Question about Epson Perfection 3170 Flatbed Scanner
Where to get an Epson scanner fixed?
The scanner light has moved to one end and does not return. It started to scan but then got stuck at the far end and did to return to the correct position.
jackboy
  • 2985 Answers
SOURCE: scanner not responding to preview scan
Try this as a last ditch effort. Remove the software. Reboot the computer and come off line. Disable the Anti Virus program. Now install the soft ware. Then try. If the red light still flashes then assume it is new scanner time.
Posted on Aug 02, 2007
Basti
  • 1447 Answers
SOURCE: Epson 4180 scanner w/ possible drive belt problem
Check if you have a toggle lock at the back of your scanner, when you are facing the back of it, its on the right hand side near the tpu cable. toggle that 3x and make sure it on the UNLOCK position.
Posted on Mar 24, 2008
  • 110 Answers
SOURCE: Scanner wont scan transparencies properly
On the 4990, make sure that you have unlocked the lid of the scanner. The lock is located underneath the lid.
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Posted on Aug 22, 2008
  • 2692 Answers
SOURCE: I Can't start epson scan software.
My guess is that the cd that you are attempting to use is for a different version of windows than you presently have. If that be the case; download new software and driver for the OS that you now have.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14587&infoType=Overview
Posted on Jan 06, 2009
SOURCE: Epson V500 scanner will not scan film
You're problem is Vista, not the v500!
Posted on Jan 01, 2010
My scanner is not returning it seems to be stuck
I have had good luck fixing that problem by opening up the scanner and cleaning the rails with alcohol then very lightly lubricating them.
Feb 28, 2015 | HP Scanjet G2410 Flatbed Scanner
Tip
Fix Red Flashing Light on Epson V500 Photo Scanner
Try moving any excess film (if your strip is longer than the holder ie scanning medium format film cut too long to fit the holder) to the other end of the holder so it hangs out of the end where the controls are on the front of the scanner.
on Mar 29, 2010 | Office Equipment & Supplies
My Canon MG8120 all-in-one makes a loud noise when copying (not when printing). How do I fix it?
Dear
from the question I understand, the scanner move to right and during return it starts noise.
The problem with scanner assembly, It might be dust accumulated on gears, the scanner belt might have loose or the grips of the belt has worn out. Proper cleaning and lubricating the moving parts may overcome also if the belt worn out it has to be replaced.
In case of at home position it gives noise then the home position sensor may dirty/dusty, it has to be cleaned.
thanks.
Feb 15, 2015 | Canon Pixma MG8120 Wireless Photo...
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Mar 31, 2014 | Brother MFC Office Equipment & Supplies
My Epson scanner makes whirring noise
There are a couple possibilities that can cause the problem.
1. you need to unlock the scanner. There is a lock at the side of the scanner that could be in the locked position which is preventing the scanner from moving. you can use a nickel or penny or screwdriver to turn it to release it.
2. the tab that is holding the gear is broken
3. the glass is not attached 100% to the upper case and the scanner is hitting it when trying to scan.
if its 2 or 3, you might be better off getting a replacement.
thank you
May 25, 2010 | Epson Perfection 1250 Flatbed Scanner
Scanner mechanism stuck, making loud clicking sound
I've just got this problem after a powercut, whilst it was not being used but on. If you have only had it a few months send it in warranty.
Think I will have to take this apart and see if the scanner cable/ribbon/drive belt is caught on something or been stretched too much and can be replaced at all.
Its like at one end its caught and wont move the scanning head being stuck somehow, caught on something (doubtful tho').
Apr 14, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson Artisan 800 Scanner leaves blue/grey stripe on side.
I had this exact same issue with two Artisan 800's. I was told it was a hardware issue. Both were returned under warranty to Epson. Have since had problems with ADF and that printer was returned. Warranty has now ended. Expecting to buy a new printer shortly: they last about 4 months before having problems. It won't be an Epson even though that's all I've owned for 10 years
Sep 17, 2009 | Epson Perfection V100 Flatbed Scanner
Epson Stylus NX105 scanner started clicking when turned on...
I dismantled the printer because i've been having the same issue. It recedes to the right and begins clicking because it is at the end of the track. For some reason the scanner isn't registering that it is at the end of the track and keeps persisting making the gears jam up on the other end because they obviously can't move any further. Any suggestions as to how to fix, or master reset?
Aug 28, 2009 | Epson Stylus NX105 All-In-One Printer
Scanner buzees and moves slowly and scan's all photos as one
I fixed the problem by updating a driver I found in the Epson site. It woeks great once again.
Mar 23, 2009 | Epson Perfection 3170 Flatbed Scanner
CanoScan 5000F - Scanner bar is stuck
hi all;
i fixed it by taking the thing apart, pushing the scanner head (the block that is stuck-- that normally moves) back to the starting position. Make sure its snug at the end, a little bit off and you'll be putting it have to take it apart and back together a second time. There's a mirco swtich in there somewhere, and you need to make sure its pressed...
reconstruct, and hey presto, a working scanner! this also worked for my epson 1250 that got stuck once.
Easy as a section of gateaux.
Oct 04, 2007 | Canon CanoScan D660U Flatbed Scanner
Epson Perfection 3170 Flatbed Scanner Logo
59 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
