My laptop remains active after shutdown. Fan and green light in front showing power. if it is left as same the whole battery discharged.
    Top Expert:
  • 10,875 Answers
Go into power settings and change what happens when power button pushed from go to sleep to shut down
Posted on Apr 27, 2015
sandrew
  • 2961 Answers
SOURCE: Unable to start my Laptop (Acer Ferrari 3400)
This could indicate power or motherboard failure, you are wise to e-mail the acer technical dept. http://support.acer-euro.com/request/uk/index.html
Posted on Jan 05, 2007
  • 13433 Answers
SOURCE: Acer Aspire 3100 Laptop Monitor will not turn on
1. Mainboard failed
2. Vga adapter failed
I wouldnt be suprised if the vga failed, my acer broke down on me 2 times, on the 3rd time it was too much and I sold the laptop.
Posted on Mar 28, 2008
patemi
  • 366 Answers
Try Screen switch function to switch from Internal screen to External monitor to Both.
Normally FN + F4 (on Compaq or FN + F7 on Lenovo check the Function symbols on your Keyboard: allow few seconds after command to refresh configuration.
try Safe mode also. to check if display shows in VGA format.
Posted on Dec 26, 2008
El Geek
  • 149 Answers
SOURCE: Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
Posted on Jun 02, 2009
  • 130 Answers
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Posted on Jun 21, 2009
Battery will not charge. replaced battery worked untill discharged, works off ac ok but light to show battery charging on computer (charger led sold and green, checked in control panel/power options/...
Go to your laptop's manufacturer's website and download the latest chipset drivers for your laptop. They will tell your laptop how to manage the battery.
Oct 17, 2013 | Dell Latitude D600 Notebook
Hi ive got a hp g70-212em laptop that over heated, i shut it down as the fan was clogged and wasn't cooling it. i cleared the floof from the fan and it now spins freely again but the laptop will not...
1st try this.....discharge ur laptop battery then open safe mode and charge the battery full after that also discharge the battery in safe mode....if not works then there problem of fan..talk to service center
May 21, 2011 | Computers & Internet
My Sony Vaio battery light remains orange
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
May 26, 2010 | Sony VAIO Notebook
Acer aspire 4315 Blank Screen!!!!!!!!
You need to Revive the bios back.
Search for Acer bios revive in google
Dec 19, 2009 | Acer Aspire 4315-2963 Notebook
Advent 7094swf turned off and never turn on again
i would say the hard drive needs replacing
Oct 15, 2009 | Advent Netbook
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
My ibm thinkpad booting and hanging fault
Try this... to see if your video card is bad...
Connect your laptop to an external monitor and press the Function key plus F5 on the laptop... if your OS shows up on the monitor screen, then you have a bad video card...
If its not the video, Bad Ram might be the cause.
And worst case.. Need Motherboard replaced...
Jun 09, 2008 | IBM ThinkPad T42 Notebook
HP dv6835tx Notebook with Visa Ultimate 64-bit will not shut down
From what you've described, it sounds like you are clicking the Standby button, instead of the actual shutdown option. On the Start button, you will see (from left to right); Left: Start Search Middle: Standby Middle: Lock Right: Arrow Clicking the arrow will show you the Shutdown menu option; http://blogs.chron.com/techblog/archives/shutdown.jpg
May 26, 2008 | Computers & Internet
IBM Thinkpad A22e Shutdown early on full battery
First, you should clean the battery terminals. You can scratch the terminals with a metal and then charge. Secondly, you should change your battery, that is, buy a new battery.
Aug 15, 2007 | IBM ThinkPad A22e 2655 Notebook
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
