Question about T-Mobile Alcatel One Touch Evolve 5020 Unlocked AT&T - International
Sim slot locked permanently
How do i unlock it
HELO!PLEASE CAN I GET A HELP? MY LUMIA521 CAN'T READ SIM CARD.
Remove back cover and remove battery and check sim is properly fixed in side sim slot or not. If sim is loose inside sim slot then put some paper packing make it properly fixed also remove sim and rub with cotten lock the golden part of the sim and insert again. Also check the sim in another mobile and if in that mobile sim also not recognized then there is issue with your sim card replace it.
here is how to sim unlock mobile http://mobile-cellphones.blogspot.com/2016/06/android-smartphone-sim-unlocking-details.html
Jul 21, 2017 | Cell Phones
I bought a used cat B 15 . The phone says the sim card slot is permanently locked . I do not know who the previous provider was . How do I unlock the phone ? Please help .
If the sim is locked that came with the phone that is not a issue you need worry about. The phones are gsm phones so then new carrier you take it to will have to use sim cards as well. Being the phone with you to the carrier to see if it works on their network before signing up.
Feb 12, 2017 | Cell Phones
Slot permanently locked
Hi Alison,
Try this site..
http://sim-unlock.net/simlock/Alcatel/OT-5020T/
Choose your model and follow the steps. You may have to purchase a code to unlock it.
I would strongly suggest you take it back to where you bought it as you locked the phone by inserting a different SIM. You activated the security feature to prevent it from being used. At this point you need to get the vendor to unlock it... try calling the place where you bought it, and see if they can assist first. Best of Luck!
Feb 25, 2014 | Alcatel Cell Phones
Inserting sim card in LG sliding phone
You can insert sim card in LG sliding phone on sim slot.After inserting it displays any error message saying "Wrong sim" or "Incorrect sim" or "Emergency calls only", etc., then your phone is probably network locked.To unlock it,visit the site WickedUnlock.com here they are providing the unlock code at reasonable cost with easy step by step unlocking instructions and unlock it.This is the fast and permanent unlocking method.
Source:http://www.wickedunlock.com/lg/rs16wp8/
Jan 16, 2014 | Cell Phones
How do you change the sim card Samsung E2210L
To insert simcard in your Samsung E2210L you need to take care of two things..one is the sim size and another is whether the phone is unlocked to accept all sim network.Regarding the sim size (this uses a Mini-Sim) if you do not have the desired sim size there are options like the apt sim adapter hardware that is available in the market.If you are not comfortable with the above you can approach your respective service provider and order for the desired sim size.
To unlock your phone you can approach Unlocking4u.com and by submitting the country and network to which the mobile is locked to you will be able to remove the restriction from the respective network.This will be a permanent unlocking solution.
Once the phone is unlocked you can use insert the sim.To find the sim slot remove the back panel and it will be above the battery.
Note down the correct position and insert your sim in the same position.
Jul 06, 2013 | Cell Phones
How do you unlock a slot when its permanently locked in a dual phone
my phone alcatel orange royal permanent blocked. l buy in another country have a code remain 10times and then blocked
Mar 16, 2013 | Cell Phones
Sim unlock
Your Phone brand is Blackberry Phone?Because Blackberry has 10 unlocking tries...If you miss the Chances your phone get permanently locked...So you have to unlock it....Visit the site Wickedunlock.com/unlock-your-phone/rs11wp2/ get the unlock code and unlock it from network lock...
Jul 30, 2012 | Cell Phones
My phone says the incorrect unlock code was entered 10 times. this phone is permanently locked and cannot be unlocked. what can i do
Nothing, once the SIM card is locked, it is permanently locked and you need to get a new SIM card from your cell phone service provider.
Apr 16, 2011 | Cell Phones
T-Mobile Alcatel One Touch Evolve 5020 Unlocked AT&T - International Logo
43 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
