Question about Samsung Washing Machines
How do I correct a 4E error?
I've tried turning it on and off and dosen't seem to have a split or hole in any of the hoses.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • 61 Answers
Follow the link below or carry out the instructions.
http://www.samsung.com/ae/support/skp/faq/442142
To solve, please check the following:
1. Check if the water tap connected to the washing machine is open to full.
2. Check if there are no kinks or bents in the water hose connected to the washing machine.
3. Check if the water hose mesh filter is not blocked.
Note: You may need to clean the water hose mesh filter twice a year.
Cleaning the water hose mesh filter:
1. Turn off the water source that supplies water to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pari of pliers, gently pull out the mesh filter from the end of the hose and then rinse it under.
4. Water until clean. also clean the inside and outside of the threaded connecter.
5. Push back the filter into its correct place.
Posted on Apr 27, 2015
    Genius:
  • Samsung Master
  • 1,585 Answers
Try unpluging for 15mins re try
  • 3 Answers
SOURCE: Samsung Washing machine fault
Had the same problem - I posted full description in another 4E post - But my problem was a crack.split in the pipe to the sensor
Posted on Jul 11, 2008
SOURCE: 4e code
i have problem error 31( E31) please advice me to solve this problem
Posted on Apr 14, 2009
blueextc3221
  • 15935 Answers
SOURCE: My 7kg samsung washer always flashes error code 4E
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: 4E showing on Samsung Washing Machine
blueextc3221
  • 15935 Answers
SOURCE: 4E error....samsung J845
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
I have a samsung front loading washer and I am getting error code 4E and cant find book help
Water supply problem causing a 'time-out'.
The 4E (4C) error is displayed on the panel of my washing machine ...
www.samsung.com/.../the-4e-error-is-displayed-on-the-panel-of-my-washing-machin...
  1. Cached
4E (4C) ERROR. The 4E (4C) error indicates that the washing machine has detected that there is a problem with the water supply. The most common reason for this error is a blocked or kinked water supply hose.
There are videos here
samsung front load washer error codes 4e Google Search
Apr 05, 2018 | Samsung Washing Machines
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
4e on my samsung front load WF42H5000AW
A 4E code indicates your machine is not sensing that it is filling. The corrective action is to check that water supply is on and has adequate pressure, hoses are not kinked, and that filters on the inside end of the water valve are not clogged.
Nov 21, 2016 | Samsung Washing Machines
I am getting a 4E error message on my Samsung frontloader WF8802RSW. What does this mean? Thanks
4E refears to a water supply issue.
pull machine out, turn off the water and remove the inlet hose. put hose in a basin and turn on water, if water flowing the fault is on the machine end. although if the water pressure is very low the machine can time out filling and this will cause an error code. always try to have machine plumbed into the mains supply, not the tank in the attick.
where you unscrewed the inlet hose from the machine check for dirt or grit, if dirty get a pair of pliars and pull out the mesh and clean out. refit inlet hose and your sorted.
if not this its a new valve you need
Jun 25, 2011 | Samsung Washing Machines
2008 Samsung front end loader develops a 4E error
Jul 12, 2010 | Samsung WF337AA Front Load Washer
Error 4E + timer countdown is delaying
Sep 02, 2009 | Samsung WF337AA Front Load Washer
Aug 23, 2009 | Samsung WF203ANW Front Load Washer
4E code keeps apearing
Jan 29, 2009 | Washing Machines
The manual says Mke sure the soucre water faucet it turned on. Check the water pressure. turn off water and unscrew the hose from the back of the washing machine. it says to pull out the nesh filter from the end of the hose and ricse it under water until clean with a pair of pliers.also clean the inside and outside of the threaded connector. push the filter back into place, screw the hose back onto the washing maching. turn on the faucet and maike sure the connections are watertight.
May 15, 2008 | Samsung WF203ANW Front Load Washer
I have foud a solution 4E error for my Samsung WD7101CKW. Water that comes inside washer is splitted in splitter with valves. One of these valves has a red label on it - this is a valve with restrictor of flow inside. This restrictor is used to limit flow speed mainly for testing purposes of pressure/water level sensor. Because of that restrictor (red cap with two holes of 0,5 mm diameter) blocked flow too much, after some time washer controller thinks that water has too low pressure.
Unplug washer, disassemble hoses from valves, disassemble valves from the washer (screwdriver needed), drill both holes in red restrictor to 1 mm (use 1 mm drill or just big needle). Assemble in reverse. Will work :)
Greetings - Thomas
Jan 16, 2008 | Samsung WF203ANW Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
