My Sf-p160jjs washing machine is indicating an F9 error code. What's wrong?
    New Friend:
F9 error code.,there is so many ways how to fixed that error.just try this maybe can help you,. Check wiring sometimes loosen from the connector or totally cut..check the pump motor and last check the clutch trouble shoot if the clutch in normal position must be the agitator only moving if the cluth in up position must be spin or drums the one moving.
Posted on Aug 27, 2016
    New Friend:
  • 25 Answers
F9 pump failure code for some of the Hitachi units.
Posted on Apr 27, 2015
4 Suggested Answers
SOURCE: Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Posted on Dec 19, 2010
ZJLimited
  • 17970 Answers
SOURCE: washing machine model no SF-160GJ
it will not let you unlock the door because the machines full of water?--the machine will not finish its cycle because the vacume switch is still detecting water. The water will not drain because the pump is blocked with something , probably a wire from your underwire bra, all you can do is undo a pipe undernieth and let the water drain away and take the pump to bits? There may be an inspection cap somewhere on the front at the bottom.
Hope helps.
Posted on May 15, 2011
SOURCE: Hitachi SF-P95FJ WASHING MACHINE ERROR
if you have Hitachi nw-d8ax f1 error check water sensor f3 error check rinse filter f9 error do not know where the error but I did repaired, remove back panel and right hand side inside polithine cover find blue connector its with 2 wires remove it and switch machine it will give f3 error with sound reconnect the socket its started working
mail me if yours working I will give you more tips nava@netintec.com cheers
Posted on May 17, 2011
Hitachi washing machine. Model:SF-P90P Fault code F9"
F9 can happen when have wiring shortage,please do checking for wiring especially at bottom of drum maybe have wiring was shortage when have insulation tear or cut,just fix it reconnect by terminal connector or solder it and apply electrical insulation tape,hope this information can solve your problem thanks
Aug 20, 2016 | Washing Machines
I have hitachi washing machine appear lode model SF-100JJS error p9 please tell me what is solution, ?
That is an F not a P. The codes are generic. It is a pump clog, block, or defect.
SOLVED: I am getting F09 error code - Kenmore Elite HE3 Washing ...
https://www.ifixit.com/Answers/View/47460/I+am+getting+F09+error+codeMar 20, 2011 - The F09 error is a water pump problem, either clogged pump, or pump malfunctioning, ... The Kenmore Elite HE3 is a washing machine by Kenmore. .... hi i have f9 display always when i start machine can you help with this. hitachi washing machine f9 error Google Search
May 09, 2016 | Washing Machines
Hitachie washing machine SF-95CJ. without completing the
Owner's manual? trouble shooting? Should have errore codes
No manual? try http://www.manualslib.com/
Mar 08, 2015 | Washing Machines
Model:SF-95CJ F9 FAULT CODE
my hitachi model SF-95 CJ is washing machine show F6 ,C4, F4 FAULT CODEcleck
Feb 11, 2012 | Washing Machines
Hitachi SF-P95FJ WASHING MACHINE ERROR CODE F9
Oct 29, 2010 | Washing Machines
Jul 29, 2010 | Washing Machines
Hi i have hitachi SF-110CJ waching machine how can i cotrol the water temperature before starting the waching process
i have an error code f9 and washing machine stop spinning and dont turn , how can i fix it and where can I buy spar parts , i am from lebanon , west bekaa
Jan 19, 2010 | LWScientific LW Scientific Variable-Temp...
Washing Machines Logo
482 people viewed this question
Top Washing Machines Experts
