Question about Whirlpool Ovens
Have a whirlpool generation 2000+ oven. Middle button on panel has been temperamental for a while. Now after power cut, button is not reacting and cannot get out of 'stop' mode? Any help out there?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 58 Answers
  • 833 Answers
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Posted on Dec 07, 2007
SOURCE: Whirlpool Generation 2000+ oven
Yeah just turn the left hand knob to the one setting which isn't a cooking function - I think it looks a bit like a dash - and then power up as normal on the right hand knob.
It happpened to me but you get the hang of it and it's not a fault.
Sid
Posted on Jun 03, 2008
SOURCE: whirlpool oven
Press the botton between the two control knobs and hold for a few seconds.
Posted on Dec 24, 2008
  • 25 Answers
SOURCE: Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
Posted on Jun 25, 2009
  • 5 Answers
SOURCE: whirlpool electric oven problem
thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
Posted on Oct 26, 2009
E6 F2 Fault Code on left side Display panel of Whirlpool Accubake Upper oven. There is No Cancel Button on the Display Key pad. Double oven unit has just been cutting off in middle of Bake Cycle.
this is usually a problem with the keypad, most techs would say to replace the keypad, if that doesnt solve it, the main board will need to be replaced. make sure your connectors are tight if you decide to kill power and replace the keypad
Dec 20, 2016 | Whirlpool Ovens
After a power outage my oven does not work and only the left half of the stove is working, any thoughts?
Needs resetting. With power off, press middle button and hold in. Turn power on and continue to hold middle button until STOP disappears. Should now be able to reset.
Aug 27, 2014 | Whirlpool Ovens
Whirlpool generation 2000 wont reset after powercut. Just says STOP.
Turn left knob to dash mark then turn right knob on normally see if this works. Hope this helps.
Dec 31, 2013 | Whirlpool Ovens
I have a STOP message on the oven display. The user manual refers me to the product description sheet or the electronic programmer description, neither of which I have. The oven is not working at all while...
HI. This is a control fault, that may be corrected by simply shutting down the appropriate circuit breaker for 5 minutes. This will DE-energize the control board. Once the 5 minutes have passed, simply re-introduce power to the unit. If the unit continues to produce the error, this will confirm that the main control board has failed. it should be replaced asap.
Nov 04, 2009 | Whirlpool RBS275PD Electric Single Oven
Whirlpool oven will not heat up after self lean
Check the overload thermostat inside the back panel of the oven.
No continuity? Replace it.
Mar 02, 2009 | Whirlpool RBS275PD Electric Single Oven
OVEN BLACK-OUT!
Just turn off and then turn on next day...........
Aug 03, 2008 | Whirlpool RBD245PDS Electric Double Oven
Re: my whirlpool digital oven
The red key sign is a lock against children. To cancel it you have to hold the two buttons at the same time for 5 seconds (you activate it the same way).
The STOP sign appears after the cooker switches of after a power cut. You just have to press the left button, and, using the right knob, set the time.
Jun 24, 2008 | Ovens
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
Whirlpool Oven AKZ101/1X serial 858510115001 140349004758
Ensure the oven knob is set to 0 (zero) and press the reset button in the middle
Oct 24, 2007 | Ovens
Ovens Logo
865 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
