L2 and L3). Test once more to verify rotation and when correct close the wiring compartment and complete the installation. Swapping the L wires will likely be much quicker and easier to do at the magnetic contactor instead of the the motor's wiring compartment. Either location is acceptable.
You should try to obtain the name plate data for this motor - if at all possible to to make sure of the voltage and wiring method. I hope this helps & good luck!
May 13, 2012 | Gb Electrical 100 Amp GE Load Center
T-30 wiring changing from 460 volts to 230 volt 3 phase
There are several items that will need to be changed or replaced. First rewire motor. Remove weather head cover. On the motor will be a tag that shows how to wire for 460 volts and 230 volts.Check the tag and present wiring to make sure they match. Then look at the 230 wiring and change wiring per motor tag. Again check the motor tag to see max amps at 460 volts and 230 volts. 230 volts will be higher than 460 volts. Check the starter (if so equiped) to see how many amps its rated for. You will probably have to replace the starter. Make sure it has a 230 volt coil. Next size the overload heaters for your amperage. This conversion is not a simple task unless you're familiar with electrical . Good luck!!!
Next the starter coil will need to be replaced with a 230 volt coil
Nov 27, 2011 | Ingersoll Air Tools & Compressors
I have a 1022w bench grinder with a missing capacitor. The baldor catalog doesn't list the part number or spec for the cap. Nor is there a wiring diagram that shows the connections to the cap. Anyone...
OC3012F12SPCYL OIL CAP 12MFD/370V
Thats number the neccesary part for your grinder 12 mfd think about a fitting size of the capacitor and model if you will know for sure here is the information to get .
http://www.baldor.com/brands/baldor-dodge/contact-us/contact
https://www.baldorvip.com/servlet/productInfoPacket/1022W.pdf
Jun 15, 2017 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
I m looking for a wiring diagram for an AC motors and how the capacitors are connected model baldor reliance part number fdl3612tm
Motor wiring- Capacitor usually gets two brown wires, 120 Volt Black= Power, White neutral.
220Volt usually no white Black =L1 Power, Red,Blue, Speeds. Yellow=L2
Nov 15, 2010 | Heating & Cooling
I need a multi 110/230 volt wiring diagram for a baldor non reversible motor
http://www.baldor.com/support/literature_load.asp?ManNumber=MN1240
You didn't give a model,here's a manual on their motors and the wiring diagrams,they start on page 2-9.It should get you there,or you can check out their other manuals on the same page .Take care!
Jan 13, 2010 | Target Portable Masonry Saw PS1411S...
Pool & Spa Logo
76 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
