Question about Directed 434MHZ Remote Control
Cherche code pour pvq32vgb
Cherche code pour tv vision quest remote is time wargner
Have a Panasonic remote need to program a Vision Quest TV
I don't know whether Panasonic remote have set-up code for Vision Quest TV. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Oct 20, 2016 | Panasonic Televison & Video
I have a vision quest tv and lost the remote and the buttons on the side won't switch so I need a code for my universal remote
Check these codes. If you wish to get more codes, check this site.
0664 0691 1233 0529 0404 1939 0067 0586 0039 0246 248 0247 0481 1167 1938 0910 1248 0906 0895 0728 744 0736
Feb 10, 2013 | Televison & Video
I have a BELL remote for my visionquest tv - i need the 4 digit code
from what you are saying I would think the universal remote is not comparable with that unit. they say universal, but they don't always cover ever model etc. check that the remote has your brand/model of TV listed.
Dec 28, 2017 | Proscan 26LB30QD 26 in. LCD HDTV
Je cherche un code pour telecommande one for all urc-4041B01 pour television jvc merci
Bonjour
Codes de configuration pour JVC TV avec la t?l?commande URC4021 sont
0463, 0053
OK.
Aug 18, 2011 | Universal Remote Control URC4021 Universal...
Tv code
The Innovage Jumbo remote control manual does not list any TV's by the manufacturer Vision Quest, but that does not mean your TV is not compatible with another brand's control codes. I recommend using the auto-search function to see if any of the remote's TV codes work with your set.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Dec 07, 2009 | Innovage Jumbo Remote Control
Need a universal remote control code Vision quest Van gogh 42
According to my information this TV does not have any published universal codes as of yet. A call to the manufacturer results in:
" Just use the remote that came with the TV...it's too new to have the codes yet"
Not very helpful are they? IT's a nice Tv for the $$..guess customer support is sacrificed when we try to save some $$.
May 23, 2009 | Emerson EWF2004 20" TV
Vision Quest Van Gogh 32 " plasma TV. What are remote codes?
Codes are stored in the remote. If you use a universal remote you can try its code search (or equivalent) feature to find something that will manage some or all functions of your TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Jan 24, 2009 | Emerson EWF2004 20" TV
Televison & Video Logo
44 people viewed this question
Top Directed Televison & Video Experts
ted dux
Are you a Directed Televison and Video Expert? Answer questions, earn points and help others
