Question about Garden
Contax k18 ride on mower the deck shudders and there's smoke coming from the belt what's wrong with it this happen's occasionally the belt is new
  • 1,169 Answers
Check all of your idler pulleys as it sounds like one has a bearing that locking up. If these are of the plastic style one may flat spotted.
Posted on Apr 27, 2015
  • 246 Answers
SOURCE: I have a Countax K14 ride on mower the cutter deck
Hello ianh_2007:
Usually this Problem is Caused by a Blown Fuse or a Bad PTO Ground.
1-The Following is a Basic File I Made for Checking the PTO (Blade Engagement).
>>The Most Common Cause for this Problem is the PTO Ground. >>A Quick Ground Check is to Use Another Wire and Ground the PTO at the Harness Connection Nearest the PTO.
>>Be Careful and Do Not Ground the HOT Wire. Use a Multimeter and Locate the Ground Wire.
>>Clean the PTO Ground and All the Connections for the PTO Wiring Harness.
>>If you have an Ohmmeter, Disconnect the Wiring Harness from the Front of the Clutch and Check the Resistance of the Clutch. You should have around 4 or 5 OHMs. If at or near Zero, the Coil has Shorted.
2- >>The Following is a Basic File I made for Setting the PTO Clearance. Any Input is Appreciated. **Some of the Newer PTOs cannot be Adjusted.
>>If you can Get a Blade Style Feeler Gauge between the PTO Magnet and Clutch, then Set the Clearance at .015in. The Newer PTOs have the Same Set Up as the Older PTOs, except there is No Adjustments.
>>I Suggest also that you Rig a 12 Volt Light for Testing the Current Flow to the PTO while Operating the Mower. If the Light Blinks During Operation, then you have a Bad Connection somewhere to the PTO Clutch.
>>If the Light Stays Steady and the PTO Still Kicks in and Out, then it is the Adjustment.
>>You can Also Try Turning the Spring Loaded Adjuster Nuts 1/4 Turn and Operate the Mower. Do Not Adjust Over 1/2 Turn.
>>If you have Adjusted to 1/2 Turn and the Problem is Still Present and you Know the Voltage to the PTO is Steady, then Replace the PTO.**
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
SOURCE: need to replace belt on deck of john deere riding mower
does the belt on a 42" scotts lawnmower go behind the tenisoner or in front of it?
Posted on Jul 25, 2009
bargainbin2
  • 123 Answers
SOURCE: replacing deck belt
Here ya go.
Posted on Aug 26, 2009
mickey813
  • 472 Answers
SOURCE: We have a Weatern Auto Wizard Riding Lawnmower.
19c5756.gifHOPE THIS HELPS LET ME KNOW
Posted on Nov 19, 2009
No, Need to see a diagram of the springs that are on the deck of riding mower Model #247-288851
Hope this helps. Craftsman Tractor model #247288851 Deck and Belt Diagram
Apr 11, 2015 | Garden
Why are the blades engaged when mower starts and the handle is in off position?
the belt is routed around both blade pulley rear of belt routed to inside of pully tensioner front of belt routed to moter clutch or or in some cercumstance it is totaly the wrong belt and thats what i think your problem is i think you got to short of a belt
Aug 27, 2014 | Garden
42 IN 21HP BRIGGS &STRATTON
Deck belt is slipping. Are you cutting too low? May need a belt replacement?
Jul 19, 2013 | Garden
Lt 1000 new deck belt is smoking, is there a break-in period for new belts?
First, you need to check to make sure you have the belt on correctly. There needs to be a tensioner holding the belt in proper tension. I have had a few deck issues where a bearing is worn out and it could be smoking when the grease gets hot. See if you can get a diagram for the belt position and check your bearings and idlers. Also make sure it is cleaned out so that you don't have a lot of grass in there that could be burning and smoking.Good luck.
Jun 17, 2012 | Craftsman Replacement Belt for 42" Deck
My MTD riding lawnmower is burning thru the new belts I just purchased.The new belts are 954-0371A which replaces 754-0371A. The old style belt lasted 5 years. Even before engaging the clutch, the belt...
My idea is not about the belts, but is about the deck. If the tensioning mechanism on the deck is getting stuck in an intermittant position than the belt may be just tight enough to turn blades while slipping through the pulleys, this may cause enough friction to start melting your belts. If this is the case you will have to remove your mower deck and see what is preventing the mechanism from functioning properly.
Jul 07, 2011 | MTD LAWN MOWER PART 1909404 BELT
Husqvarna CT151 Smoking
the belt is smoking because a pulley isnt spinning like its supposed to. its gonna break the new belt if you don't remedy the problem. try taking the belt Back off. then see if you can spin the pulleys by hand with no belt .
Jul 31, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
May 01, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a bolens 38 inch riding mower. it cranked and when i tried to engage the cutting deck the belt smoked off. i replaced the belt and cranked mower. tried to engage and belt smoked and i shut it off....
did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
Feb 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Sep 30, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Have a 2006 145 automatic riding mower. Belt keeps
idler or adjustment pulley bearings worn allowing belt to ''run off''as it wobbles.stays on.check spring tension of idler.
Sep 20, 2009 | Garden
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
