Question about Belkin Computers & Internet
MY ROUTER IS NOT GETTING RESET - Belkin Computers & Internet
  • Belkin Master
  • 7,733 Answers
Try this first:
GENERAL ROUTERS RESETING
then this : http://www.fixya.com/support/r7900574-general_router_setup
Posted on May 12, 2015
We believe it overheated and now the internet provider is sending 20mbps download speed but once it hits the router we only get 1.61mbps to the computer. How can we fix it so we are getting the full...
if your router was truly overheated you wouldn't be getting any signal at all. The advertised dl speed of ISP's are greatly exaggerated. First you have to figure you what you're actually getting
So connect a computer directly to the modem, bypassing the router then go to:
http://speedtest.net/
to figure out what you're getting.
If you get what you've gotten before, then welcome to the world of false advertising.
If the diff between what you directly, and then behind the router is more than 10mbps then from the settings of your router:
1) Check DMZ (demilitarized zone) and redo the test. If you're speed improved significantly then you have an internet port blocked in the port forwarding settings of your router. Most likely port 80, or 8080. These are http ports. Release the ports. If your speed hasn't improved:
2) hold the reset button of you router for 20 seconds. Power cycle the router. Hold reset button for another 20 seconds. POwer cycle the router. Hold reset button for a 3rd 20 seconds. This will hopefully clear the NV ram in your router. Redo speedtests. If it still hasn't improved, plug the wire cord into another port. No improvement? buy another router! Which reminds me:
3) You won't get 20 mbps with the WIRELESS aspect of your router, only wired. So hopefully that's not the issue.
Good luck, and hope this helped.
Jul 14, 2011 | Computers & Internet
WRT4G2 VI wireless router. I was upating the firmware when the power flashed. I have no access to the router's gui and the router is not broadcasting. I am not getting a dhcp address
do a hard reset for the router by pressing the reset button for 10-20 seconds...
check whether its getting a dhcp address...
if it is still not getting an ip address, then try to assign a static ip address in the range of your router on your computer...
for example...
The default ip address of linksys is 192.168.1.1.............
then assign
IP address 192.168.1.5
Subnet mask 255.255.255.0
Default gateway 192.168.1.1
Also assign a static DNS
Primary DNS : 8.8.8.8
Secondary DNS : 8.8.4.4
Now try to open the GUI of your router...
Dec 10, 2010 | Linksys WRT54G2 Wireless Router
Where is the reset button on a 3 antenna linksys WRT54g Wireless Router (silver case)
reset button is in the back of the router you will see a small hall in the back of the router you need a pin or some thing just push it in and press for one minute you will see all the light in the router getting off remove the pin this will reset the router before reseting the router
Nov 14, 2010 | Computers & Internet
Router/power light constantly flashing cannot make any connection to computer
try to reset the router. On the router you will find the reset button. press it and hold it down for 30 seconds. release the reset after 30 seconds. wait for 1 minute. unplug the power and plug it back in. wait for 1 minute and check if the power light stays solid.
If not then try to reset the router again.
check the IP address on the computer. If you are getting a valid IP address then try to open the set up page of the router.
If you are not getting the valid IP address and power light is not solid then I think you will need a new router.
Click here for more information about the router
Mar 09, 2010 | Belkin (F5D7231-4) Wireless Router
Keep getting error message - unpupported router
Make sure that you have completely install the router driver on your PC. Better to download the latest firmware for that model if has needed. Also try to reset the unit, by pressing the reset button, this will restore and reset the unit to it's default factory setting's.
Hope this helps.
Let me know for further instructions.
mico~
Jul 19, 2009 | NetGear WNR2000 Wireless Router
Can't access Belkin setup page 192.168.2.1 anymore.
There should be a small reset pin hole in the back of the device. Hold down the reset button for 15 seconds and it should reset the router to factory defaults
May 27, 2009 | Belkin (F5D7231-4) Wireless Router
Linksys wireless -G 2.4 GHz router just stopped
I would try a factory reset of the router if there are not any special settings saved in the router. To factory reset the router press and hold down the reset button on the back with a pen or similar object for 30 seconds and then unplug the power cord and plug it back in.
Apr 09, 2009 | Linksys Wireless-G Broadband Router
I cant get my new wireless N linksys WRT310N router to work
First reset the router by pressing the reset button for 15 seconds and after resetting it run the setup CD fo it to reconfigure the router, if you don't have the setup CD better contact Linksys tech support number and let a tech walk you through in manually configuring the router, this is the number for Linksys 800-3267114...........
Jun 18, 2008 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Cannot get hooked up to router
connect your pc to the router then check if it is getting an Ip address. if not hard reset the router by pressing the reset button on the back for 39sec then unplug it from power.
plug it back then check if you are getting an ip if there is an ip you can access it definitely
May 25, 2008 | Linksys Wireless-G WRT54G Router
Netgear
There are two things involved in getting disconnected either your comp is getting disconnected or your router.
Instance 1
Computer getting disconnected connect your comp and router with ethernet cable if using wireless. Because at times it's not router but the wireless connectivity that gets loost.
Instance 2
Router getting disconnected...
Reset your router by holding the reset pin at the back of your router for 15 secs and lights will start flashing on router wait for 1 min you'll have router reset to default settings and now check that dsl or internet light on your router is flashing or static if flashing contact your isp issue with the line if static run the disc for router installation again and it'll remain connected after successful installation.
Apr 22, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
