Question about Home
Im went to work today
I will cut my knives carefelly
Cutter not working
Hi Jackie, I'm Julie, what brand and model of sewing machine are you using, please?
Aug 05, 2015 | Sewing Machines
My Singer Serger won't cut, I have changed the knives but it didn't help.
Perhaps the knives have been put in wrongly, check your manual.
Oct 12, 2014 | Sewing Machines
Knives don't cut and needles keep breaking. Can't sew with the Toyota 6600 Serger.
knives may need to be replaced and the serger needs to be checked for a timing problem
Nov 05, 2013 | Sewing Machines
Serger's knives are not cutting
the knives probably need to be replaced
Jan 30, 2013 | Sewing Machines
When buying a dive knife, should I get one with a serrated edge or a straight edge?
Serrated edges are used for cutting natural fibers such as rope and kelp and can be used with a sawing motion. The straight edge knives are better for cutting plastic, fishing line and nylon rope. You can get knives with a serrated and straight edge so you would be better to get one of these.
Jan 17, 2013 | Scuba Diving & Snorkeling
What kind of cutting board is the best?
I think plastic is the best. Wood harbors bacteria, glass ruins your knives. Plastic ones can be cleaned well and they even can go in the dishwasher.
Jan 14, 2013 | Home
What's heavier a German or a Japanese knife?
A German knife is generally heavier. It has a thicker and more robust blade with a more obtuse angle at the cutting edge. A Japanese knife is generally lighter and has a thinner blade, so it should not be used for heavy cutting tasks like chopping through bones as this will most likely chip the blade. Most Japanese knives are best used for slicing and dicing.
Jul 25, 2012 | Camping, Backpacking & Hiking
HOw do I adjust the tables so I do not get a snipe?
Adjusting a jointer to relieve snipe can be trickey but here are a few procedures that will help.
-The two tables on the jointer are adjustable, the front (infeed) is what you adjust for cut depth.
- The back (outfeed) needs to be the exact hieght as your knives
The outfeed needs to be adjusted first
-unplug jointer
-using a straight edge on the outfeed table adjust it so that when you turn the head (counter clockwise) the knives just touch the staight edge (NOTE** all the knives should touch the straight edge the same, if not your knives are not set correctly) This is your most important adjustment, if the outfeed is to high or to low it will cause inconsistant jointing.
-Now that the outfeed is trued up to the head you can adjust the infeed table, using the straight edge align it so that it is perfectly lined up with the outfeed table (not touching the kinives) Your jointer is now at ZERO
You can now adjust the infeed for depth of cut, Start by lowering the infeed a very small amount (1/16 of a inch to start)
The biggest problem I have seen is that people try to cut to much at one time, it will work alot better if you take several small cuts instead of one deep cut.
Also- getting the knives set perfectly in the head is a key to success, if this is not happening you WILL have jointing problems. ALSO if the knives are not sharp they will pull the material down causing snipe.
I really hope this helps and if you need a visual aid try looking it up on you tube.
I have used my jointer for numerous different projects, Here is a cool one for tapered table legs.
Take a piece of square stock (like 2x2 ) about 3 feet long, make a mark about 2 foot up and wrap a piece of tape around it at the mark.
now make a mark (we will call it a stop mark) on the fence of the jointer by the head.
with a pencil and number the edges on the 2x2 (above the tape so you dont joint them off)
turn on jointer and run side 1 until your tape is at the fence mark, carefully lift 2x2 and do the same to the 2 side.
only joint the #1 & #2 sides, run several more times and you will have a perfect tapered leg.
SHOP DOG
May 02, 2011 | Masonry Tools
WHERE CAN I FIND REPLACEMENT KNIVES FOR BROTHER 1043D
Right from Brother at 1-800-276-8437 you can order it. Also, www.sewingpartsonline.com for around $7. I think that your Serger is a 1034D, are you sure that Brother didn't give you one in your accessory bag?
Dec 30, 2010 | Brother Lay-In Thread Serger Mechanical...
Home Logo
336 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
