Question about Coffee Makers & Espresso Machines
Dispenses very little CREMA. Is there something to adjust?
Sometimes a very small crema is present on top of the coffee
  • 352 Answers
Rule of thumb - espresso machines deliver a shot of coffee in 25 to 35 seconds.
If there is no crema and the coffee comes faster:
  1. There is not enough coffee in the portafilter (7 grams per shot).
  2. The coffee is not tamped enough (about 30 lb pressure on the tanmper handle).
  3. The grind is too coarse.
If the above does not "fix" the crema problem, post again and include make and model of the machine and type of portafilter.
Good luck.
Posted on Apr 27, 2015
I just bought this Office Control model. I use espresso grind, softened water, and a heavy tamper. I fill the filter to within 1/8 in from the top, as advised. The espresso has a thin skin of crema,...
These two problems can be related.
If the water temp is low, You are NOT going to get a good extraction (almost no crema).
wait like 20 min. before using the machine, And if there is a pressure gauge (on the machine) it has to be in the 1 to 1.2 range.
Always warm up the portafilter/handle before use.
If the water is hot and there no crema, Adjust the grinder.
The group temperature is about 212f for commercial espresso machines.
Jan 14, 2011 | EXPOBAR Office Control Espresso Machine
No 'real' coffee taste or crema - despite following instructions
Set the machine for the finest coffee and the least water.
You should get a decent espresso.
For a regular cuppa, keep the settings the same and make either a medium coffee combined with a small coffee (jolt) or
make two small coffees.
I have this machine and the crema is nice at this setting.
Aug 01, 2010 | Miele CVA615 Espresso Machine
Solis Crema SL90 NO HEAT
Hi
There can be a couple of things. The heating element could be bad. Check with an ohms meter. 12 - 16 ohms between the element terminals. You could have a bad power board. There is a solder connection that seperates and can be resoldered. Look for a small bulls eye where 3 solder connections make a triangle in the top left side. A little heat and new solder can fix it sometimes but don't put too much solder on or you will short the connections. If this doesn't fix the problem you need a new board.
Jan 21, 2010 | Solis Crema SL-70 Espresso Machine
SAECO fully auto Traditional Very little crema
The crema is created by reducing the grinding to more fine so the coffee will run slower around 20 sec. Inside the coffee bean container their is un adjust control and with special tool you can turn it to grind the coffee to more fine.
Jan 03, 2010 | Saeco Royal Professional Espresso Machine
No Crema
Hi
If your talking about the tube on the brew unit, you are probably missing the spring or if you have the spring its upside down. Again if this is what you are taking about is the check ball at the bottom of the spring(ball in first, small end of the spring on the ball, O-ring, then the manifold)These things are important for creama.
Nov 08, 2009 | Saeco Magic De Luxe Espresso Machine
Why doesn't my Krups espresso maker produce crema when I brew espresso? Very little is produced and gets blasted away by the time it's don't brewing.
Crema is the goldish brown top that goes onto the top of the coffee once it is dispersed from the espresso tap and flows naturally as part of the coffee when coffee is made. Im not sure what you mean "blasted."
Perhaps you should flush through the machine with cold water a couple of times beforehand and also consider a descaling kit - check your manual or Krups if there is one for this model.
Crema isn't produced by any machine though.
Jul 25, 2009 | Krups XP 4050 Espresso Machine
Crema attachment
It is optional, if your coffee is fresh, you would not need the attachment. If your coffee isn;t the freshest, the attachment comes in handy to create the crema affect
Aug 20, 2008 | Gaggia Carezza Espresso Machine
UNABLE TO GET GOOD CREMA ON TOP OF COFFEE:
It could be. Your grind should determine the amount of time that it takes the shot to pour. Standard is 18 - 30 seconds. I prefer 25. If it only takes 10 sec, your crema will be weak.
Are your beans fresh? Older beans produce less crema. By old, I mean more than a month if properly stored.
What is the temperature of you shots? The water coming out of the head should be about 195 F which makes the shots roughly 170-185. If it's too cold, you'll get worse crema. It's also possible to have mostly steam in contact with the grounds which will give the same results. Both indicate other problems.
Make sure your group head screen isn't clogged. And make sure everything is very clean, especially inside the handle (under the grounds basket - just pop it out with a screwdriver). Good luck!
Dec 16, 2007 | Rancilio Silvia Espresso Machine
Coffee Makers & Espresso Machines Logo
113 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
