Question about Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top Load Washer
My Samsung washer does not drain or spin, what can I do?
Ran the washer under perm press and it stopped at 9min spin cycle and will not drain
  • 343 Answers
Hi Anil.
The most common cause for the machine not to drain is a problem with the drain pump.
It could be that there is something in the hose which is blocking it or something in the pump filter doing the same thing.
Depending on the age of the machine it's also possible that the pump motor needs to be replaced.
Check that the hose is not kinked by the machine being too close to a wall.
I hope this helps.
It's not a big job for an experienced serviceman.....
Cheers.
Nomess
My Samsung washer does not drain or spin, what can - 25668185-dncsfhauojlbn5rxzmouzunk-2-0.jpg
Posted on Apr 28, 2015
    Genius:
  • Samsung Master
  • 1,585 Answers
Check pump for blockage
Posted on Apr 27, 2015
3 Suggested Answers
SOURCE: samsung silvercare washer stopped working, won't unlock
here is the most common cause for this problem, according to the Samsung repair guy that was here to fix mine today.
On these washing machines it is possible for some debris (in my case it was a small screw from my packet) to make its way passed the drum and into the pump. Once this happens then the impeller of the pump becomes restricted or completely blocked which will result in the above mentione symptoms.
On some machines the pump is on the front, on others at the rear of the machine. In my case it was at the rear, removing the rear panel will allow easy access to it. Have a bucket ready, when the hose is removed from the pump the water will be draining from the machine. 3 bolts and a hose clamp on the inlet and another on the outlet hose. Disconnect the electrical plug from the pump and you can remove it from the machine for cleaning. A very easy job, requiring little skills and not much in terms of tools. (make sure machine is UNPLUGGED from AC outlet)
Remove obstruction(s) from pump and reinstall in reverse order of disassembly. The guy says these pumps are really tough so if you hear it buzzing, trying to go while it's jammed it's a good sign it will work. If not, replacement will be necessary.
Cost me $140. Could have been worse I suppose. Advise: Empty pockets BEFORE washing clothes...
Posted on May 26, 2009
SOURCE: Samsung Front Loader wf306law took off back panel
I found MayTag has a full report on this washer. https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8169153c018494398525729c0057a4d2/$FILE/Samsung_Frontier_Washer.pdf
The part number is DC97-10417A and can be ordered at samsungparts.com
http://www.samsungparts.com/Products/Parts_and_Accessories/PID-DC97-10417A.aspx
Posted on Jun 21, 2010
Washer wont spin or drain
Yes, you can check the LID switch as it needs to activate the program to move forward. If the water fills up and there is no wash cycle, check if the motor hums, if so check the capacitor, check the friction on the spindle/drum. If the spindle does not agitate with movement the assembly must be reset.
Jan 23, 2013 | Washing Machines
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
I Have a Samsung Washing machine model number WF218anb. I can't get it to go through the complete spin cycle. I have taken all the clothes out and put it on spin only and it stays on 9 minutes for a very...
Wow, I have the exact same problem. I reported it under my extended warranty, and the repair shop replaced the drum/bearings without fixing the problem.
I was looking at Consumer Reports today, and some of the people there reported the same thing. Interestingly, some also reported that Samsung told them they couldn't use this washer in places where the temperature got below 60 degrees because it's temperature sensitive, somehow.
But the overwhelming reports on this model are good. I got the whole sequence to run by putting it on perm press -- it spun OK!
Jan 31, 2011 | Samsung WF337AA Front Load Washer
The washer did not drain
if its a whirlpool or kenmore, it will not drain if it thinks the lid is open. the lid hits a paddle in the top that actavates a switch. it should click when closing the lid. You may just need a new lid switch.
Dec 23, 2009 | Washing Machines
The spin cycle is not functioning
electronical fault not motor but the controil unit is no working ok ....
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer will not stop!
call a service technician to get a proper diagnosis and quote then decide to fix or junk
Jun 10, 2017 | Kenmore 98702 Stacked Washer/Dryer
Maytag Atlantis MAV7200 doesnt drain at end of rinse goes to OFF
It sounds like it may be the lid switch. It may be as simple as adjusting or tightening. But ultimately it may need replacement.. Hope this helps
Apr 04, 2009 | Maytag Atlantis MAV7000
Frigidaire washer machine stop in the middle of the cycle
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Feb 28, 2009 | Frigidaire FWS833A Top Load Washer
Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top Load Washer Logo
886 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
