Photocopier works and engages and spits out paper but nothing is on paper
The scan engages and paper ejects from paper feed but it is blank, ink is full
    Top Expert:
  • 6,702 Answers
And all nozzles are open? did you try to print a printhead check? Just to see what nozzles are working.
First run one or two print head cleaning cycles. Not telling us the brand nor the model, makes it impossible to tell you how to do on your printer.
Posted on Apr 27, 2015
PAPER FEEDS INTO PRINTER BUT COMES OUT BLANK
HP DeskJet f4280 Spitting Out Blank Paper. - HP Support ...
h30434.www3.hp.com > Printers & All-In-Ones > Print Issues
Solved: I can hear it printing, but the paper is blank when it's finished. ... Mark as New; Bookmark; Subscribe; Subscribe to RSS Feed · Highlight · Print · Report ... green checks say every thing is good to go, but the test print comes out blank,. ... Reinstall the cartridges into the product, and then gently close the cartridge door.
my printer is printing blank pages, and i just changed ink
Nov 18, 2015 | Office Equipment & Supplies
I have a Sharp Z50 photocopier. When I feed the paper in manually, it prints but gets stuck and will not eject.
Check if theres no particles on the paper path.check the size of paper.check the settings.also check all the feed rollers .check the sensor ,connectors and mechanism.
Dec 22, 2013 | Sharp Z50 - Z88 Toner
My HP F4280 says it's printing but the pages come out blank. How do I get them to really print??
uninstall the reinstall the driver for the printer from the HP web site for that printer and the win operating system you are using
Jan 01, 2018 | HP DeskJet F4280 All In One Printer InkJet
C5180 sounds like printing then jams
try aligning the heads, and cleaning ink cartridges
Nov 18, 2012 | HP Photosmart C5180 All-In-One InkJet...
Epson Stylus CX4800 prints blank pages
Alex_Garton:
I'm not familiar with the Epson Stylus printers, but I'm going to hazard a guess. If the paper does not move at all, the paper pickup feed mechanism is at fault. One of two methods is used to pick up the sheet. Either the front lower portion of the tray is lifted up to force the top sheet into the feed roller, or the feed roller is connected to a drop-swivel to drop the feed roller onto the top sheet of paper. You'll need to look carefully at the feed mechanism to determine if a gear or clutch is failing. If the paper moves into the machine about 1/2 inch and then stops, either the first paper feed roller past the pickup roller may be at fault. Also check to see if the paper sensor between the paper pickup roller and the first feed roller is working properly.
Sep 22, 2012 | Epson Stylus CX4800 All-In-One InkJet...
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
My printer/photocopier won't print. It's a problem with the machine itself as even using the photocopier by itself won't work. It takes paper in and spits it out slowly like it's printing, but the paper...
See articles here and here to troubleshoot this problem...(possible also here)
If that doesn't yield results, reset the printer by following instructions here and/or here.
It may be necessary to reinstall the print drivers and software in this case...see here and here for examples...
The home support page for your model here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 29, 2009 | HP Photosmart 2575 All-In-One InkJet...
Ink
is it the exact ink replacement or did you have a company refill it ?
Robert
Aug 29, 2008 | Canon PIXMA iP1600 Printer
Printer not printing
Try this. Push the copy and cancel buttons together for about 3 seconds. Then release. The printer should push a blank piece of paper through. Try to print.
Jul 17, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer won't print.
sounds to me like perhaps the printer drivers are really unhappy. you'll need new ones from www.kodak.com
http://tinyurl.com/6qcpgy
Jul 01, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
54 people viewed this question
k24674
jasbo
jasbo
