Question about Primus BrewFire Coffee Brewer Md: P-460010
Is there a repair manual for a Brewfire coffee maker
Battery trys to light but gas does not seem to get through so burner won't light
I have had my Kuerig coffee maker for over a year now which I believe means it's no longer under warranty. However, I paid quite a lot for it so I'd really like to see if I can have it repaired...
unfortunatly keurig treats any home model as throwaway once warrenty is up. They even do the same with mostcommercial models. By the sounds of your problems its time for a new one. sorry. try for a b145 or b150 they are a little more robust.
Sep 05, 2011 | Keurig Platinum B70 Coffee Maker
It won't brew when it says its brewing. Why won't it brew my coffee? Just seems to be really slow and I have only had this coffee maker about a year.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 18, 2011 | Keurig Platinum B70 Coffee Maker
The nurses use the Bunn VPR 2 burner coffee maker. They have succeeded in having horrible hard water residue all around the outside of the pour area. Vinegar doesn't seem to clean it off. What would...
This can be solved by running vinegar and water through unit and here is more information.
Maybe this will help you, with information, trouble shooting and contact numbers.
BUNN VPS COFFEE MACHINE MANUAL
http://www.bunn.com/pdfs/commercial/manuals/10053.0000.pdf
Also if you could rate this and some kind words would be great. Also here is my direct link to my pages of expertize that might help you. Visit me anytime at :
http://beta.fixya.com/users/mc1bean
Thanks So Much, Mike
Jun 16, 2011 | Bunn VPR Coffee Maker
Jura c9 on out of box start up won't leave rinse cycle and enter heating mode. Checked rotary dial but it seems fine.
You need to be patient and keep pressing the rinse button. I took a few water tanks of rinsing before it clicked over to heating mode. The manual and DVD need to mention this!
May 13, 2011 | Jura Capresso Capresso IMPRESSA C9 One...
My KF 180, Type 3115 Braun Coffee Maker stopped working, no heat, no purking but red light is on. I'm trying to open the bottom cover, have removed the centre screw but still can't get past the clips. I...
I have the same problem and even though I was able to disassemble the unit + get to the heating element, I fear I won't ever find a replacement part. Element is def bad; checked w/ohm meter across element - OPEN.
Like everything else we buy, coffee makers are throwaways when they fail so no one sells repair parts.
SAD!
Mar 13, 2011 | Braun FlavorSelect KF 180 Coffee Maker
Seems I have no power to either heater...I always leave the rear heater on all the time , but all is dead today ..
It sounds like your heating element is burned out. This would affect both burners. You can get a quote to have it repaired, but from experience I can tell you that it will be less expensive to replace the entire coffeemaker.
*Heating elements only have a certain "lifetime" (like lightbulbs). You might try not using it constantly if this is possible.
Nov 20, 2009 | Bunn NHB Coffee Maker
Flashing Blue Light
I have found that if I turn off the machine for a few seconds and turn it back on, the burner seems to re-energize strongly and the water heats and a few minutes later, it seems as good as new. I know that this is not the the technical solution to the true underlying problem, but it keeps my old machine in the game.
Mar 17, 2009 | Keurig B100 Coffee Maker
Water over filling pot
The procedure for setup of this coffee maker can be found here -
http://www.bunn.com/pdfs/commercial/manuals/10613.0000.pdf
Please email if you have additional questions.
Feb 02, 2009 | Bunn Automatic Coffee Brewer CWTF15 1
Bloomfield coffee maker repair
It depends on where you live if there are any techs available.
Feb 20, 2008 | Coffee Makers & Espresso Machines
Primus BrewFire Coffee Brewer Md: P-460010 Logo
44 people viewed this question
Top Primus Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Primus Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
