Question about Radio Communications
How do i get my TYT 2R out of channel mode and save the setting?
The radio switched into channel mode whilst in lock mode in my pocket. No manual came with it so no idea how to get it back out of channel mode
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 116 Answers
Instruction Manual is available at google you can get help from their. Also check the channel lock key.
Posted on Aug 03, 2015
Mic wiring for tyt -9000
since this is a fairly new radio, your only resource is your manual and schematic.
As a Ham you should be able to read them. If you are thinking of installing an aftermarket mic, you don't do this on most ham radios, they are not CBs that you can put a "power mic" on. too much audio input on an FM transceiver can make your transmission unintelligible
Oct 12, 2014 | TYT Electronics TYT TH-9000 VHF...
Programming tyt TH-F8 radio
Be sure the "Channel" and "Code" are set the same on both radios.
May 14, 2014 | Radio Communications
What does TOT mean on display?
TOT Penalty means: If the radio transmits more than a set time, it will beep an T-O-T error tone and the radio will only receive a signal for the penalty time. (TX inhibited for this time).
Under the above mode, press Up/Down buttons to select On or Off and then press Mode button or PTT button to set Busy Channel Lock Out. The radio will then save selection and exit to receiving stand-by
mode.
To DISABLE... navigate the menu to "PENALTY" in the display... press mode button... then use UP or DOWN buttons to select mode... to disable select "OF" (which means off).
Good Luck.
Apr 26, 2014 | Midland M222P (22 Channels) 2-Way Radio
MT TYT 9000 220 MHZ NO RECEIVE
Might want to post what kind of radio you are having problem with for better answer. Sounds like it could be several different things.
Jan 05, 2014 | TYT Electronics TYT TH-9000 VHF...
Can not connect my two way motorola t5920 set
Be sure they're both set to the same "channel" and "code".
Feb 22, 2013 | Motorola Talkabout T5920-2R (7 Channels)...
I lost the owners manual for my Innova - Trifecta Digital AM/FM Clock Radio with Built-In Apple® iPod® Dock Model: VR880SA | SKU: 8955222 and do not know how to reset the preset channels
I have the manual.
1. Press the FUNCTION button to select FM or AM mode
2. Press SKIP to select station.
3> Press and hold the Memory button to enter channel saving mode.
4. Press the Memory button to select desire preset channel #.
5. Press and hold the Memory button again to save into memory. If it has been previously set, the former station is replaced.
6. Repeat step 2 and 5 to store addtl. stations.
Any idea as to how to set the volume during alarm mode, it's too loud!!
Jun 04, 2009 | Audio Players & Recorders
Stucxk on vibrate
As per instructions of the manual:
"...Your microTALK® radio can alert you to incoming signals by
sounding an audible call tone, by vibrating silently or both. To change call settings:
1. Press the Lock/Mode button until the Call Setting icon flashes on the display. The current setting (“01” vibrate + ring, “02” vibrate only or “03” ring only) is displayed.
2. Press the Channel Up or Channel Down button to change the call setting.
3. Choose one of the following:
a. Press the Lock/Mode button to enter the new setting and proceed to other functions.
b. Press the Hi•Low/Enter button to enter the new setting and return to Standby mode
Should you need a copy of the manual, it is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 16, 2008 | Cobra 22 CHANNEL 2-WAY RADIOS
Operator/instruction manual
ghilger, First off, has your radio been converted to open up all the other channels(including CB)?? That has to be done first, or it's locked in the ham freq's. I think the factory manual is pretty well detailed, but i've been around radios my whole life. The mode button does the changing from am/fm/usb/lsb.Here's from the manual;
MODE: Operating Mode. Press the MODE control to select the operating mode. The operating mode is indicated on the liquid crystal display: am, fm, usb, or lsb.
* See, there is 2 different functions for each button. One set of functions are by just pushing the buttons, the other set of functions are obtained by pushing the function button first. The function button is activated by pushing in on the clarifier knob.
*Here is for saving of freq's;
Memory Save. To save in memory a specific
frequency and operating mode, select the desired mode and rotate the FREQUENCY control to the desired frequency. Press the FUNC button, and then press the M.SAVE button. S will appear on the LCD next to the frequency. While S is displayed, immediately press any of the memory channel buttons (1 - 5). The mode and frequency is now saved into memory. If the S indicator disappears before you press the memory channel button,
the information will not be saved and the process
must be repeated.
M.LOAD: Memory(Recall). To recall, any of the saved memory channels press the M.LOAD
button. L will appear on the LCD for several seconds. While the letter is displayed press the desired memory channel button (1 - 5). The programmed mode and frequency will be displayed.,
If you have any more questions about the radio, repost them here and I'll try to walk you thru them. The radio is a very good ssb rig, especially set up with a power mic. Hope this helps,, Mechanic
Feb 03, 2008 | Magnum 257 CB Radio
Radio Communications Logo
194 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
