Question about Dishwashers
How do I plug the garbage disposal after removing the dishwasher?
    Top Expert:
  • Dishwashers Master
  • 45,245 Answers
They make a cap for it but I do not know the name of it . call a local plumbing shop .
Posted on Apr 27, 2015
How to remove drain plug from garbage disposal
Good Afternoon Dogman85,
I understand you want to know how to remove the drain plug from your garbage disposal, regarding your Frigidaire dishwasher, model# PLD2850. I suggest contacting the manufacturer of the garbage disposal. They will be able to better assist in removing the drain plug from your garbage disposal. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire 24 in. PLD2850 Built-in...
We just replaced our garbage disposal and now the dishwasher won't drain. I order a drain pump and it still won't drain.
Make sure that the air clear on top of the sink is clean and clear all the way through. Sometimes in replacement silt and other garbage clog this up and keep it allowing water to drain properly.
Dec 23, 2010 | Whirlpool Dishwashers
Dishwasher will not drain totally after it has finished the cycle. I recently had a new garbage disposal installe and every since then the dishwasher will not drain. Is it something to maybe do with the...
disposal has a plug in it where the drain line from d/w hooks up remove drain line from disposer and stick a screwdriver in hole to remove plug remove plug from inside disposer with a pair of needle nose pliers that should take of it
Oct 26, 2009 | Dishwashers
My quiet partner 4 will no longer drain, I recently replaced my garbage disposal & the problem began after that.
There is a plug you have to remove on the garbage disposal where you hook up the washer drain hose.
Check the instructions with the disposal.
You'll have to deinstall the garbage disposal, remove this plug and reinstall.
May 05, 2009 | Dishwashers
Not draining
Did you remove the plug in your disposal so the dishwasher can drain???
May 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Apr 07, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher won't drain
remve the drain line connected to the garbage disposal take a flat blade screwdriver insert it into the garbage disposal and hit the end of the screwdriver , the plug will pop out
to verify after hitting it stick the screwdriver back in if it has not removed the plug do it again
Apr 04, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Kenmore Built In Dishwasher
the obstruction they talk about in the disposer, its where the connection for the d/w drain is made, there is a "knockout" plug within the drain line connector( in case you dont have a d/w) that would need to be removed before the d/w will drain. can be popped out with a good smack with a screw driver, the plastic knockout will land within the disposer. disconnect power and remove the plug, it will not break up and wash away
Mar 25, 2008 | Kenmore 15121 Built-in Dishwasher
Dish washer
The drain in to the garbage diposal is clogged.  Remove the drain hose from the dishwasher and clean the hose.  Also check the inlet to the garbage disposer and clena it.
Oct 28, 2007 | Dishwashers
Installation
It sounds like you have connected your dishwasher to a garbage disposal.
  1. The 2 hoses provided with your dishwasher connect together.
  2. You run the drain hose through a hole in the bottom/back of your cabinet, then up to the top of the cabinet, then connect it to the drain on the garbage disposal. (The reason that you run your drain up to the top of the cabinet is: This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher.)
  3. Be sure to knock the plug out of the drain of the garbage disposal. A garbage disposal is designed to work with or without a dishwasher. The plug is in the center of the drain. The best way to knock this plug out is to pull the garbage disposal, and with a flat screwdriver, knock the plug out.
  4. Then remove the plug from the disposal. Reinstall the disposal.
  5. Install the drain hose. The drain hose will connect right up to the disposal using the clamp provided with the dishwasher.
This should help you. If not please attach more info.
Please rate this solution
Sep 09, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
