Question about MERCURY / QUICKSILVER Mercury/Quicksilver Command 3000 Trim/Trail Switch 87-18286T31
I need a diagram for a Commander 3000 classic controller
What kind of fuses does a 1976 commander take on the outer breaker box
www.jeepforum.com/forum/.../commander-fuses-you-kidding-me-4161... May 18, 2007 - 12 posts - ‎8 authors Pray you never have to change a fuse in the Commander - at least the 06 model ...diagram in the book because they are kind enough to NOT give you a diagram near the actual box
Jul 20, 2015 | Cars & Trucks
Bike has 70,000 miles with power commander true duals and high flow air filter. The bike will not idle and will die if its under 1100 rpms. Runs good as long as throttle is turned.
With the power commander on it you will need to hook up a laptop with the program for your bike and what mods it has and set the throttle posistion from idel to wide open throttle.
Dec 11, 2009 | 2005 Harley Davidson FLHTCUI Electra Glide...
Removal of recovery commander
dude access the control panel..... if u see less than 15 icons then click on switch to classic view in upper left part of the window.........
click on add/ remove programs that is the 3rd icon from top....... select the program n click uninstall......
Sep 25, 2009 | Computers & Internet
Can't find fuse
easiest way to check is to locate the washer pump on the bottom of the tank, disconnect it, and hook a test light between the two terminals! One will be power and the other ground, so when you hit the washer button, if it lights up, you need a new pump! if it doesn't it is most likely in the switch, cause there are going to be other functions you are missing in your vehicle as the fuse is going to control more than just the w/washers!
Jul 31, 2009 | 2008 Jeep Commander
Need instructions for digitor commander universal remote control with touch screen
There's a copy of the manual right here on FixYa! http://www.fixya.com/support/p40387-universal_remote_control_mx_3000_lcd/manual-18057
Hope this is what you need!
Jul 09, 2009 | Universal Remote Control MX-3000 LCD...
Engine light on/off sporadically while riding. 2002 Ultra Classic. Fuel hoses in tank just replaced and oil pressure good. Possible oxygen sensor??
You don't have that on a 2002. Do you have a power commander on it? Sounds typical of the older style power commander ( IIIr ) one thing to pay attention to is does it do it under load? If it's not showing any historic codes and the bike rides fine, and you have a power commander 3r I wouldn't worry. It's normal. The older power commander lies to the ecm. Sometimes it gets confused and kind of glitches ( that's where the light comes from ) but if it has running issues to I would take it to a shop to find out what the codes are and go from there.
Jun 26, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
Location of 2008 Jeep Commander fuse panel
Glad to help...sometimes even the book needs a bit of translation!!!
Jun 16, 2009 | 2008 Jeep Commander
MERCURY / QUICKSILVER Mercury/Quicksilver Command 3000 Trim/Trail Switch 87-18286T31 Logo
258 people viewed this question
Top MERCURY / QUICKSILVER Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a MERCURY / QUICKSILVER Boating Expert? Answer questions, earn points and help others
