Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
Can you tell me why our Barracuda keeps flipping over and climbing walls more than usual. Hose doesn't seem to be flexing and moving with the unit.
    Top Expert:
  • Zodiac Master
  • 5,922 Answers
Reduce suction
Posted on Oct 19, 2017
3 Suggested Answers
jharwell668
  • 640 Answers
SOURCE: barrcuda inground pool cleaner flips over
Often when you are having this problem with automatic pool cleaners, it has to do with the hose. Make sure that you have plenty of slack in the hose to cover the entire pool. Also, make sure that you do not have any obstructions in the hose and that it is not tangled.
Posted on Jul 28, 2010
rickspool
  • 20 Answers
SOURCE: Barracuda climbing walls almost to
There are several adapters on the market to allow more water to bypass the cleaner. One is called the Vac-Mate, another is the Hayward skimmer adapter. I personally like the vac-mate. but it's only compatible with most skimmers.
Posted on Apr 04, 2011
I have a frigidaire wall oven showing E r r f1 what is wrong no manual
Typically error code F1 could indicate a variety of issues. The wall oven could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the wall oven by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately
Nov 19, 2012 | GE Ovens
The yellow nut that screws the hose to the unit at the top of the Zodiac keeps jarring lose and then disconnecting from the suction hose. I have to keep reattaching it at least once a day, but the nut...
Try some teflon tape.. Remove the cassette and apply 3 to 5 even wraps on the thread and then install the cassette back on and tighten.. This should keep the neck from backing out...
Aug 16, 2011 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Aquabot Turbo T2 flips over when it tries to climb walls. Water is not coming out the top but the unit is moving fine. Does it need a new pump motor or can something just be clogged inside??
the likely problem is the float/handle. Make sure it moves freely and is always in the straight up position when on the bottom of the pool. If it's not then it is the problem.
Jul 20, 2011 | Aquabot Turbo T
I put the eyeball diverter on my pool and the cleaner runs up to it and the hose hangs on it. I keep my hose laying out strait when not in use. It does seem to stay on the sides also.
If the eyeball diverter is not working, you might need to install a wall climb adjuster (Part #K12065). This will keep the automatic pool cleaner on the pool's floor and walls and away from pool obstructions. Make sure the narrow end of the wall climb adjuster points down to the drive tubes.
Aug 23, 2010 | Universal Kreepy Krauly In-Ground Pool...
The barracuda just returns to the deep end of the pool and stays there, how can I get the cuda to sweep the whole pool?
The Barracuda Zippy is an Above Ground pool cleaner and is not designed for a pool that does not have a flat bottom. They are generally not capable of climbing slopes, walls, etc.
Apr 19, 2010 | Zodiac Baracuda Zippy Pool Cleaner
Barracuda x7 quattro won't go to the shallow end of the pool
Zodiac X7 only 4 months have problems with Parts, had to replace all lower parts and now the flex hose fitting is bad.
I believe this design is a lemon.
Aug 12, 2009 | Zodiac Baracuda G3 Automatic In Ground...
How to hookup side exhaust vent on a Kenmore dryer?
Go to a hardware store and ask for a dryer hook-up kit. You can run the vent to an outside source through a wall or if needed you can exit the exhaust through a roof although I would not do this unless it was the last resort. Instructions for the dryer hook-up are included with the materials.
It consist of connecting a vent hose usually 4 inches to the dryer outlet and running the hose usually a flex hose to another outlet that vents the dryer air outside. The outside connection should have a door that closes when the dryer is not in use to keep rodents and pest out.
Jun 14, 2009 | Kenmore 700 6973 Dryer
Barrcuda inground pool cleaner flips over
Jun 13, 2009 | Zodiac Baracuda Zippy Pool Cleaner
AF flashing on our Whirpool Cabrio Dryer.
Hi Terry,
AF flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
I suspect it's the vent connecting the dryer to the wall or the vent pipe in the wall to the outside. Without moving your dryer, look behind it to see if the flex duct is crushed or pinched. If it is, it's pinching off your air flow, too. Pull the dryer out straighten or replace the hose (you can get vent hose at Home Depot, Lowes or Ace Hardware) then slide the dryer back being careful to keep it about 8" from the wall (8" is the recommended distance from the back of the dryer to the wall, btw).
If the flex vent is NOT pinched off, then you should call a chimney sweep to come out and clean the vent pipe that's in the wall.
*Note---> If you want to test this diagnosis to verify it, just disconnect the flex hose from the wall and run a load of clothes. The error code should not reappear.
SG
Mar 27, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
163 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
