Question about Janome Memory Craft 4000 Sewing Machine
Where can I get a replacement hard cover for this machine?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 58 Answers
Call this number or email Janome
info@janome.co.uk
Main
0161 666 6011
from outside the UK +44 161 666 6011
Posted on Apr 27, 2015
My dog knocked a wood burner into the front cover of a fashion mate 69 stitch computerized machine is there a way to replace the front cover?
Probably. However, the first issue is finding a replacement cover--may have to find a used donor part for that. Second issue is actually getting the old cover off and the new cover on without cracking or breaking anything, ie the plastic clips that hold the cover in place.
Apr 30, 2017 | Sewing Machines
How do I remove the back casing/cover so I can replace the spool pin?
Have you checked to be sure the spool pins do not pull out or are screwed in? Hard to diagnose without knowing the make & model.
Feb 01, 2016 | Sewing Machines
I NOTICE THE BELT IS HARD TO TURN-HOW TO CHANGE THE BELT?
Your machine is computerized and, as such, are closed systems (difficult-impossible to take the covers off per manufacturer's design). May be worthwhile to take it for service.
Jan 06, 2016 | Brother CS6000i Computerized Sewing...
A new hard cover for this machine
sorry we have no access to information here .
Apr 26, 2015 | Sewing Machines
How do i change the light bulb on singer model 7426 ?
You have to unscrew the cover of your sewing machine on the left top and once it is unscrewed you take the cover off and insert a new bulb and then replace the cover.
Jul 08, 2014 | Singer 7426 Mechanical Sewing Machine
Sewing machine is sewing slow
This could be for several reasons. I would try the easiest "fixes" first, such as: remove the needle plate and bobbin cover plate, and clean all lint from these areas, including between the feed dog teeth. Lint can quickly accumulate and bog the feed dogs from advancing correctly; oil all moving parts of your machine after removing the top covers, side covers, and the needle plate & bobbin cover plate as mentioned previously--oil anywhere in which metal moves against metal, but make sure you remove all lint or dried oil gunk first; check the belt of your machine to see if it is too tight if it was recently replaced--if it hasn't been replaced or adjusted in a long time, it would more than likely be too loose rather than too tight, but if too tight, it will bog the motor down by making the motor pulley too hard to turn; slowly turn the machine's hand wheel by hand without power with all of the covers off as previously stated and watch everywhere the machine moves--see if anything looks bent, is hitting something it shouldn't or making clanking or clacking noises somewhere as a part may be bent and rubbing somewhere, slowing-down the machine (and of course, if you know the machine has been dropped or damaged, something bent is highly likely which may require a repair tech); check your foot controller--is there something physically blocking the pedal from depressing completely?--these controllers also sometimes just need replaced, so as a test, you may borrow one to test on your machine and see if that helps; if your machine has a fast and slow sewing speed, make sure that setting is not governing the machine from sewing fast; check all of your power cords, plugs, and controller connections to make sure everything is plugged in securely, and maybe try your power plug in another outlet; and lastly, it could be your motor--the motor may need new brushes, some motors require a drop of oil now and then for the bearings (your manual should tell you this if so), or the commutator may have a common build-up of carbon residue that can be removed, and you may have just worn-out your motor that can be replaced. And as always, make sure you are using a new needle after encountering and hopefully fixing an issue.
Feb 17, 2013 | Singer 2263 Mechanical Sewing Machine
How do I take of the back cover on my singer 2250 tradition? Not the cover for changing the bulb, but the one that covers the rear of the machine. The machine became very noisy and after I cleaned it and...
These plastic machines are like computer cases. Get a thin bladed tool and wedge it between the sections... look for those "tab locks" and release them.
Good luck.
Aug 26, 2012 | Singer 2250 Tradition
My Shark Euro-pro 8260 sewing machine smells like it's burning inside... what is causing this and how can I stop/fix this? It has sat for several months since I last used it... and I hardly ever use...
hi, the motor may be going out,,smell the motor to see if it smells like a pair of old dirty socks, if it does smell then it needs to be replaced.
if it's not the motor then it could be some type of electrical short,, it needs to be serviced by a sewing machine shop
when a sewing machine sits for months, it needs to be covered with some type of plastic cover where dust can't get in.
Sep 23, 2011 | Sewing Machines
Sewing Machines Logo
55 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
